    Release 3.01-RC10
    2.8k
    • Leblondundefined
      Leblond @dc42
      hello dc42 Thank you for your intervention
      the update sequence was:
      1. Update of FW 3.01-RC10
      2. DWC update directly from the .zip file
      The nozzle is selected and active: ok
      FW 3.01-RC10 loaded: ok
      DWC 2.1.5 loaded: ok
      The temperature is 220: ok
      I created a macro for ease of use to clean the nozzle:
      G1 X0 Y0
      M104 S220 T0
      M109 S220 T0
      G1 E30 F200
      I bring the temperature to 220, the macro is active, the head moves to the chosen coordinates, but it does not extrude and it is still, I manually try to extrude, but nothing happens and it does not give me any errors whatsoever
      I am attaching photos for viewing:
      • Leblondundefined
        Leblond @dc42
          Thanks. So the manual extrusion buttons in DWC are not greyed out, but pressing them does nothing. Is that correct?
          Which firmware version were you using before, when extrusion was working?
          Please send the following commands from the console, and check that the E values reported in the responses are expected:
          M92
          M906
          M913
          M563 P0
          Also please confirm that the hot end heatsink fan is running, and that you can push filament through the hot end by hand to make sure that you don't have a filament jam.
            droftarts administrators @Leblond
            @Leblond Does the extruder position change? Here:
            Leblondundefined 2 Replies Last reply Reply Quote 0
            • Leblondundefined
              Leblond @droftarts
              @droftarts guys I will make the checks tonight after work and keep you informed, I realized that the E0 motor is struggling to turn Responding to @droftarts it is at 0.0 but once I try to extrude 10mm the motor vibrates but does not move, but on extruder driver it marks me from 0 to 10mm, tonight i try to clean the nozzle and i will tell you everything
              • Leblondundefined
                Leblond @droftarts
                @droftarts good morning everyone, after several tests I found out that the nozzle was blocked, what stole me was the engine that did not jump but remained motionless, however I had to replace the nozzle and clean the heat breack, therefore solved, thanks to everyone for the commitment, there is always something to learn here.
                • Leblondundefined
                  Leblond
                  the cases are two at the origin to the problem of the blocking of the extrusures "correct me if I'm wrong !!", 1: when the trigger is wrong, that is too attached to the plate and does not extrude, by force of give and give yes the filament is compact and freezes, 2: filament dirty or low temperature, but the problem encountered by me is strange perhaps it has something to do with it
                  the motor voltage? it is set to 800 but, and in any case it should jump, make the usual "tac tac ..." noise which has not happened to me and which has caused a waste of time for me and for you, I was wondering if there was a way via SW to check if an engine actually runs or not, type ammeter?
                  • chrishammundefined
                    chrishamm administrators @Leblond
                    @Leblond Yes, there is a way to detect motor stalls. See https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing#main
                    Duet software engineer
                    Leblondundefined 1 Reply Last reply Reply Quote 0
                    • Leblondundefined
                      Leblond @chrishamm
                      @chrishamm ok thanks, I print it and I care about it
                      • Leblondundefined
                        Leblond
                        Good morning and good May 1st
                        Well I have a problem that repeats itself every time I homing, then I thought the last problem had been the fault of the nozzle blocked by the filament, in part yes, it blocked because the extruder motor stops, now I understood the reason, the tests I did are all without filament in order not to damage the nozzle, I describe what I did:
                        1: I set the temperature to 180 in order to have the extrusion and retraction buttons active the drive buttons work very well and the motor responds
                        2: if I homing all the axes and retry the procedure n.1 the extruder no longer works
                        3: I did the single homing of the axes
                        4: homing x axis and retrying the extruder and it works
                        5: homing y axis and retrying the extruder and it works
                        6: z axis homing and try again the extruder does not work
                        I tried to load the fw one by one starting from 3.0 until the last beta and the problem persists,
                        7: I removed the sd and reformatted and loaded the fw but nothing happens
                        Any suggestions on this?
                        for @ dc42
                        m92
                        Steps / mm: X: 80.000, Y: 80.000, Z: 400.000, E: 424.000
                        M906
                        Motor current (mA) - X: 800, Y: 800, Z: 800, E: 800, idle factor 30%
                        M913
                        Motor current% of normal - X: 100, Y: 100, Z: 100, E: 0
                        m563 p0
                        Tool 0 - drives: 0; heaters (active / standby temps): 1 (180.0 / 0.0); xmap: X; ymap: Y; fans: 0; status: selected
                        • Leblondundefined
                          Leblond
                          to restart the engine I have to reset with the command M999
                            dc42 administrators @Leblond
                            @Leblond said in Release 3.01-RC10:
                            Please post your homez.g file.
                            • Leblondundefined
                              Leblond @dc42
                              ; homez.g
                              ; called to home the Z axis
                              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 23 2020 22:39:29 GMT+0200 (Ora legale dell’Europa centrale)
                              G91 ; relative positioning
                              G90 ; absolute positioning
                              G1 X60 Y50 F6000 ; go to first probe point
                              ;G91 ; relative positioning
                              ;G1 Z10 F100 ; lift Z relative to current position
                              ;G90 ; absolute positioning
                              • Leblondundefined
                                Leblond
                                now I have mounted the fw 2.05 to see if even with this it does the same problem
                                  Is the tool still selected when you have this problem? Send T by itself to report the current tool number.
                                  Leblondundefined 3 Replies Last reply Reply Quote 0
                                  • Leblondundefined
                                    Leblond @dc42
                                    @dc42 ok I reassemble the FW and then I tell you
                                    • Leblondundefined
                                      Leblond @dc42
                                      @dc42 made reloaded FW 3.01-RC10
                                      yes the tool is always active
                                      1/5/2020, 14:51:33 T
                                      Tool 0 is selected
                                      • Leblondundefined
                                        Leblond @dc42
                                        @dc42 I compress all the sd and send it to you?
                                        • Leblondundefined
                                          Leblond
                                          it still does not work
                                          • Leblondundefined
                                            Leblond
                                            the engine practically vibrates as if it were stalled
