    [HELP] How to use DueUI without a Duet using chrome
    DueUI
    3.4k
    • Dario02undefined
      Dario02 @gtj0
      @gtj0 Just put them in the same directory as the top level html file and you can use the button example above. "value": "<img src='/my_icon.png'/>" doesn't work, maybe I didn't understand correctly, an example for '/my_icon.png' please
      • Dario02undefined
        Dario02
        ok i had to resize the image... is there a way like on css to self crop the image specifying the size in pixel or in percentage?
        Another problem is that by setting an image as value this is not centered and remains some colored margin....
        • gtj0undefined
          gtj0 @Dario02
          @Dario02 You have complete control over the styling with the "style" attribute. Almost anything you can do in CSS you can do with "style". See the example in https://github.com/gtjoseph/DueUI/wiki/Element
          Dario02undefined 1 Reply Last reply Reply Quote 0
          • Dario02undefined
            Dario02 @gtj0
            @gtj0 ok I'll check thank you, please could you check why If I put an image to a button the image is not centered and doesn't cover the whole button even if I resize it in photoshop?
            • gtj0undefined
              gtj0 @Dario02
              @Dario02 At the time the screen is painted, the browser might not know what the size of the image is.
              Let's say your image is 128x128 but you want it to display as 32x32 in a button that's 8 pixels bigger (40x40):
              	"id": "my_button",
              	"type": "button",
              	// Set the size of the image
              	"value": "<img src='my_icon.png' width='32' height='32'/>",
              	// Set the size of the button
              	"style": {
              		"width": "40px",
              		"height": "40px",
              		"padding": "8px",
              You'll have to play with the style (CSS) to get it to display the way you want.
              • tech-ratonundefined
                tech-raton
                Thank you very much,
                I'm on tracks.
                I'm modifying your file.
                I was looking for a way to modify the layout of dwc but your way is easier.
                Thank you again.
                • Dario02undefined
                  Dario02
                  @gtj0 how to fix this errore?
                  Could not retrieve config from http://192.168.1.118/rr_download?name=/sys/dueui_config.json
                  • gtj0undefined
                    gtj0 @Dario02
                    @Dario02 said in [HELP] How to use DueUI without a Duet using chrome:
                    Does the file actually exist in the /sys/ directory on the Duet?
                    If not, you need to either place the file there, or change the "DueUI config file URL" in Settings to point to the correct config file.
                    • Dario02undefined
                      Dario02 @gtj0
                      @gtj0 the file is in the sys folder, how can I see the exact url????
                      • gtj0undefined
                        gtj0 @Dario02
                        @Dario02 You're using a Duet in standalone mode yes? No Raspberry Pi attached?
                        If so, that should be the URL. Can you just enter that URL in a browser and get the file? How about http://192.168.1.118/rr_download?name=/sys/config.g ?
                        Dario02undefined 2 Replies Last reply Reply Quote 0
                        • Dario02undefined
                          Dario02 @gtj0
                          @gtj0 I'm using the duet connected via ethernet and the url you gave me doesn't work
                          wait . . .
                          • Dario02undefined
                            Dario02 @gtj0
                            @gtj0 I'm using duet 2 ethernet connected via cable and the url you gave me works...
                            I assume I have to give that url but with the json file's path
                            • Dario02undefined
                              Dario02
                              @gtj0 it works, I don't know if it's because you changed the file name with dueui_config_default_standalone.json that didn't work
                              • gtj0undefined
                                gtj0 @Dario02
                                @Dario02 Ah OK. You can use the DuetWebControl to see the files on the Duet's SD Card.
                                • Dario02undefined
                                  Dario02 @gtj0
                                  @gtj0 yay, now it's working fine, I have to "study" how to use elements etc
                                  • Dario02undefined
                                    Dario02
                                    @gtj0 is there a way to modify the config.json without removing the sd card?
                                    gtj0undefined 2 Replies Last reply Reply Quote 0
                                    • gtj0undefined
                                      gtj0 @Dario02
                                      @Dario02 Sure. Use the DuetWebControl and go to "File Management, System". You can upload files and even edit the config.json file right from there.
                                      • gtj0undefined
                                        gtj0 @Dario02
                                        @Dario02 Oh don't forget, the file doesn't actually have to be on the Duet. You can have it anywhere as I described above.
                                        • Dario02undefined
                                          Dario02 @gtj0
                                          @gtj0 ehm... how should I use dwc if I can't see it?? I just received my duet and I'm not well informed... My last question is "how can I setup my DUEUI for a 7" rpi lcd?
                                          • Dario02undefined
                                            Dario02
                                            @gtj0 I mean that if I search 192.168.1.118 I only see a blank page... before install dueui I was able to see the dwc page
