Problem with overhangs
1.3k
    MrBlom
    Hello i upgraded my D-bot(corexy) lastweek and have some problems with printing small overhangs
    it prints good on normal stuff but if there is overhang it gets ugly
    please help me fix this
      MrBlom
      if you can not see the image go here
      https://www.dropbox.com/s/hcju7e1wz2kmynw/2017-04-04%2020.10.41.jpg?dl=0
        DjDemonD
        Hi couple of things
        What material?
        What nozzle temperature?
        What hotend?
        What sort of part fans?
        www.precisionpiezo.co.uk
          MrBlom
          Hi sorry
          PLA
          195 - 220 tried different
          e3d titan/aero
          1 radial fan blowing from the left
          see set up here
          https://www.dropbox.com/s/b0rico0keothqr1/2017-04-01%2017.12.44.jpg?dl=0
          hmm in the pic i printed the falcon from starwars with overhang with out problems
          it seams like it only is when the overhang is curved
            MrBlom
            hmm must be the cooling
            i have a 24v systems then the fans is running at 24v?
            or is the fan 12v ? if so the fan might run to slow
              DjDemonD
              Either the fan is designed for 24v,12v or 5v. If it were 12v it would be running insanely fast at 24v, a 5v fan would probably run for a few seconds at 24v before dying.
              You probably have adequate cooling, but cooling from one side is much less effective for preventing curling which causes the pattern on the cup shaped objects at the top. The filament curls away or towards the fan.
              In the image of the blue object the focus isn't clear but I'd say it looks over extruded too.
                MrBlom
                i have a 24v fan and system
                but it not the fan
                i put a 80mm fan on the heatbed on the other side and the result was the same
                i have done 20x20 cube and it correct size and check the e-steps
                  MrBlom
                  hmm will try to lower the extrusion alot to see what happens
                    MrBlom
                    it was bad cooling
                    the pink part is printed with excact the same gcode but with dual radila fans
                    see pic here
                    https://www.dropbox.com/s/45figvtgtf1b6sp/2017-04-07%2015.31.59.jpg?dl=0
                      T3P3Tony administrators
                      That is comprehensively solved!
                      7 out of 10
