    Notification in Telegram
    12
    1.1k
    • juanmenaundefined
      juanmena
      First of all thank you always answer all the questions and always give an answer, and good work.
      Some time ago, we talked about notifying on Telegram the status or completion of an impression (a job), but I do not see that it has been implemented, which is strange, since other applications apparently not so advanced, if they offer that possibility.
      Is there already in Duet?
      Thank you.
      • DocTruckerundefined
        DocTrucker
        What do you mean by telegram? Link to the original thread?
        I'd suggest priority is low because with the high accuracy of the print time simulation it isn't really needed.
        Alternatives include using DWC to check the status either from the local network or through using VPN to get onto your network.
        • juanmenaundefined
          juanmena
          I mean, it would be very good, to get a warning to Telegram or something similar, when the printing is finished, to the mobile.
            How bout this?
            https://forum.duet3d.com/topic/7745/duet-telegram-bot
            • juanmenaundefined
              juanmena
              A pity to have to have a Raspberry and that is not directly in the Duet
                See also https://forum.duet3d.com/topic/9626/new-m-code-to-send-a-network-request.
                Does Telegram use MQTT, HTTP, or some other protocol?
                  A Former User
                  Some other protocol https://core.telegram.org/mtproto
                  (But the Bot API is https)
                  • hectorundefined
                    hector
                    From the Spanish telegram community of Duet we are making an integration with Nodered, to have bot, timelapse, dashboard for various duet machines ...
                    soon we will have an image for raspberry to release preconfigured, with which anyone can continue to customize 😜
                    mqtt bridge include in this option, read data from duet api, use in flow and inject to mqtt server, o in the include server in the pi
                    Leds control is macro call in the duet board, and the macro set the pwm in pin in expansion port, and read with small arduino or wemos, and change the effect.
                    is possible set effect for heating, error, printing, homing, finish etc...
                    IdefixRCundefined andymidtfundefined madeinta1wanundefined 3 Replies Last reply Reply Quote 1
                    • IdefixRCundefined
                      IdefixRC @hector
                      @hector Ohhhhhh man.....finally 🙂 been waiting for this for a long time (first raised a request for some sort of notification back in 2017.
                      Please let me know once the image is available. I have a Pi Zero connected to the duet already and use it as webcam so it should be a quick install (hopefully) ✌
                      • andymidtfundefined
                        andymidtf @hector
                        @hector que tal va eso? Algún avance?
                        How is this going? Any news?
                        • madeinta1wanundefined
                          madeinta1wan @hector
                          @hector Did you manage to get a working Telegram bot running? I know it's been some time since you posted and others have asked but I thought I'd check.
                          -Nate
                            Phaedrux Moderator @madeinta1wan
                            @madeinta1wan said in Notification in Telegram:
                            -Nate
                            See here: https://forum.duet3d.com/topic/7745/duet-telegram-bot
