    [HELP] How to use DueUI without a Duet using chrome
    DueUI
    3.3k
    • Dario02undefined
      Dario02 @gtj0
      @gtj0 the file is in the sys folder, how can I see the exact url????
      • gtj0undefined
        gtj0 @Dario02
        @Dario02 You're using a Duet in standalone mode yes? No Raspberry Pi attached?
        If so, that should be the URL. Can you just enter that URL in a browser and get the file? How about http://192.168.1.118/rr_download?name=/sys/config.g ?
        Dario02undefined 2 Replies Last reply Reply Quote 0
        • Dario02undefined
          Dario02 @gtj0
          @gtj0 I'm using the duet connected via ethernet and the url you gave me doesn't work
          wait . . .
          • Dario02undefined
            Dario02 @gtj0
            @gtj0 I'm using duet 2 ethernet connected via cable and the url you gave me works...
            I assume I have to give that url but with the json file's path
            • Dario02undefined
              Dario02
              @gtj0 it works, I don't know if it's because you changed the file name with dueui_config_default_standalone.json that didn't work
              • gtj0undefined
                gtj0 @Dario02
                @Dario02 Ah OK. You can use the DuetWebControl to see the files on the Duet's SD Card.
                Dario02undefined 1 Reply Last reply Reply Quote 0
                • Dario02undefined
                  Dario02 @gtj0
                  @gtj0 yay, now it's working fine, I have to "study" how to use elements etc
                  • Dario02undefined
                    Dario02
                    @gtj0 is there a way to modify the config.json without removing the sd card?
                    gtj0undefined 2 Replies Last reply Reply Quote 0
                    • gtj0undefined
                      gtj0 @Dario02
                      @Dario02 Sure. Use the DuetWebControl and go to "File Management, System". You can upload files and even edit the config.json file right from there.
                      • gtj0undefined
                        gtj0 @Dario02
                        @Dario02 Oh don't forget, the file doesn't actually have to be on the Duet. You can have it anywhere as I described above.
                        • Dario02undefined
                          Dario02 @gtj0
                          @gtj0 ehm... how should I use dwc if I can't see it?? I just received my duet and I'm not well informed... My last question is "how can I setup my DUEUI for a 7" rpi lcd?
                          • Dario02undefined
                            Dario02
                            @gtj0 I mean that if I search 192.168.1.118 I only see a blank page... before install dueui I was able to see the dwc page
                            • gtj0undefined
                              gtj0 @Dario02
                              @Dario02 said in [HELP] How to use DueUI without a Duet using chrome:
                              If 192.168.1.118 is the IP address of your Duet, then just go to http://192.168.1.118/
                              That the default user interface that ships with all Duets.
                              You'll need to run a browser on the Pi.
                              • Dario02undefined
                                Dario02 @gtj0
                                @gtj0 so is the page responsive?? Cause I tried with your apk from my smartphone and I see a page that doesn't fit my screen size
                                • gtj0undefined
                                  gtj0 @Dario02
                                  Oh. Something got messed up then. The install of DueUI should NOT have touched the existing DWC installation. Let me check on something.
                                  No. It renders however you designed it and it depends on the browser and screen resolution.
                                  • Dario02undefined
                                    Dario02 @gtj0
                                    @gtj0 If I search 192.168.1.118 now I see a blank page, if I use ctrl+u I'm able to see that the html only shows dueui.startup() or something similar
                                    • Dario02undefined
                                      Dario02 @gtj0
                                      @gtj0 ok so I have to make a page for my 7 inch, ok I don't know how but I'll try
                                      • Dario02undefined
                                        Dario02
                                        @gtj0 I searched http://192.168.1.118/reprap.htm and now it displays the dwc... ok
                                        • Dario02undefined
                                          Dario02
                                          @gtj0 I'm tired now it's midnight where I live, have a nice day, thank you! 🙂
                                          • gtj0undefined
                                            gtj0 @Dario02
                                            @Dario02 That was my fault. I accidentally included a file in the zip that shouldn't have been there. Since you can get to the DWC now using reprap.htm, you can re-upload the DWC from this zip and http://192.168.1.118/ will work again.
                                            https://github.com/chrishamm/DuetWebControl/releases/download/2.1.7/DuetWebControl-SD.zip
