[HELP] How to use DueUI without a Duet using chrome
DueUI
3.3k
    gtj0 @Dario02
    @Dario02 At the time the screen is painted, the browser might not know what the size of the image is.
    Let's say your image is 128x128 but you want it to display as 32x32 in a button that's 8 pixels bigger (40x40):
    	"id": "my_button",
    	"type": "button",
    	// Set the size of the image
    	"value": "<img src='my_icon.png' width='32' height='32'/>",
    	// Set the size of the button
    	"style": {
    		"width": "40px",
    		"height": "40px",
    		"padding": "8px",
    You'll have to play with the style (CSS) to get it to display the way you want.
      tech-raton
      Thank you very much,
      I'm on tracks.
      I'm modifying your file.
      I was looking for a way to modify the layout of dwc but your way is easier.
      Thank you again.
        Dario02
        @gtj0 how to fix this errore?
        Could not retrieve config from http://192.168.1.118/rr_download?name=/sys/dueui_config.json
        undefined 1 Reply Last reply 9 May 2020, 21:19 Reply Quote 0
          gtj0 @Dario02
          @Dario02 said in [HELP] How to use DueUI without a Duet using chrome:
          Does the file actually exist in the /sys/ directory on the Duet?
          If not, you need to either place the file there, or change the "DueUI config file URL" in Settings to point to the correct config file.
          undefined 1 Reply Last reply 9 May 2020, 21:23 Reply Quote 0
            Dario02 @gtj0
            @gtj0 the file is in the sys folder, how can I see the exact url????
            undefined 1 Reply Last reply 9 May 2020, 21:27 Reply Quote 0
              gtj0 @Dario02
              @Dario02 You're using a Duet in standalone mode yes? No Raspberry Pi attached?
              If so, that should be the URL. Can you just enter that URL in a browser and get the file? How about http://192.168.1.118/rr_download?name=/sys/config.g ?
              undefined 2 Replies Last reply 9 May 2020, 21:28 Reply Quote 0
                Dario02 @gtj0
                @gtj0 I'm using the duet connected via ethernet and the url you gave me doesn't work
                wait . . .
                  Dario02 @gtj0
                  @gtj0 I'm using duet 2 ethernet connected via cable and the url you gave me works...
                  I assume I have to give that url but with the json file's path
                    Dario02
                    @gtj0 it works, I don't know if it's because you changed the file name with dueui_config_default_standalone.json that didn't work
                    undefined 1 Reply Last reply 9 May 2020, 21:35 Reply Quote 0
                      gtj0 @Dario02
                      @Dario02 Ah OK. You can use the DuetWebControl to see the files on the Duet's SD Card.
                      undefined 1 Reply Last reply 9 May 2020, 21:37 Reply Quote 0
                        Dario02 @gtj0
                        @gtj0 yay, now it's working fine, I have to "study" how to use elements etc
                          Dario02
                          @gtj0 is there a way to modify the config.json without removing the sd card?
                          undefined 2 Replies Last reply 9 May 2020, 21:44 Reply Quote 0
                            gtj0 @Dario02
                            @Dario02 Sure. Use the DuetWebControl and go to "File Management, System". You can upload files and even edit the config.json file right from there.
                            undefined 1 Reply Last reply 9 May 2020, 21:49 Reply Quote 0
                              gtj0 @Dario02
                              @Dario02 Oh don't forget, the file doesn't actually have to be on the Duet. You can have it anywhere as I described above.
                                Dario02 @gtj0
                                @gtj0 ehm... how should I use dwc if I can't see it?? I just received my duet and I'm not well informed... My last question is "how can I setup my DUEUI for a 7" rpi lcd?
                                undefined 1 Reply Last reply 9 May 2020, 21:54 Reply Quote 0
                                  Dario02
                                  @gtj0 I mean that if I search 192.168.1.118 I only see a blank page... before install dueui I was able to see the dwc page
                                  undefined 1 Reply Last reply 9 May 2020, 21:57 Reply Quote 0
                                    gtj0 @Dario02
                                    If 192.168.1.118 is the IP address of your Duet, then just go to http://192.168.1.118/
                                    That the default user interface that ships with all Duets.
                                    You'll need to run a browser on the Pi.
                                    undefined 2 Replies Last reply 9 May 2020, 21:55 Reply Quote 0
                                      Dario02 @gtj0
                                      @gtj0 so is the page responsive?? Cause I tried with your apk from my smartphone and I see a page that doesn't fit my screen size
                                        gtj0 @Dario02
                                        Oh. Something got messed up then. The install of DueUI should NOT have touched the existing DWC installation. Let me check on something.
                                        No. It renders however you designed it and it depends on the browser and screen resolution.
                                        undefined 1 Reply Last reply 9 May 2020, 21:58 Reply Quote 0
                                          Dario02 @gtj0
                                          @gtj0 If I search 192.168.1.118 now I see a blank page, if I use ctrl+u I'm able to see that the html only shows dueui.startup() or something similar
