    Connecting to Duet3 with Macbook
    Firmware installation
    690
    • meatfestundefined
      meatfest
      Dear All
      Aplogies but I cannot get M115 to return anything. I can connect to Duet3 via USB and Repetier OK - thats as far as I can get. Please help me, I'm new to this!
      • chrishammundefined
        chrishamm administrators
        Did you follow these instructions? https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3
        If yes, please explain if you are running your Duet in standalone or SBC mode.
        Duet software engineer
        meatfestundefined 1 Reply Last reply Reply Quote 0
        • Danalundefined
          Danal
          I use a Macbook on Duets regularly.
          The actual USB support (drivers) "just works". I choose to install the Mac version of "CoolTerm" rather than anything built in. There are probably several terminals that will work.
          By default Duet does not echo. So you type a command and it looks like nothing is happening. When you hit enter, you will get a result. Therefore, I choose to put CoolTerm in "line mode".
          • meatfestundefined
            meatfest @chrishamm
            @chrishamm Yes I followed instructions. In fact I am lucky enough to have a Windows 10 machine as well. I can connect to the Duet3D via USB (in this case COM9) I type M115 and nothing comes back...
              A Former User @meatfest
              @meatfest said in Connecting to Duet3 with Macbook:
              Can you check the device manager to see what the board identifies as. (Windows key + X, then select Device manager)
              (And look under Ports (COM & LPT)
              • meatfestundefined
                meatfest @A Former User
                @bearer Bossa Program Port (COM9)
                  see https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3
                  you can go straight to using the Bossa program as the firmware is already erased.
                  meatfestundefined 1 Reply Last reply Reply Quote 1
                  • meatfestundefined
                    @bearer also the diag led is dimly lit all the time, either with or without the erase pins connected...
                      droftarts administrators @meatfest
                      That means that the firmware has been erased. It should flash once a second if firmware is running. Also note that the Bossa program doesn't work on Mac OS to flash Duet 3 (it does work with Duet 2) so use a Windows PC to flash the firmware.
                      • meatfestundefined
                        meatfest
                        I switched to my Windows 10 machine for now, I just want to get it working. I will look at re flashing firmware.
                        • meatfestundefined
                          meatfest @meatfest
                          @meatfest still stuck. let me re-cap.
                          I have Duet3D board.
                          I am using Windows 10 (stopped using my Macbook Pro)
                          I have installed Bossa and Sam-Ba
                          I have updated the driver for USB and it shows Bossa Program Port (COM 9) in Device Manager.
                          With Sam-ba I get message:
                          Error h_handle returned zero
                          while executing
                          "TCL_Open $target(connection)" ....
                          With Bossa I get the message:
                          Could not connect to device on COM9
                            @meatfest It sounds like something is still connected to the Duet on COM9. I'd suggest restarting your PC, then just use Bossa to flash the Duet.
                            • meatfestundefined
                              meatfest @droftarts
                              @droftarts rebooted, same message from Bossa...
                                A Former User
                                While its possible there is a problem with the board, all the other instances has turned out to be issues with software or usb cables.
                                As such I think it could be worth while trying to build bossa from sources on the Mac and see if it makes a difference after applying a patch to the code.
                                Is cloning code with git and running make to build it something you're comfortable with on the Mac?
                                • Danalundefined
                                  Danal
                                  If you happen to have a Raspberry Pi, there are instructions on the Dozuki to set it up and try it. They are sometimes better at finding the bossa port. Sometimes.
                                    dc42 administrators @meatfest
                                    Which version of Bossa are you using?
                                    • meatfestundefined
                                      meatfest
                                      Success!
                                      In device manager I selected show hidden devices and found two instances of Bossa one was inactive the other active. I deleted both and reconnected and then when I selected the new com port I ran write and verify and all was well. It seemed that Windows held onto two com ports , one was hidden thus causing the problem. Something to bear in mind!
                                      Phaedruxundefined 1 Reply Last reply Reply Quote 2
                                        Phaedrux Moderator @meatfest
                                        show hidden devices
                                        Good tip.
                                        • meatfestundefined
                                          meatfest @Phaedrux
                                          This post is deleted!
