    Error on Thermistors
    2.1k
      What hardware revision Duet is it?
      weputundefined 1 Reply Last reply Reply Quote 0
      • weputundefined
        weput @dc42
        @dc42 said in Error on Thermistors:
        This is one of those preorders boards... (numbered 138) preorder group 2.
        so i assume hardware ver1.0
          dc42 administrators @weput
          @weput said in Error on Thermistors:
          Thanks. See https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_VSSA_fuse.
          • weputundefined
            weput @dc42
            @dc42 Thank you.
            I've seen that... unfortunately with this covid-19 lockdown i assume i'll have to install and run on 8 bits for a while.
              In the UK at least, the major component distributors are still shipping components. What country are you in?
              • weputundefined
                weput @dc42
                Panama.
                  If you have a resistor with a value in the range 2 to 10 ohms, you could temporarily connect that between VSSA and ground instead of the fuse. Space it well off the board, because it will burn up if you get a short between VSSA and VIN - which may be what caused the VSSA fuse to blow.
                  • clearlynotstefundefined
                    clearlynotstef
                    Personally I used a tube fuse and little holder thing, but you could even solder directly to the fuse if you could get one of them. There's gotta be someplace still selling standard fuses online near you
                    https://www.amazon.com/dp/B00X7B6FPI/ref=cm_sw_r_em_apa_i_TyFIEb1C2DN29
                    https://www.amazon.com/dp/B00VLBAF84/ref=cm_sw_r_em_apa_i_bFFIEbQQWNZKN
                    • weputundefined
                      weput
                      ok guys...
                      we are still in lock down so no luck to getting the fuse or the resistors...
                      (im fine as i have another printer running...)
                      Anyways, I'm thinking on breaking one of those x-mast decoration light cords (the ones that comes with like 150 small bulbs wired in series) to use one incandescent bulb... its a low resistive lineal load and if something happens it should manage the power by emitting light...
                      .,.. then i recalled i have a few small led's laying around... technically the same principle with the 0.7v drop.... anyways,
                      here im asking.. what do you think?
                        A Former User
                        is there not a gas station or anything like that you can get a fuse from? (they might not have very small values though, but might for motor cycles)
                        • weputundefined
                          weput @A Former User
                          @bearer said in Error on Thermistors:
                          the smaller they had was 10 amps... the fuse should be rated for 100mA... max 200
                          way too much current.
                          • weputundefined
                            weput
                            Just to let you know guys (assuming you care)
                            i pull out a potenciometer from my electric guitar... so the printer is going to be running soon.
                              ok guys...
                              The incandescent bulb should work.
                              • weputundefined
                                weput @dc42
                                @dc42 (y)
                                • weputundefined
                                  weput
                                  funny...
                                  i was about to place the fuse... but because i had to remove the cables i had fro the potensiometer...
                                  ... checked the continuity and happens that the original fuse has continuity.
                                  • weputundefined
                                    weput
                                    stupid question...
                                    what is the actual resistance i should measure between vssa and gnd?
                                    the thermistors are oscilating way too much...
                                      A Former User @weput
                                      @weput pretty much 0, single digit omhs at most.
                                      • weputundefined
                                        weput
                                        my small ohmmeter is a cheap old analog type...10ohm and 1k selector...
                                        resistance was 8~9 ohms if this is ok.
                                        I'm leaning towards to replace the fuse.
                                          8~9 ohm
                                          datasheet for the replacement part suggest 0.6 to 2.5 ohm, but early boards could use a different part.
                                          do you get a 0 reading if you touch the probes together?
                                          • weputundefined
                                            weput
                                            touch
                                            let me check...
                                            do you want me to measure the resistance on the thermistor connection?
