    WiFi reported error: Failed while trying to connect
    Firmware installation
    2.0k
      A Former User
      ref step 3 and set up line ending in yat
      https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s6
      • thrawn86undefined
        thrawn86
        thank you for this insight.
          A Former User
          Its a lot easier to read when the <LF> tuns into actual line feeds; your call.
          • thrawn86undefined
            thrawn86
            The time you've spent typing these two posts is already >= the time it takes to skim the first few lines of diagnostic output, the other two YAT responses are two lines each and the rest of my procedure is documented both in bullets and in another thread with a similar issue.
            If you have any other suggestions I'm all ears, but dropping into a thread and saying only that comes off very rudely.
            e: not the machine right this second but hopefully this will help
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later<LF>
            Board ID: 08DLM-996RU-N8PS4-7JKDG-3S86P-TBA7N<LF>
            Used output buffers: 14 of 24 (14 max)<LF>
            === RTOS ===<LF>
            Static ram: 25712<LF>
            Dynamic ram: 94000 of which 64 recycled<LF>
            Exception stack ram used: 304<LF>
            Never used ram: 10992<LF>
            Tasks: NETWORK(ready,540) DHTSENSOR(blocked,228) HEAT(blocked,912) MAIN(running,3824) IDLE(ready,160)<LF>
            Owned mutexes:<LF>
            === Platform ===<LF>
            Last reset 00:03:52 ago, cause: power up<LF>
            Last software reset details not available<LF>
            Error status: 0<LF>
            Free file entries: 10<LF>
            SD card 0 detected, interface speed: 20.0MBytes/sec<LF>
            SD card longest block write time: 0.0ms, max retries 0<LF>
            MCU temperature: min 34.9, current 37.4, max 37.5<LF>
            Supply voltage: min 0.0, current 0.0, max 0.1, under voltage events: 0, over voltage events: 0, power good: no<LF>
            Driver 0: ok, SG min/max not available<LF>
            Driver 1: ok, SG min/max not available<LF>
            Driver 2: ok, SG min/max not available<LF>
            Driver 3: ok, SG min/max not available<LF>
            Driver 4: ok, SG min/max not available<LF>
            Date/time: 1970-01-01 00:00:00<LF>
            Cache data hit count 430705318<LF>
            Slowest loop: 200.47ms; fastest: 0.05ms<LF>
            I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0<LF>=== Move ===<LF>
            Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms<LF>
            Bed compensation in use: none, comp offset 0.000<LF>
            === DDARing ===<LF>
            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0<LF>
            === Heat ===<LF>
            Bed heaters = 0 -1 -1 -1, chamberHeaters = 2 -1<LF>
            Heater 1 is on, I-accum = 0.0<LF>
            === GCodes ===<LF>
            Segments left: 0<LF>
            Stack records: 2 allocated, 0 in use<LF>
            Movement lock held by null<LF>
            http is idle in state(s) 0<LF>
            telnet is idle in state(s) 0<LF>
            file is idle in state(s) 0<LF>
            serial is ready with "M122" in state(s) 0<LF>
            aux is idle in state(s) 0<LF>
            daemon is idle in state(s) 0<LF>
            queue is idle in state(s) 0<LF>
            autopause is idle in state(s) 0<LF>
            Code queue is empty.<LF>=== Network ===<LF>
            Slowest loop: 1280.47ms; fastest: 0.00ms<LF>
            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)<LF>
            HTTP sessions: 0 of 8<LF>- WiFi -<LF>
            Network state is running<LF>
            WiFi module is idle<LF>
            Failed messages: pending 0, notready 0, noresp 0<LF>
            WiFi firmware version 1.23<LF>
            WiFi MAC address bc:dd:c2:2d:64:f6<LF>
            WiFi Vcc 3.47, reset reason Turned on by main processor<LF>
            WiFi flash size 4194304, free heap 26504<LF>
            Socket states: 0 0 0 0 0 0 0 0<LF>ok<LF>```
              Hang tight while I figure out what code 7 is. Haven't seen that one before.
              And I'm sorry but if you looked at M122 posts all day you'd want the proper formatting as well. Trying to read that on a mobile phone is nearly impossible, and on a monitor it's still eye wrenching. Please do a courtesy to those trying to help you by saving their poor eyeballs. 🤓
              A Former User? thrawn86undefined 2 Replies Last reply Reply Quote 0
                A Former User @Phaedrux
                This post is deleted!
                • thrawn86undefined
                  thrawn86 @Phaedrux
                  @Phaedrux
                  Do you think this is a failed wifi module like dc42 suggested in the post I linked?
                  This board was already a replacement for another failed duet thats out of warranty 😕
                  Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                    Phaedrux Moderator @thrawn86
                    @thrawn86 It's possible. Still waiting for DC to take a look.
                      That code means that the WiFi module didn't respond to a request for a transaction from the duet.
                      Are you certain that the WiFi firmware that you put on it was the DuetWiFiServer-1.23.bin file, renamed to DuetWiFiServer.bin before you ran M997 S1 ?
                      thrawn86undefined 1 Reply Last reply Reply Quote 0
                        droftarts administrators @thrawn86
                        @thrawn86 from switching on/reset, no SD card, connect via YAT on USB, then try sending M552 S-1 to disable module, then M552 S0 to enable module but not turn on WiFi, then add SSID with M587, and finally enable with M552 S1. Sometimes disabling then enabling kicks it into life.
                        • thrawn86undefined
                          thrawn86 @dc42
                          Positive. Any reason I shouldn't be using 2.05.1 and 1.23?
                          I have repeated the process a few times and occasionally have seen other errors including Code 4, Code 7, status error: Bad Reply format and status error: SPI timeout
                          M122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                          Used output buffers: 1 of 24 (10 max)
                          Static ram: 25712
                          Exception stack ram used: 320
                          Never used ram: 10976
                          Tasks: NETWORK(ready,1268) DHTSENSOR(blocked,228) HEAT(blocked,912) MAIN(running,3692) IDLE(ready,160)
                          Owned mutexes:
                          Last reset 00:10:07 ago, cause: software
                          Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11032 bytes (slot 0)
                          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04433000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                          Error status: 0
                          MCU temperature: min 33.4, current 33.5, max 33.8
                          Supply voltage: min 11.8, current 11.9, max 11.9, under voltage events: 0, over voltage events: 0, power good: yes
                          Cache data hit count 971815164
                          Slowest loop: 99.82ms; fastest: 0.07ms
                          === DDARing ===
                          Segments left: 0
                          === Network ===
                          Slowest loop: 1.28ms; fastest: 0.00ms
                          - WiFi -
                          Network state is changing mode
                          WiFi module is trying to connect
                          WiFi flash size 4194304, free heap 26584
                          ok
                          WiFi reported error: Failed while trying to connect to ***
                          WiFi module is idle
                            A Former User @thrawn86
                            @thrawn86 said in WiFi reported error: Failed while trying to connect:
                            There is no wifi firmware 2.05.1; that is reprap firmware. Reprap firmware 2.05.1 which is released together with DuetWiFiServer-1.23.bin; and it needs to be renamed to just DuetWifiServer.bin if you're doing things manually. In any case you'll have to have a valid DuetWiFiServer.bin file on the SD card as the latest M122 does show WiFi firmware version 1.23
                            • thrawn86undefined
                              thrawn86 @A Former User
                              @bearer
                              2.05.1 being the firmware reported by the board. I assume its relevant, but I'm sorry if my nomenclature isn't correct here.
                              The title of the github page I downloaded this firmware from is literally "Release 2.05.1" so I assume that both the combined firmware and wifi firmware linked therein are the correct ones to use. M122 reports that both are those versions are installed on their respective parts. If this isn't correct, please let me know.
                                but on the SD card the wifi firmware needs to be called just DuetWifiServer.bin not DuetWiFiServer-1.23.bin which is normally handled by the web interface automagically.
                                still, odds are DuetWifiServer.bin on the SD card is version 1.23 as that is what the running wifi modue is reporting.
                                • thrawn86undefined
                                  @bearer
                                  YAT is the only way I have to talk to the board right now since I can't connect to DWC, so firmware is done and renamed manually.
                                  Ultimately I just want to figure out if I need to send this board back or not, updating to the correct firmware has never been this difficult.
                                    If M122 reports that the WiFi firmware version is 1.23 then it has evidently been installed correctly. I think the WiFi module may be faulty and should be replaced.
                                    • thrawn86undefined
                                      thrawn86 @dc42
                                      unfortunately the replacement from filastruder has an identical issue
                                      M552 S0
                                      ok
                                      WiFi module started
                                      M587 S"***" P"***"
                                      ok
                                      M552 S1
                                      ok
                                      WiFi module is idle
                                      M552
                                      WiFi module is changing mode
                                      ok
                                      WiFi module is idle
                                      M552
                                      ok
                                      M115
                                      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
                                      ok
                                      M122
                                      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
                                      Board ID: 08DLM-996RU-N85T0-6JTD2-3S46Q-1UTZP
                                      Used output buffers: 1 of 24 (9 max)
                                      Static ram: 25680
                                      Dynamic ram: 93340 of which 164 recycled
                                      Exception stack ram used: 256
                                      Never used ram: 11632
                                      Tasks: NETWORK(ready,1268) HEAT(blocked,916) MAIN(running,3808) IDLE(ready,160)
                                      Owned mutexes:
                                      Last reset 00:08:27 ago, cause: power up
                                      Error status: 0
                                      MCU temperature: min 28.0, current 32.6, max 32.7
                                      Supply voltage: min 1.7, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
                                      Cache data hit count 1006782636
                                      Slowest loop: 100.14ms; fastest: 0.06ms
                                      Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                                      === DDARing ===
                                      Segments left: 0
                                      === Network ===
                                      Slowest loop: 1.26ms; fastest: 0.00ms
                                      - WiFi -
                                      WiFi MAC address bc:dd:c2:2d:5e:3e
                                      WiFi Vcc 3.36, reset reason Turned on by main processor
                                      WiFi flash size 4194304, free heap 27224
                                      ok
                                      WiFi module is idle
                                      at this point I have done literally nothing but open the box, connect the antenna and perform the steps described in : https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7 , sans firmware update. 2.03 was what I was running on my first board connected to the same network, before the sd card slot died.
                                      • thrawn86undefined
                                        thrawn86
                                        in addition, subsequent attempts (restarting, forgetting and re-adding network, creating a new SSID and connecting to that instead) have all yielded the same variety of wifi error messages including:
                                        -Error retrieving WiFi status message: bad reply format version
                                        Error retrieving WiFi status message: SPI timeout
                                        Failed to change WiFi mode (code -7)
                                          normally fixed by (from YAT etc)
                                          M552 S-1 ;to disable the wifi module
                                          M552 S0 ;to disable networking/idle wifi
                                          G4 S1 ;wait a second
                                          M587 S"" P"" ; insert ssid and passphrase to add wifi
                                          M552 S1 ;to enable networking
                                          but to try and get some more info on the other issues i'd run
                                          M588 S"*"; forget all previous access point info
                                          then power down, remove the SD card and power it back up without the SD card. connect to usb/YAT and run
                                          M111 P14 S1 ;to enable wifi debug
                                          (don't need to type ; and what comes after, but its safe to copy/paste as is)
                                          edit: unclear - you installed RRF 2.03 but wifi 1.23 was on there already?
                                          • thrawn86undefined
                                            @bearer
                                            That was exactly what was on the board out of the box.
                                            e:
                                            M552 S0
                                            ok
                                            WiFi module started
                                            M588 S"*"
                                            ok
                                            M552
                                            WiFi module is disabled
                                            ok
                                            M111 P14 S1
                                            Debugging enabled for modules: WiFi(14)
                                            Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15)
                                            ok
                                            M552 S-1
                                            ok
                                            M552 S0
                                            WiFi:
                                            WiFi:  ets Jan  8 2013,rst cause:2, boot mode:(3,6)
                                            WiFi:
                                            ok
                                            WiFi: load 0x4010f000, len 1384, room 16
                                            WiFi: tail 8
                                            WiFi: chksum 0x2d
                                            WiFi: csum 0x2d
                                            WiFi: v3fff168c
                                            WiFi: ~ld
                                            WiFi module started
                                            G4 S1
                                            ok
                                            M587 S"Battlestar Pegasus Mainframe" P"***"
                                            ok
                                            M552 S1
                                            ok
                                            WiFi:
                                            WiFi: add if0
                                            WiFi: wifi evt: 8
                                            WiFi: scandone
                                            WiFi: ../src/SocketServer.cpp(353): found network dobry22
                                            WiFi: ../src/SocketServer.cpp(353): found network Alex WiFi
                                            WiFi: ../src/SocketServer.cpp(353): found network xfinitywifi
                                            WiFi: ../src/SocketServer.cpp(353): found network Brother Eye
                                            WiFi: ../src/SocketServer.cpp(353): found network luk-ela
                                            WiFi: ../src/SocketServer.cpp(353): found network PS4-A490FF8D684C
                                            WiFi: ../src/SocketServer.cpp(353): found network PS4-3B1F4A9CD2C0
                                            WiFi: ../src/SocketServer.cpp(353): found network Wifi is Jericho!!
                                            WiFi: ../src/SocketServer.cpp(353): found network Toilet Cam #12
                                            WiFi: ../src/SocketServer.cpp(353): found network Loki1
                                            WiFi: ../src/SocketServer.cpp(353): found network ATT528s735
                                            WiFi: ../src/SocketServer.cpp(353): found network The Room Of Requirement
                                            WiFi reported error: no known networks found
                                            WiFi module is idle
                                            WiFi: scandone
                                            WiFi: ../src/SocketServer.cpp(353): found network Petersen
                                            WiFi: ../src/SocketServer.cpp(353): found network SEC_LinkShare_836496
                                            WiFi: ../src/SocketServer.cpp(353): found network TK2.4
                                            WiFi: ../src/SocketServer.cpp(353): found network degapudi
                                            WiFi: ../src/SocketServer.cpp(353): found network CRAZYVirus
                                            WiFi: ../src/SocketServer.cpp(353): found network MAXIMUS
                                            WiFi: ../src/SocketServer.cpp(353): found network NETGEAR56
                                            WiFi module is idle
                                            WiFi: ../src/SocketServer.cpp(353): found network TP-LINK_D28A
                                            WiFi: scandone
                                            WiFi: ../src/SocketServer.cpp(353): found network NETGEAR20
                                            WiFi: ../src/SocketServer.cpp(353): found network Srbija 2G
                                            WiFi module is idle
                                            WiFi: scandone
                                            WiFi: ../src/SocketServer.cpp(353): found network Battlestar Pegasus Mainframe
                                            WiFi: ../src/SocketServer.cpp(353): found network BattlePi24
                                            WiFi: ../src/SocketServer.cpp(353): found network ATT3Hkz4Mq2.4
                                            WiFi: sleep enable,type: 2
                                            WiFi: wifi evt: 2
                                            WiFi: scandone
                                            WiFi: state: 0 -> 2 (b0)
                                            WiFi: state: 2 -> 0 (2)
                                            WiFi: reconnect
                                            WiFi: wifi evt: 1
                                            WiFi: STA disconnect: 2
                                            WiFi: scandone
                                            WiFi: reconnect
                                            WiFi: wifi evt: 1
                                            WiFi: scandone
                                            WiFi: reconnect
                                            WiFi reported error: Failed while trying to connect to Battlestar Pegasus Mainframe
                                            WiFi module is idle
                                            WiFi: wifi evt: 1
                                            WiFi: scandone
                                            WiFi: del if0
                                            WiFi: usl
                                            WiFi: mode : null
                                            WiFi: wifi evt: 8
                                            WiFi: mode : sta(bc:dd:c2:2d:5e:3e)
                                            WiFi: add if0
                                            WiFi: wifi evt: 8
                                            WiFi: scandone
                                            after that it just starts looping. Also, I was able to start it up in AP mode and I can get into DWC that way if needed.
