    E3D SuperVolcano on SmartEffector?
    Smart effector for delta printers
    1.4k
      If your Smart Effector PCB revision is 1.3 then you should definitely add wires between the connectors to bypass the traces. If it's revision 2.0 then it may well be OK without, but add the wires if you wish. The worst that should happen if you don't is that one of the traces will fuse, at which point you can bypass them with wires.
      If you do add wires then they will need to go over the edge of the effector in order to get from one side to the other. So make sure they are protected in case that edge can bump into anything.
      Nxt-1undefined 2 Replies Last reply Reply Quote 0
      • Nxt-1undefined
        Nxt-1 @dc42
        @dc42 I am planning on ordering from E3D in the comming weeks, I will ask them what version they are sending out.
        Duet3D and delta printer enthousiast. Buildlog
        Looking for Duet3D configuration support, check out Nxt-3D
        • Nxt-1undefined
          Nxt-1
          I know I am digging up an old thread here but I wanted to let anyone that happens to stroll by know that I have successfully printed with the Supervolcano + Smarteffector combo.
          I did have to reduce probing speed and increase wait time after each move. The values in here are most likely to conservative, but they do the job for me: M558 P8 F800 H7 R1 T10000 A10 S0.04
          I plan to do a large-ish job this evening -6hr printing and I will report back when I have time with the results.
          Nxt-1undefined 1 Reply Last reply Reply Quote 1
            Thanks for the feedback!
            • Nxt-1undefined
              Nxt-1 @Nxt-1
              @Nxt-1 said in E3D SuperVolcano on SmartEffector?:
              I lowered the waiting parameter R to something like 0.5s and that seems to work fine. I also had to lower my acceleration/jerk parameters to account for the increased mass of the effector and longer moment arm under the effector.
              I completed the 6hr print without major issues and also did a 28hr (2kg) print this weekend without SmartEffector problems. It would have been interesting but I did not perform any measurements and even just feel the temperature of the relevant heater traces on the effector.
              • clearlynotstefundefined
                clearlynotstef
                Thanks for coming back to update us with your experience, I'm on the fence about trying this as well. I am on 12v currently, anyone know if that changes the recommendation on smart effector? I could always just run the heater wire down directly to the hotend and bypass the effector entirely if necessary, it would just be a bummer because I have swappable effectors between a v6 and volcano currently, so when using the v6 effector, there would be an extra wire dangling there I guess, unless I bypass it for both effectors... hmm
                Nxt-1undefined 1 Reply Last reply Reply Quote 0
                • bbergerundefined
                  bberger
                  Oh boy, I would love to see a video or even just a picture of that thing 🙀
                  • Nxt-1undefined
                    Nxt-1 @clearlynotstef
                    @clearlynotstef said in E3D SuperVolcano on SmartEffector?:
                    While I did not test this myself, I would advise against running the 12V heater current trough the smart effector pcb. This would mean running 6.66A trough the traces in the pcb.
                    @bberger said in E3D SuperVolcano on SmartEffector?:
                    I currently have a regular V6 mounted, but I have all the materials I need to mount the SuperVolcano on a 2nd smart effector for easier swapping. Once the pandemic has settled down I will have access to the machines I need to get the mounting the way I want is and will post pictures here.
                    • Nxt-1undefined
                      Nxt-1 @bberger
                      I will see what I can do to post a video of the machine printing with it in the coming days.
                        If you use 12V then the heater wires should bypass the Smaty Effector completely. The 6-pin connector and 2-pin terminal block are not rated for 6.66A.
                        If you use 24V then you can use the connectors on the Smart Effector, but I recommend that you bypass the heater traces and vias on it using two short pieces of wire that connect the terminal block spills to the 6-pin connector spills. They will have to go around the edge of the Smart Effector, so you may need to protect them if there is anything on your machine that the effector can bump into.
                        • Nxt-1undefined
                          Nxt-1 @dc42
                          @dc42 said in E3D SuperVolcano on SmartEffector?:
                          Is there anything that made you more cautious since you said this in the beginning if this thread?
                            dc42 administrators @Nxt-1
                            Not really. If your effector is version 1.3 2.0 and you are using 24V then the PCB traces should be adequate.
                            • Nxt-1undefined
                              Nxt-1 @dc42
                              @dc42 Both my smart effectors are rev 2 and I am indeed running 24V
                              • Nxt-1undefined
                                Nxt-1 @bberger
                                @bberger Here we go, a video of my Deltex V1 in full action. Youtube
