    PanelDue no longer connecting on Duet3/io0 with 3.01-RC11
    Beta Firmware
    1.7k
      A Former User
      The Arduino would have to send M408 S0 or S1 depending on how much of the data it needs to update to work independent of the PanelDue.
      Nuramoriundefined gtj0undefined 2 Replies Last reply Reply Quote 0
      • Nuramoriundefined
        Nuramori @A Former User
        @bearer said in PanelDue no longer connecting on Duet3/io0 with 3.01-RC11:
        The arduino code is basically sniffing and parsing the JSON package for the time to complete, the bed temp, and the extruder(s) temps. That info is then graphically represented via driven neopixel rings.
        • gtj0undefined
          gtj0 @A Former User
          @bearer Maybe if you jumper io0.in to io1.in both ports will get the paneldue commands.
          • Nuramoriundefined
            Nuramori
            The ultimate goal maybe/would be to negate the arduino entirely and use the Pi4 to drive the neopixels. I am digesting the way that could be done by using the API to pull the same info that is used in the JSON package to the Paneldue.
            • gtj0undefined
              gtj0 @Nuramori
              @Nuramori There's a command /opt/dsf/bin/ModelObserver that spits out json as its updated by the Duet. All you have to do is keep reading that.
                A Former User @gtj0
                @gtj0 said in PanelDue no longer connecting on Duet3/io0 with 3.01-RC11:
                probably, but i think thats what Nuramori was suggesting?
                @Nuramori said in PanelDue no longer connecting on Duet3/io0 with 3.01-RC11:
                yeah, you could just send M408 with different S paramters in DWC to see which one returns all you need and have the arduino send that string at regular intervals and keep the parsing code as is.
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M408_Report_JSON_style_response
                The Pi route may be easier, if not maybe less reliable until the DSF stuff matures.
                  A Former User @gtj0
                  btw
                  Oh, one other thing, io1.out can also be configured as a uart so you may want to use that for the Arduino.
                  @gtj0 said in RRF 3.01-RC11 DSF mode: io_1 not outputting "ok" consistently:
                  Marlin mode and raw mode on io_1...
                  M555 P2
                  M575 P1 B115200 S2
                  was wondering if the typo was io_1 or P1, should be P2? (never mind, saw P2 a bit further up here)
                  • gtj0undefined
                    gtj0 @A Former User
                    @bearer Unfortunately it looks like the uart on io1 is disabled in firmware. So P0 is the USB port, P1 is io0 and P2 returns Error: M575: parameter 'P' too high
                    Maybe @dc42 can enable it in a future release.
                    • Nuramoriundefined
                      Nuramori
                      I'm always up to trying anything; out of pure curiosity, I am interested in what changed that would prevent both devices from sharing the data on io0.out, when it worked prior to RC11, without any hardware changes.
                      • gtj0undefined
                        gtj0 @Nuramori
                        I'm guessing there was a drive strength change or something. I can't get to the source code right now but I can check tomorrow if @dc42 hasn't answered by then.
                        Nuramoriundefined 1 Reply Last reply Reply Quote 0
                        • Nuramoriundefined
                          Nuramori @gtj0
                          Interesting. I wasn't aware that something like that was controllable through software. Thanks for the help @gtj0 .
                          • gtj0undefined
                            gtj0 @Nuramori
                            Yeah on most "microcontroller" platforms, including the ones on the Duets, Pis and other SBCs, many pins are general purpose and have their function (uart, GPIO, SPI, etc) and capabilities (input, output, both, drive strength, pull up/pull down, tristate, etc) controlled from software.
                              A Former User
                              couldn't spot any changes to low level functions, just some conditional logic around the higher level initilization.
                              https://github.com/dc42/RepRapFirmware/commit/6f912e9ca47930d7b91d504c0e9c8be31251284a#diff-52cb419324e9c23a2e2c5a269e0e70fcR3581
                              0 dc42 committed to dc42/RepRapFirmware
                              Various changes for 3.01-RC11
                              Tool change files are now run even if axes have not been homed
                              PanelDue replies are now sent immediately instead of being saved for
                              retrieval by M408
                              Added aux raw mode
                              On Duet 3, IO_0 is not configured in serial mode until M575 P1 is
                              executed
                              GCodeException class now stores a small string to allow more meaningful
                              error messages
                              • Nuramoriundefined
                                Nuramori
                                Could it be this?
                                setPullup(APIN_Serial0_RXD, true);
                                I didn’t see anywhere else where the pull-up resistor is used/set in the old code, could the setting the pull-up affect the signal enough that it “dies” enough in signal strength for two electrical connections to be too much for the paneldue circuitry?
                                  A Former User
                                  click the beginning of the line and choose "git blame" to see when it was changed. (if viewed on github, otherwise git cli works as well)
                                  i'm guessing its part of the other repositories then
                                  • gtj0undefined
                                    gtj0 @Nuramori
                                    Could it be this?
                                    Absolutely!
                                    I just did a build without the pullup. See this helps...
                                    http://dueui.org/download/Duet3Firmware_MB6HC.bin
                                    • gtj0undefined
                                      gtj0 @A Former User
                                      @bearer It was new in the last 2 commits.
                                        A Former User
                                        (for CoreNG, ofc, my bad)
                                        • Nuramoriundefined
                                          Nuramori @gtj0
                                          @gtj0 I downloaded the file, pushed it to the printer, and performed a "M997 S0"
                                          Result was :
                                          Error: Operation failed (Reason: ArgumentNullException in SimpleCode: Value cannot be null. (Parameter 'input'))
                                            A Former User
                                            But without the pull up? Comment said it was removed pending a M575, so the fix would be to enable it upon finding a M575 P1 command?
