Redefining WiFi
I had to reinstall my WiFi in my home today and was not able to use my existing SSID because the newer firmware required more than the 2 characters I was using. Now I need to reset my Duet WiFi network connect but I’ve been unable to find the proper instructions. Can someone point me in the right direction?
@mperdue said in Redefining WiFi:
sure about that?
In any case, look up M587
@bearer said in Redefining WiFi:
sure about that?
Newer firmware in my WiFi router, not the duet. -
I finally had an opportunity to correct this problem. It took a couple of attempts but the first printer is back on the network and working fine. The other one will be reconnected later today. Thanks for pointing me in the right direction.
