    RRF 3.01-RC11, DWC 2.1.6 and DSF 2.1.3 released
    Beta Firmware
    910
      dc42 administrators @mwolter
      I've put new RRF binaries at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0 to fix the following:
      • Changing baud rate for the PanelDue port didn't work unless the M575 command was repeated. Note that in this version, the M575 command is mandatory when using a PanelDue, even on the Duet WiFi, Ethernet and Maestro.
      • Virtual extruder position was missing from the object model
      • HTTP requests for files with very long names reported a "Filename too long" error and didn't return a response. They now return a 404 response and issue a warning of a possible virus attack from the sending IP address.
      On the Duet WiFi, Ethernet and Maestro it shojud now be possible to use the two I/O pins of the PanelDue port as GPIO, if there is no M575 p1 command in config.g.
      A Former User? botundefined 2 Replies Last reply Reply Quote 0
        A Former User @dc42
        @dc42 said in RRF 3.01-RC11, DWC 2.1.6 and DSF 2.1.3 released:
        temporary or something that will be part of 3.01?
          @bearer said in RRF 3.01-RC11, DWC 2.1.6 and DSF 2.1.3 released:
          All of these changes will be included in 3.01 stable.
          • ChrisPundefined
            ChrisP
            The "iterations" meta command variable isn't handled correctly when using a D3+SBC setup. This was discovered when attempting to use the example object identification macro posted here. The code example there works as intended when the D3 is used in standalone mode, but returns an error in a D3+SBC setup.
            • ChrisPundefined
              ChrisP
              The identification of objects by parsing the object label comments (PrusaSlicer) and process comments (Simplify3D) for object cancellation features etc. currently works on a D3 in standalone mode but fails if using a D3+SBC setup. Noted here, but first identified here.
              • gtj0undefined
                gtj0 @ChrisP
                @ChrisP said in RRF 3.01-RC11, DWC 2.1.6 and DSF 2.1.3 released:
                The "iterations" meta command variable isn't handled correctly when using a D3+SBC setup. This was discovered when attempting to use the example object identification macro posted here. The code example there works as intended when the D3 is used in standalone mode, but an error if the a D3+SBC setup.
                These will get better attention if you open issues for @chrishamm on GitHub if you can.
                • botundefined
                  bot @dc42
                  Wat?
                  *not actually a robot
                    dc42 administrators @bot
                    @bot said in RRF 3.01-RC11, DWC 2.1.6 and DSF 2.1.3 released:
                    Wat?
                    See https://forum.duet3d.com/topic/15346/duetwifi-error-filename-too-long.
                    • ChrisPundefined
                      ChrisP
                      Perhaps one for @chrishamm ....
                      I had previously reported here that a pause caused by the filament sensor resulted in the printer just halting this was with D3+SBC setup. On trying again in standalone, the pause works as expected and can be resumed. Therefore a DCS issue?
                        dc42 administrators @ChrisP
                        I believe that issue is already on his list to look into.
