    Tevo Little Monster delta endstopless homing
    815
      Don't use such a small H parameter, use a faster homing speed. If you set the H parameter too low then stall detection will become temperature-sensitive. I included an example for a delta printer in https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing#Section_Procedure.
        dc42 administrators @DomMilan
        @DomMilan said in Tevo Little Monster delta endstopless homing:
        Also updated the config to use 256 microstepping
        NO NO NO!
        (sorry, it's late here. time I turned in.)
          Phaedrux Moderator @DomMilan
          What DC42 means is that this won't solve your issue at all, and will likely result in performance issues along the road. Use x16 microstepping with interpolation to x256 for best results.
          • DomMilanundefined
            DomMilan
            So after the changes and DC42s recommendation I am back where I started... I really don't know what to do. I am running the same setup and an Ender 3 and it works perfectly and I cant even get this this thing to home.
            • DomMilanundefined
              DomMilan
              On top of that all my thermistors are now reading 2000 even though everything is all connected.
                What settings are you currently using and what exactly is happening?
                Does the Little Monster not have endstops already? I'm not sure what the draw of stall detection homing is for a delta? I'd think you'd want the best reliability and accuracy possible for homing.
                • DomMilanundefined
                  DomMilan
                  @Phaedrux said in Tevo Little Monster delta endstopless homing:
                  I live near New York City and I have put my 14 3D printers to work printing 250 shields a day. I was running my SBase on the TLM until the board died. Turned out one of my endstops died too, which is why I am trying to run sensor less homing. My temp errors went away when I moved to Firmware 2.03-2.05 from 3, so that's taken care of. Guess ill buy the endstop and wait another week until I bring this thing back to life.
                    I see. Well there is the manual way. You could move the carriage into position and then set the position with g92.
                    But as I said before what settings do you currently have and what happens?
                    DomMilanundefined 1 Reply Last reply Reply Quote 0
                      What speed are you now using in the G1 homing move in your homedelta.g file? Previously, you had it set too low. Revert to using H400 in your M915 commands, and try a homing speed of 4000 mm/min as in my example file.
                      Note, stall homing by itself isn't accurate enough to home a delta, but if you have a Z probe then one or two auto calibration cycles after homing will fix the accuracy.
                      • DomMilanundefined
                        DomMilan @Phaedrux
                        @Phaedrux
                        My config
                        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Apr 25 2020 21:37:52 GMT-0400 (Eastern Daylight Time)
                        M550 P"The Fortune Teller" ; set printer name
                        M665 R155 L397.19 B155 H520 ; Set delta radius, diagonal rod length, printable radius and homed height
                        M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
                        M551 P"Turnip123!" ; set password
                        M552 S1 ; enable network
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        M92 X80.00 Y80.00 Z80.00 E403.00 ; set steps per mm
                        M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
                        M203 X18000.00 Y18000.00 Z18000.00 E9000.00 ; set maximum speeds (mm/min)
                        M201 X5000.00 Y5000.00 Z5000.00 E1000.00 ; set accelerations (mm/s^2)
                        M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        M208 Z0 S1 ; set minimum Z
                        M574 X2 Y2 Z2 S3 ; set endstops controlled by motor stall detection
                        M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                        M558 P9 H5 F120 T7200 ; set Z probe type to bltouch and the dive height + speeds
                        G31 P500 X0 Y20 Z1.3 ; set Z probe trigger value, offset and trigger height
                        M557 R150 S45 ; define mesh grid
                        M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                        M563 P0 S"Extruder" D0 H1 F0 ; define tool 0
                        ; Custom settings
                        M591 D0 C3 P2 E6.0
                        My homedelta
                        ; homedelta.g
                        ; called to home all towers on a delta printer
                        M400 ; make sure everything has stopped before we make changes
                        M915 P0:1:2 S2 F1 H400 R0
                        M574 X2 Y2 Z2 S3 ; set endstops to use motor stall
                        M913 X55 Y55 Z55 ; reduce motor current to 50% to prevent belts slipping
                        G91 ; relative positioning
                        G1 H1 X705 Y705 Z705 F4000 ; move all towers to the high end stopping at the endstops (first pass)
                        G1 H2 X-5 Y-5 Z-5 F7200 ; go down a few mm
                        G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
                        G1 Z-5 F7200 ; move down a few mm so that the nozzle can be centred
                        G90 ; absolute positioning
                        G1 X0 Y0 F7200 ; move X+Y to the centre
                        M400 ; make sure everything has stopped before we reset the motor currents
                        M913 X100 Y100 Z100 ; motor currents back to normal
                        G1 X0 Y0 F2000 ; centre the head and set a reasonable feed rate
                        What currently happens with this specific homedelta.g is the effector rams itself into the endstop position and returns two errors, target position not reachable from current position and insufficient axis homed.
                          Try this instead
                          M915 P0:1:2 S2 F0 H200 R0
                          G1 X-50 Y-50 Z-50 F7200 ; go down a few mm
                          • DomMilanundefined
                            DomMilan
                            Okay this one was odd.
                            Y and Z jumped down a good 50mm but then raised up about half that distance but is now lowering every time I run G28.
                            X just lowers to the same height that Y and Z end in one motion.
                              I may have removed too much from your original. I'm not very familiar with the delta homing.
                              try removing G1 X0 Y0 F7200 ; move X+Y to the centre
                              That should home all towers once and then move down 50mm and stop. What you do with it after that is up to you.
                              The important thing is that it sounds like it homed correctly.
                              • DomMilanundefined
                                DomMilan
                                Now it homes one axis every time I G28 but a different axis every time with a net downward movement still.
                                  Two things. First, I may have made an error by removing the H2 from the G1 command to lower the heads a bit. Second, we may be experiencing a limitation of RRF2 and stall detection homing.
                                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
                                  Ok I think we've encountered the limitation of RRF2 and stall detection. As soon as one endstop is triggered, movement stops for all axis.
                                  You would need to use RRF3 to use multiple motor stall detection (M574 S4). See the link.
                                  Snnn 1 = switch-type (eg microswitch) endstop input, 2 = Z probe (when used to home an axis other than Z), 3 = single motor load detection, 4 = multiple motor load detection (see Notes).
                                  However, updating to RRF3 would take some effort on it's own since the config.g would need to be recreated with the web configurator or manually updated.
                                  If you're not up to that, I think we could get around this limitation by homing each axis with an individual move. This gets a little tricky with a delta though because of the way the axis are linked. But if they started in a semi safe spot you should be able to home each tower individually.
                                  So first, try this.
                                  G1 H2 X-50 Y-50 Z-50 F7200 ; go down a few mm
                                  If that doesn't work, try this
                                  G1 H1 X705 F4000 ; move X tower
                                  G1 H1 Y705 F4000 ; move Y tower
                                  G1 H1 Z705 F4000 ; move Z tower
                                  Also before running those try and get the carriages to be more or less even.
                                  • DomMilanundefined
                                    DomMilan @Phaedrux
                                    @Phaedrux Thank you for all your help on this. I bought the endstop and its coming in a few days so no need to waste both our time on this. Sorry for the inconvenience.
                                      Awww I was eager to see if that last one would work.
