    RRF 3.01-RC11, DWC 2.1.6 and DSF 2.1.3 released
    Beta Firmware
    910
    • garyd9undefined
      garyd9
      Duet 3 users: Connector IO_0 is no longer dedicated to PanelDue, therefore if you connect a PanelDue to this port you must use the following command in config.g to enable it: M575 P1 S1 B57600
      Does that imply that only 57600 will work with the paneldue and duet3?
      dc42undefined gtj0undefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @garyd9
        @garyd9 said in RRF 3.01-RC11, DWC 2.1.6 and DSF 2.1.3 released:
        No, you can use other baud rates too.
        • gtj0undefined
          gtj0 @garyd9
          Confirmed: It works fine on the Duet3 at 115200.
          • gtj0undefined
            gtj0
            DCS 2.1.3: M500 writes invalid G10 command to config-override.g
            https://github.com/chrishamm/DuetSoftwareFramework/issues/130
            gtjoseph created this issue in chrishamm/DuetSoftwareFramework
            closed DCS 2.1.3: M500 writes invalid G10 command to config-override.g #130
            • mwolterundefined
              mwolter
              M117 does not allow conditional gcode statements to be inserted into a string.
              https://forum.duet3d.com/topic/16036/rrf-3-01-rc10-bug-m117-and-conditional-gcode-statements
                dc42 administrators @mwolter
                I've put new RRF binaries at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0 to fix the following:
                • Changing baud rate for the PanelDue port didn't work unless the M575 command was repeated. Note that in this version, the M575 command is mandatory when using a PanelDue, even on the Duet WiFi, Ethernet and Maestro.
                • Virtual extruder position was missing from the object model
                • HTTP requests for files with very long names reported a "Filename too long" error and didn't return a response. They now return a 404 response and issue a warning of a possible virus attack from the sending IP address.
                On the Duet WiFi, Ethernet and Maestro it shojud now be possible to use the two I/O pins of the PanelDue port as GPIO, if there is no M575 p1 command in config.g.
                A Former User? botundefined 2 Replies Last reply Reply Quote 0
                  A Former User @dc42
                  @dc42 said in RRF 3.01-RC11, DWC 2.1.6 and DSF 2.1.3 released:
                  temporary or something that will be part of 3.01?
                    @bearer said in RRF 3.01-RC11, DWC 2.1.6 and DSF 2.1.3 released:
                    All of these changes will be included in 3.01 stable.
                    • ChrisPundefined
                      ChrisP
                      The "iterations" meta command variable isn't handled correctly when using a D3+SBC setup. This was discovered when attempting to use the example object identification macro posted here. The code example there works as intended when the D3 is used in standalone mode, but returns an error in a D3+SBC setup.
                      • ChrisPundefined
                        ChrisP
                        The identification of objects by parsing the object label comments (PrusaSlicer) and process comments (Simplify3D) for object cancellation features etc. currently works on a D3 in standalone mode but fails if using a D3+SBC setup. Noted here, but first identified here.
                        • gtj0undefined
                          gtj0 @ChrisP
                          @ChrisP said in RRF 3.01-RC11, DWC 2.1.6 and DSF 2.1.3 released:
                          The "iterations" meta command variable isn't handled correctly when using a D3+SBC setup. This was discovered when attempting to use the example object identification macro posted here. The code example there works as intended when the D3 is used in standalone mode, but an error if the a D3+SBC setup.
                          These will get better attention if you open issues for @chrishamm on GitHub if you can.
                          • botundefined
                            bot @dc42
                            Wat?
                            *not actually a robot
                              dc42 administrators @bot
                              @bot said in RRF 3.01-RC11, DWC 2.1.6 and DSF 2.1.3 released:
                              Wat?
                              See https://forum.duet3d.com/topic/15346/duetwifi-error-filename-too-long.
                              • ChrisPundefined
                                ChrisP
                                Perhaps one for @chrishamm ....
                                I had previously reported here that a pause caused by the filament sensor resulted in the printer just halting this was with D3+SBC setup. On trying again in standalone, the pause works as expected and can be resumed. Therefore a DCS issue?
                                  dc42 administrators @ChrisP
                                  I believe that issue is already on his list to look into.
