Help with HTTP Error 500 on Duet 3D
@Jim46 said in Help with HTTP Error 500 on Duet 3D:
Remove the ERASE jumper, load Bossa and select the correct COM port. It should identify the device as ATSAM70x20. This didn't occur. the Duet looks like this. the small light next to the microSD card holder is only very dim
It's normal for the DIAG LED to be very dim when the board isn't running any firmware. So the BOSSA port should be available. If your PC runs Windows, look in Device Manager under "Ports - COM and LPT". If it's not there, you may need to try a different USB cable, or a different USB port on your PC. You may also need to install the Windows device driver from https://github.com/dc42/RepRapFirmware/releases/tag/3.01-RC9 (download DuetDriverFiles.zip into a temporary folder on your PC, then double click in the .inf file).
Gentlemen,
Thanks so much for your latest comments.
I've checked my router network map and don't see reference to the Duet.
I've tried YAT and it doesn't see COM3 the BOSSA port.
Unable to open DWC as it seems to do so using an IP address which I don't have for the Duet.
Here are screen that I hope are useful...
It seems the BOSSA 1.9.1 isn't in good shape as it is crunched up on the lower part of the screen. And, the Serial Port drop down is blank.
The Device Manager currently on my PC shows the COM3 but the drop down says the device is not connected to the computer. Assuming this is the Duet, the CAT5 cable is connected from the Duet to the router and the best USB cable I have is connected to the PC in a slot i rarely use.
BTW, I was i supposed to get a 3' USB cable with my Duet3D 6HC order? I only seem to have two 12" cables.
Lastly, YAT says none of the COM ports are avaiable. I type in COM3 with the same result.
I am rather lost here and appreciate your help.
J -
You're trying to solve 4 different problems in no coherent way and its really hard to follow the flow in what you're doing.
IF you connect the board to the computer and it shows up as BOSSA in device manager you only need to focus on the BOSSA flashing software (forget YAT and browsers).
Then the issue becomes, why is bossa not detecting the CPU when started.
Oddly enough your inherent all over the place approach may add some hints - if YAT is unable to open COM3 the problem is like in Windows. The file (com ports are files at the end of the day) could be open in another process, or windows could have double booked the handle COM3 preventing you from using it.
Do you have any other software running that might be trying to access a serial port? (only one software can access any one serial port at any given time)
edit -
Looks like the Bossa port is showing in Device Manager but the connection isn't reliable. Try again with a different USB cable. Note, Bossa only scans the USB ports when it starts up, and when you click Refresh, so you may have to click Refresh to make the port appear.
Potential progress
When plugging my USB3 cable into PC and Duet, a Windows message pops up saying it doesn't recognize the device...anyway something like that. Ordering a new USB3 cable tonight just in case.
BOSSA didn't pop up when the Duet was connected to the PC in every UBS plug, so I launched it directly. Finally got COM3 port to show up.
What do I do next?
You'll need this bin file: https://github.com/dc42/RepRapFirmware/releases/download/3.01-RC10/Duet3Firmware_MB6HC.bin
After downloading it, verify that it is 553 KB in size.
Select the file in bossa.
Check boxes Erase all, Lock, and Boot from Flash
When the write completes, press Verify
Let's start with that.
Then on your SD card, you'll need to have the DWC 2.1.5 files in the /www folder from here: https://github.com/dc42/RepRapFirmware/releases/download/3.01-RC10/DuetWebControl-SD-2.1.5.zip
While you're at it, download this file and place it in the /sys folder of the SD card: https://github.com/dc42/RepRapFirmware/releases/download/3.01-RC10/Duet3_SDiap_MB6HC.bin
The BOSSA program is not made to start automatically when connecting the Duet, you will have to launch it yourself every time it is needed (hopefully just this once)
@Phaedrux
The 3.01-RC10/Duet3Firmware_MB6HC was successfully downloaded and remains in the download file. It is 553.3 KB.
The next step of trying to check boxes allowed the Erase All, Lock and Boot TO Flash. When clicking Write, it produces this error...
So, what does it mean SAM-BA operation failed? BTW, the formatted microSD card is in the Duet3.
Thanks again,
Jim -
can't say for sure, try again and while you do that I'll type some more.
edit:
to find more information we need to run the command line version and enable debug output (if trying again didn't work)find "Command Prompt" on your start menu and run it (search for cmd if you can't find it)
it opens a new black window with a prompt.
copy this into it:
"%programfiles(x86)%\BOSSA\bossac" --port=COM3 -d -e -w -v -b Downloads\Duet3Firmware_MB6HC.bin -R
It can mean that the port was present when you loaded Bossa, then it disappeared. It may have come back, but unfortunately Bossa won't reconnect to it automatically. Click Refresh and then select the COM port again in the Serial Port box.
I ran the CMG with the code you gave me. It says no device found on COM3, yet the BOSSA says it connected and recogonizes the chip.
What nextif you try both at the same time, then that would be the reason, cannot access COM3 form two applications at the same time.
First do as dc42 suggested, click refresh in the graphical BOSSA to re-identify the Duet. Then click write.
If it fails again close the graphical BOSSA window and retry the command please.
(hmm, the error message is a bit ambiguous as it points to the problem being the target, I'll file an issue with the BOSSA developer to help make it clearer as I tested you get a different (more) output if the port is free but has no target)
Hey Bearer,
I've shut down BOSSA as it would just sit there after the write command.
Its probably a good idea to share the experience with the BOSSA developer. I''ve ordered new USB 3.0 microUSB cables and should have them on Monday to hopefully remove the current cable as being a potential problem.
It would be a good idea also to let them see the BOSSA screen as I saw it on 29 Apr 2020, 18:32 ...Potential progress... as the screen is all crunched up on the bottom and you can't see the check boxes. I'm running an HP Pavillion Elite e9220y (with Windows 10) APCI x64 based PC with AMD Phenom II x4 910 Processors (4). -
Just ran the BOSSA screen again with the boxes checked, I launched it. and it came back with the Error File Operation Exceeds Flash size.
de ja vous?
https://forum.duet3d.com/post/142914can you find that USB cable and try it again?
Bearer,
I've lost your message,
J -
Motor wiring verified with paperclip test
G92 X0 Y0 Z0 performed
Motors do not turn
They do spin freely when turned by hand; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 04 2020 10:26:28 GMT-0600 (Mountain Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M584 X0.0 Y0.1 Z0.2 ; set drive mapping M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation M92 X53.33 Y53.33 Z53.33 ; set steps per mm M566 X900.00 Y900.00 Z12.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X1000 Y1000 Z1000 S0 ; set axis maxima ; Endstops ; WARNING: No endstops configured ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X0:1000 Y0:1000 S20 ; define mesh grid ; Heaters ; Fans ; Tools ; Custom settings are not defined
