Logic Level shifter for 12864 display on Duet 2 Wifi
200
16.5k
    A Former User @oliof
    @oliof said in Logic Level shifter for 12864 display on Duet 2 Wifi:
    it needs 8MHz instead of 2
    should be possible to do with F8000000 to the M918 command
    for the pinout you could look at reprap http://reprap.org/mediawiki/images/5/51/RRD_FULL_GRAPHIC_SMART_CONTROLER_SCHEMATIC.pdf and work backwards from the 3 pins on the lcd and the pins on the encoder (to map the cr 20 header)?
      oliof
      Thanks for pointing out the F parameter! I will use the default pin layout if only to avoid future hassle when a ready-made adapter is available and people use this that aren't up to making their own custom cable (especially considering I have enough trouble doing it myself).
      A new reprap smart controller is on the way so I can test with a device that's known good ... I will test first on an unmodified maestro running RRF 2.05.
      ? 1 Reply Last reply 21 Apr 2020, 15:20 Reply Quote 0
        not sure which is the default? afaik beyond the reprap one its a bit of a lottery, and ramps have had a range of adapters for the various clones (why they couldn't just clone the reprap idk)
        if you're refering to the change i made, it's only between the duet and the 74htc08 so it won't affect the display as such. (but it will simplify troubleshooting as you only need to get 1 cable right to get the display to indicate its working)
          oliof
          The reprap one works for my favorite replacement display BTT TFT24/35 in 12864 emulation mode) (-: but you're right it -- doesn't matter for the the display side.
            oliof
            @bearer by the way, there is a 3.3v source on CONN_SD as well (Pin #8), so no need to head over to the z probe for that.
              A Former User
              yeah, noticed when i finished up the wirng, but now i finally need to get on with setting up rrf3
                Schmart @oliof
                @oliof I'm pretty sure the CR-20 minipanel is based on the ST7565. The first clue was that I haven't been able to find any display modules of that (small) size with an ST7920 on it, they all come equipped with a ST7565. Also, I put a logic analyzer on the display pins of the Creality mainboard, and I'm seeing A0 being actively used as data/command line (4-wire SPI) and the decoded commands correspond to the ST7565 datasheet. Here's a screenshot from a saved capture:
                Edit: improved wording.
                Creality CR-20 Pro with a Duet 2 Maestro, 3Dfused X+Z-axis rail kit, HIWIN-based DIY solution for the Y-axis, E3D Hemera, working ST7565 MiniPanel and various other small hardware improvements.
                ? 1 Reply Last reply 24 Apr 2020, 21:15 Reply Quote 0
                  A Former User @Schmart
                  @Schmart fyi oliof is "gone fishing" for a bit; https://forum.duet3d.com/topic/15792/taking-a-break
                  undefined 1 Reply Last reply 24 Apr 2020, 21:32 Reply Quote 0
                    Schmart @A Former User
                    @bearer Thanks for the heads-up! Then please consider my message as general information for the forum 😉
                      oliof
                      Just a little peek to report that I got it almost working with a cloned RepRap Smart Graphics Controller with very low SPI speed (100kHz) and somewhat malfunctioning buttons (stray button presses registered) using a txs0108 -- most likely due to shoddy cabling work.
                      @Schmart thanks for the headsup. That's a bummer as I lack the time and skill to implement full ST7565 support.
                        After a bit more research I discovered that the mini 12864 displays that use the ST7567 chip should already be 3.3V-compatible. That includes this one https://github.com/FYSETC/Mini-12864-Panel and clones, including the Viki 2 and MKS Mini I think. These displays need one more pin that the ST7920-based displays and a modification (probably small) to the driver, but that shouldn't be difficult.
                        What's stopping me adding this support to the Duet WiFi/Ethernet firmware as standard is that there isn't enough room in flash memory. Recent improvements in RRF 3.01RC and switching to a more recent C++ compiler and library have increased the binary size to 493kb, leaving just 19kb free against 24kb needed.
                          oliof
                          ISTR that extra pin is for digital contrast control (the smart full graphics controller has a potentiometer for that) so it might need another option for M918 to set contrast ... likely adding some more memory requirements.
                          But as long as there's no space in RAM that's likely moot anyways.
                          undefined 1 Reply Last reply 30 Apr 2020, 20:40 Reply Quote 0
                            dc42 administrators @oliof
                            It's not for contrast control, it's just that the ST7567 controller chip needs a command/data input pin as well as data, clock and CS.
                              oliof
                              Today I learned.
                              That said, I'd be willing to carry a patch removing unnecessary kinematics for an unofficial unsupported build with ST7567 support to make space -- I already know how to do that. I should be able to keep the patch going in case it needs changes ...
                              @dc42 I want to thank you a lot for even putting forward the consideration of including it; I also understand other features would be prioritized indefinitely.
                                antlob
                                @oliof @dc42 @bearer
                                First of all congratulations for the great job, I'm new to Duet 2 Wifi and have an LCD 12864 that came with my 3d printer (secKit Go) I also have the Paneldue 4,3". My first question is: Could I have both displays working at the same time? If I loose the SD card on the LCD 12864 would be fine since I have it on the Paneldue 4,3". What I would really like is to have the encoder operational on the LCD 12864. Is this doable? Many thanks in advance for your support.
                                  oliof
                                  emerges from time spent away from 3d printing
                                  If the SecKit go panel is driven by an ST7920 it will work with the level shifter and a custom Duet2 Wifi firmware that makes space for the LCD12864 support today by cutting something else (for example a motion system you don't need on your printer like Hangprinter).
                                  AFAICS using an LCD12864 and PanelDue in parallel works. But then v3 PanelDues have the pins for an encoder and there will be support for it in a future release so maybe it's better to wait for that.
                                  submerges again
                                    antlob
                                    v3 PanelDues
                                    Thanks @oliof for the reply. It does have the ST7920 so I I would need to connect the LCD to the CONN LCD on the Duet and add a level shifter following the schematics on the forum above skipping the SD Connector, rigth?. That does not seem hard but, my struggle is with the firmware, following Markus Scheck blog and the comments above in the fourm there are some libraries to be included and minor changes to be made to them. I've found this instructions for building https://github.com/Duet3D/RepRapFirmware/blob/dev/BuildInstructions.md of the @dc42 fork but ... I know it is a stupid question and sorry in advance, Where can I find the source libraries to make the bin file? My current version on the Duet 2 Wifi is 2.05.
                                    Thanks again for your time.
                                    ? 1 Reply Last reply 21 May 2020, 08:18 Reply Quote 0
                                      A Former User @antlob
                                      @antlob Looks like they've started migrating to https://github.com/Duet3D/
                                      btw, you need the gate function of the 7408 as well as its level shifting. (I used the TXS0108 as the enable pin mimicked the AND gate function.
                                      undefined 1 Reply Last reply 21 May 2020, 08:27 Reply Quote 0
                                        antlob @A Former User
                                        Thanks for the tip @bearer, found them finally, is huge but I'll definitely try it. Just one question, if I only connect ENC_SW, ENC_A, ENC_B, BEEP on the Duet 2 CON_LCD to the EXP 1 and EXP 2 on the LCD 12864. Will it work? The CON_SD is used right know to support the SD on the PanelDue.
                                        ? 1 Reply Last reply 21 May 2020, 08:29 Reply Quote 0
                                          @antlob said in Logic Level shifter for 12864 display on Duet 2 Wifi:
                                          CON_SD is also needed to drive the display, it uses the SPI bus for both, which is why I opted to change things around so I could connect only CON_SD and have a functional display sans the encoder.
                                          undefined 1 Reply Last reply 21 May 2020, 08:53 Reply Quote 0
