Trouble saving a manually probed mesh
Can you try this for me?
Go to the system folder in DWC and delete any heightmap file that exists.
Then home the printer as usualy.
Then in the Gcode console send
M561
to clear any loaded bed transforms, then send G29 to generate a new heightmap. -
The error message indicates that you never created a heightmap, so it cannot be loaded. That makes sense if any of the permissions of the virtual SD card (at /opt/dsf/sd) were messed up. The safest way for you to get going with the latest RC again is by downloading and flashing the latest experimental DuetPi image which can be found here: https://pkg.duet3d.com/testing/ Save you sys files (you can ZIP them all at once) and flash the image file via Win32DiskImager or Etcher. Once there, please upgrade to the latest DSF version on the Pi via
sudo apt-get update sudo apt-get upgrade
Then restore your sys backup, reboot your system, run G29 without any arguments, and it should give you a heightmap file in 0:/sys. If it doesn't, post the output of G29 here.
Also post an M122 please.
@Phaedrux said in Trouble saving a manually probed mesh:
Then home the printer as usual.
M561
to clear any loaded bed transforms, then send G29 to generate a new heightmap.When I click on sys folder nothing happens other than the sys folder disappearing and the words above which did say "System Directory" to now saying "System Directory > sys" Clicking on system directory brings the sys folder back into view and just "System Directory" above.
I have ran M561 from dwc and got the confirmation that M561 was received. I then homed and ran G29 from the console in paneldue. G29 completed and I go to height map and this is what I get. -
So Now I'll do chrishamm's procedure.
Hate to ask but how would I post the output of G29?
A screen shot of the result?
Or if it successfully made a heightmap.csv post that?
Ok,thanks.
Ok so I've downloaded Image_2020-04-28-DuetPi. I wrote it to the sd card with Win32Disk. I followed chrishamm's instructions exactly. Uploaded my saved files with dwc. ran g28 and g29 from paneldue came back to the pc and clicked on Height Map and got this.
M122
4/29/2020, 4:20:51 PM M122
RepRapFirmware for Duet 3 MB6HC version 3.01-RC10 running on Duet 3 MB6HC v0.6 or 1.0
Board ID: 08DJM-956L2-G43S8-6JTDA-3SN6M-1V0LGUsed output buffers: 1 of 40 (28 max)
Static ram: 154572
Dynamic ram: 161960 of which 52 recycled
Exception stack ram used: 528
Never used ram: 76104
Tasks: NETWORK(ready,2076) HEAT(blocked,1184) CanReceiv(suspended,3824) CanSender(suspended,1424) CanClock(blocked,1432) TMC(blocked,72) MAIN(running,4468) IDLE(ready,80)
Owned mutexes:
Last reset 00:17:01 ago, cause: software
Last software reset at 2020-04-29 23:03, reason: User, spinning module LinuxInterface, available RAM 76368 bytes (slot 3)
Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 10
MCU temperature: min 45.7, current 45.9, max 46.0
Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
Driver 0: standstill, reads 32691, writes 0 timeouts 0, SG min/max not available
Driver 1: standstill, reads 32691, writes 0 timeouts 0, SG min/max not available
Driver 2: standstill, reads 32691, writes 0 timeouts 0, SG min/max not available
Driver 3: standstill, reads 32690, writes 0 timeouts 0, SG min/max not available
Driver 4: standstill, reads 32690, writes 0 timeouts 0, SG min/max not available
Driver 5: standstill, reads 32691, writes 0 timeouts 0, SG min/max not available
Date/time: 2020-04-29 23:20:49
Slowest loop: 3.62ms; fastest: 0.21ms
=== MainDDARing ===
Scheduled moves: 56, completed moves: 56, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Segments left: 0
Movement lock held by null
HTTP* is ready with "M122" in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon* is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.47ms; fastest: 0.01ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 0 of 8- Ethernet -
State: disabled
Error counts: 0 0 0 0 0
=== CAN ===
Messages sent 27, longest wait 0ms for type 0
=== Linux interface ===
State: 0, failed transfers: 0
Last transfer: 17ms ago
RX/TX seq numbers: 33066/33068
SPI underruns 0, overruns 0
Number of disconnects: 1
Buffer RX/TX: 0/0-0
=== Duet Control Server ===
Duet Control Server v2.1.2.0
Trigger:
Finishing macro config.g, started by systemNext stack level
Code buffer space: 4096
Full transfers per second: 33.04 - Ethernet -
And when you go to the /sys folder in DWC, is there a heightmap.csv file there?
I go to system and see all of my files but there is no sys folder this time, system directory is greyed out.
I've noticed that configurator says that I should be able to upload my files in zipped form but that does not work. I unzip the files and ctrl a all of the files and upload them all at once.
Thanks. Please hang on while we can take a look into this a bit more.
Ok making progress, up until now I have ran G29 from paneldue because this is a new printer and I want to be close by if something goes wrong I can do an e-stop. So just for grins I decided to do G29 from dwc and got this.
It's ugly but I don't care just glad to see an image. Looks like there may be a bug in the paneldue interface or something.
Thanks for your help.
