    Duet Pi Regression - How?
    Beta Firmware
    1.4k
      A Former User @Danal
      @Danal said in Duet Pi Regression - How?:
      I wonder how it gets installed? With no dependency?
      duetcontrolserver has it as a dependency iirc (thus the recursion)
      • Danalundefined
        Danal
        Ah, light bulb just came on. Thank you.
        • Danalundefined
          Danal
          And, by the way, autopurge (which I am NOT going to use) actually does not purge the recursive stuff after a
          sudo apt install duetsoftwareframework=1.2.3.0 duetcontrolserver=1.2.3.0 duetruntime=1.2.3.0 duetsd=1.0.5 duettools=1.2.3.0 duetwebserver=1.2.1.0 duetwebcontrol=2.0.4-1 reprapfirmware=1.2.3.0-1
          style install, and an apt remove duetsoftwareframework.
          So.... it would not have worked anyway.
          • gtj0undefined
            gtj0
            Just switch to RPM 😂
            A Former User? Danalundefined 2 Replies Last reply Reply Quote 1
              A Former User @gtj0
              @gtj0 said in Duet Pi Regression - How?:
              +2
              was wondering if aptitude* would be better suited, but decided to brush up on regex instead 😇
              *) not better than RPM..
              • Danalundefined
                Danal @gtj0
                How about //STEP1 EXEC PGM=SMPE? It handled prereqs, coreqs, and even postreqs flawlessly. Why, I've heard you could build and entire OS with it!
                  apt remove duet* reprapfirmware is about the same length and oddly more specific. would work with remove and purge for that matter.
                  • Danalundefined
                    Danal @A Former User
                    @bearer said in Duet Pi Regression - How?:
                    Yah, I thought about the nicely structured names. As you said though, if the package changes...
                      then it has a greater chance of catching it as duetruntime still doesn't depend on duetsoftwareframework.
                      and if apt remove duetcontrolserver duetruntime duetsd duetsoftwareframework duettools duetwebcontrol duetwebserver reprapfirmware is the alternative then it needs to be updated anyways.
                      to be honest I have more faith in a * than apt and dependencies defined for the packages should autoremove fail.
                      • Danalundefined
                        Danal
                        OK, here is a "first draft" that works. Comments welcome:
                        ./DuetRegress.sh 2.1.0
                        Currently Installed duetsoftwareframework=
                        Command line argument is requesting duetsoftwareframework=2.1.0
                        Which has associated reprapfirmware of 2.1.0-1 also known as 3.01-RC9
                        * Note: The next step will run for a while; the script is (probably) not hung.    *
                        To regress to DSF version 2.1.0 which is RRF version 3.01-RC9:
                        1) Backup your files via:
                          mkdir ~/duetback
                          cp -r /opt/dsf/sd/* ~/duetback
                        or similar. Verify that the backup worked: 'ls ~/duetback' should show directories: 'filaments firmware gcodes macros sys' or similar.
                        2) Run this command: (it is long, be sure you get it all on one line)
                          sudo apt -y  --allow-downgrades install duetsoftwareframework=2.1.0 duetcontrolserver=2.1.0 duetruntime=2.1.0 duetsd=1.0.6 duettools=2.1.0 duetwebcontrol=2.1.4 duetwebserver=2.1.0 reprapfirmware=2.1.0-1
                        3) Verify system is running properly, web interface opens, etc
                        4) If Pi runs, but won't connect to Duet Board, bossa the board
                           with the file found at /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin
                           Instructions here:
                           https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
                        5) Check files like config.g, macros, etc, and restore as required.
                        There are no name or other recursion dependencies in the script. Also, I took out the "apt remove" command, I don't believe it is required, apt will just overlay things.
                          A Former User
                          i opted for splitting the lines so it can be easy to read and copy, or if piped/backticked its not.
                          i'd also reconsider the -y bit gives apt a chance to complain if it feels the need.
                          pi@raspberrypi:~ $ bash rrfdep.sh 3.01-RC9
                          sudo apt install \
                            duetcontrolserver=2.1.0 \
                            duetsd=1.0.6 \
                            duettools=2.1.0 \
                            duetwebserver=2.1.0 \
                            duetwebcontrol=2.1.4 \
                            reprapfirmware=2.1.0-1 \
                          pi@raspberrypi:~ $
                          don't think i'll put up the version that resolves it from the reprap firmware version, smells like lots of unnecessary load on servers just to save people looking up a table
                          • Danalundefined
                            Danal
                            Excellent idea on the lines! I will do that. In fact, I was a bit concerned about line length... not only that, but I'm flattening a 'list' now, all I have to do is not do that.
                            I go back and forth on the -y. Given that this is intended to be used by people who literally can't even answer the initial "Do you want me to do what you asked? [Y/n]" prompt... well... I'm inclined to leave it in.
                            re: servers, yeah, this one is entirely local. In fact, it ought to insist on a recent (whatever that means) sudo apt update.
                            Danalundefined A Former User? 2 Replies Last reply Reply Quote 0
                            • Danalundefined
                              Danal @Danal
                              This post is deleted!
                                you don't get any questions if you have all the packages specified; the one you're missing is (likely) libunwind8 (if there are questions) no idea how that snuck into anything, but the rest holds true..
                                ref the bottom code block; no -Y and no question (also before libunwind8) https://forum.duet3d.com/post/150402
                                • Danalundefined
                                  Danal
                                  Direct copy from your code block; don't know why it is different on your machine and mine.
                                  P.S. Given the name "lib un-wind ate" I was trying to figure out if you were making a bad pun or someting... 😉
                                   sudo apt install \
                                  >   duetcontrolserver=1.2.3.0 \
                                  >   duetruntime=1.2.3.0 \
                                  >   duetsd=1.0.5 \
                                  >   duettools=1.2.3.0 \
                                  >   duetwebserver=1.2.1.0 \
                                  >   duetwebcontrol=2.0.4-1 \
                                  >   reprapfirmware=1.2.3.0-1 \
                                  Reading package lists... Done
                                  Building dependency tree
                                  Reading state information... Done
                                  The following packages will be DOWNGRADED:
                                    reprapfirmware
                                  0 upgraded, 0 newly installed, 8 downgraded, 0 to remove and 0 not upgraded.
                                  Need to get 32.2 MB/32.2 MB of archives.
                                  After this operation, 0 B of additional disk space will be used.
                                  W: Sources disagree on hashes for supposely identical version '1.2.3.0' of 'duetsoftwareframework:armhf'.
                                  W: Sources disagree on hashes for supposely identical version '1.0.5' of 'duetsd:armhf'.
                                  Do you want to continue? [Y/n]
                                  • Danalundefined
                                    Danal
                                    I suspect this message in your install (the other thread) explains the difference:
                                    The following NEW packages will be installed:
                                    as vs. my:
                                      reprapfirmware
                                    Of course, this could also be it:
                                      that goes away if you remove one of the two package feeds?
                                        to be honest I have no idea where it came from, but it did show up as a dependency and got autoremoved a few times. figured it was something new in the latest version, but seems to be gremlins..
                                        • Danalundefined
                                          Hmmm... I am removing /etc/apt/sources.list.d/duet3d.list (leaving duet3d-unstable.list) and then running sudo apt update
                                          However, I don't see how that would remove any entries that are already in the apt "database". We'll see in a few min, apt is updating a bunch of raspbian stuff.
                                          • Danalundefined
                                            Danal
                                            It DID eliminate the warnings.
                                            It still asks the Y/n question. I now believe it really is the "DOWNGRADED".
