Core XYU or XYUV
3.3k
    curlypaul
    Hi all,
    Been a long time duet user, but this is my first post here - so hello ! 🙂
    So, I designed this last year, but since having a little more time on my hands, I've finally had some time to build it
    Anyway... My question is, Is this Core XYU or XYUV, I've been struggling this morning getting everything moving the right way.
    Any help appreciated !
      You have 2 motors per belt. That makes it CoreXYUV.
        curlypaul
        Thank you - That's what I thought 😀
        Just checking the obvious...
        This is M669 K8 with FW 2.05, and then setup as per a 'normal' corexy but with additional axes in config.g
        Do I need to home V ? Do I hide V ?
        I don't need to do any other mapping etc ?
        I only ask as I'm spent a couple of hours trying to get everything moving the right way so far
          You should hide V and not home it.
            curlypaul
            Thank you
            undefined 1 Reply Last reply 15 May 2020, 13:57 Reply Quote 0
              curlypaul
              Getting somewhere now - this is making me feel like a noob all over again !
              So.. I can home x (lh tool to left)
              I can home y to mc front
              I can home u (rh tool to right)
              Then, if i try to move Y, it's like the motors don't go in the right directions ?
              I must be doing something wrong !?!?
              EDIT : Can still move X and U in there correct directions - just Y is doing the wrong thing
              undefined 1 Reply Last reply 15 May 2020, 13:59 Reply Quote 0
                deckingman @curlypaul
                @curlypaul Off topic I know but that's an awesome looking build! Maybe not the way that I would do things but none the less awesome. Did you make those aluminium parts or have them machined for you?
                  @curlypaul Back on topic - might be best if you post your config.g and homing files.
                    curlypaul
                    Thankyou - I'll take that from seeing your build 🙂
                    All machined at work, it's meant to be a toolchanger at some point also - that was the original plan
                    It's sister machine has been running since last november, but only as a single head, but as with everything, life and work get in the way 😞
                      curlypaul
                      Here we go, only using stall for homing at present for getting it going
                      config.g
                      M550 P"Dual Head" ; set printer name
                      M669 K8 ; select CoreXYUV mode
                      M552 S1 ; enable network
                      M586 P0 S1 ; enable HTTP
                      M586 P1 S0 ; disable FTP
                      M586 P2 S0 ; disable Telnet
                      M569 P0 S1 ; X physical drive 0 goes forwards
                      M569 P1 S1 ; Y physical drive 1 goes forwards
                      M569 P2 S1 ; Z physical drive 2 goes forwards
                      M569 P3 S0 ; U physical drive 3 goes forwards
                      M569 P4 S1 ; V physical drive 4 goes forwards
                      M569 P5 S1 ; E0 physical drive 0 goes forwards
                      M569 P6 S1 ; E1 physical drive 1 goes forwards
                      M584 X0 Y1 U3 V4 Z2 E5:6 P4 ; set drive mapping
                      M350 X16 Y16 U16 V16 Z16 E16:16 I1 ; configure microstepping with interpolation
                      M92 X160 Y160 U160 V160 Z2560 E420:420 ; set steps per mm
                      M566 X1200 Y1200 U1200 V1200 Z12 E120:120 ; set maximum instantaneous speed changes (mm/min)
                      M203 X9000 Y9000 U9000 V9000 Z360 E1200:1200 ; set maximum speeds (mm/min)
                      M201 X1000 Y1000 U1000 V1000 Z500 E250:250 ; set accelerations (mm/s^2)
                      M906 X1400 Y1400 U1400 V1400 Z1400 E1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M208 X-5 Y-5 U-5 V-5 Z0 S1 ; set axis minima
                      M208 X400 Y350 U400 V350 Z300 S0 ; set axis maxima
                      M574 X1 Y1 U1 V1 S3 ; set endstops controlled by motor stall detection
                      M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                      M558 P9 H5 F120 T9000 ; set Z probe type to bltouch and the dive height + speeds
                      M557 X-35:215 Y-45:195 S20 ; define mesh grid
                      M143 H0 S90 ; set temperature limit for heater 0 to 90C
                      M305 P2 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 2
                      M143 H2 S280 ; set temperature limit for heater 2 to 280C
                      M106 P0 S0 I0 F50 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                      M106 P1 S1 I0 F50 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      M106 P2 S1 I0 F50 H2 T45 X125 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      M106 P3 S1 I0 F50 H-1 ; set fan 3 value, PWM signal inversion and frequency. Thermostatic control is turned off
                      M563 P1 D1 H2 F3 X3 ; define tool 1
                      homeu.g
                      M400 ; make sure everything has stopped before we make changes
                      G4 P100 ; wait 400ms
                      M574 U1 V1 S3 ; set endstops to use motor stall
                      M913 U50 V50 ; drop motor currents to 50%
                      M915 H200 U V S3 R0 F0 ; set X and Y to sensitivity 3, do nothing when stall, unfiltered
                      G91
                      G1 H2 Z5 F9000 ; lift Z relative to current position
                      G1 H1 U705 F4000 ; move quickly to X axis endstop and stop there (first pass)
                      G1 H2 U-6 F5000 ; go back a few mm
                      G1 H1 U705 F3000 ; move slowly to X axis endstop once more (second pass)
                      G1 H2 Z-5 F9000 ; lower Z again
                      G92 U400
                      M400 ; make sure everything has stopped before we reset the motor currents
                      M913 U100 V100 ; motor currents back to 100%
                      M574 U1 S0 ; Define active low and unused microswitches
                      G1G91U-5.F5000
                      homex.g
                      M574 X1 Y1 S3 ; set endstops to use motor stall
                      M913 X50 Y50 ; drop motor currents to 50%
                      M915 H200 X Y S3 R0 F0 ; set X and Y to sensitivity 3, do nothing when stall, unfiltered
                      G91
                      G1 H1 X-705 F4000 ; move quickly to X axis endstop and stop there (first pass)
                      G1 H2 X6 F5000 ; go back a few mm
                      G1 H1 X-705 F3000 ; move slowly to X axis endstop once more (second pass)
                      G92 X0
                      M913 X100 Y100 ; motor currents back to 100%
                      M574 X1 S0 ; Define active low and unused microswitches
                      G1G91X5.F5000
                      G90
                      homey.g
                      G91 ; relative positioning
                      M913 X40 Y40 ; drop motor currents to 25%
                      G1 S1 Y-700 F4000 ; move all carriages up 700mm, stopping at the endstops
                      G1 Y5
                      G92 Y0
                      G4 X2000
                      G1 Y5
                      G92 Y0
                      G90 ; back to absolute positioning
                      M574 Y1 S0 ; Define active low and unused microswitches
                      undefined 1 Reply Last reply 15 May 2020, 14:24 Reply Quote 0
                        @curlypaul I have an idea but I might be on the wrong track. I need to clarify a few things in my mind - bear with me.
                        Looking at your rig, I'm assuming that you just have one gantry that moves towards the back and front and that on that gantry you have two independent heads that move left to right yes? If so, then and Y and V are common but X and U are separate yes?
                        You are homing X to the left but U to the right yes?
                        But you have all the end stops set to the low end (M574). So what I think you might need to do is change the U end stop to be at the high end (change M574 U1 to U2). But then you'll need to change the motor directions as well (I think - because you say that it currently homes correctly but we need to change the endstop from being low end to high end). Maybe David can confirm or otherwise.
                          curlypaul
                          I noticed the U was U1 not U2 after I posted the code - changed to U2 still the same
                          Everything else you typed was correct
                          undefined 1 Reply Last reply 15 May 2020, 14:32 Reply Quote 0
                            @curlypaul You've got a couple of M574s in your home U as well as in config.g. Do they now all match?
                            undefined 1 Reply Last reply 15 May 2020, 14:34 Reply Quote 0
                              curlypaul @deckingman
                              @deckingman Yes - Both U2
                              undefined 1 Reply Last reply 15 May 2020, 15:04 Reply Quote 0
                                @curlypaul I've just re-read you post - lack of caffeine on my part - it's Y that you are having problems with not U. So you can home Y fine but you can't move Y "normally". That's a bit puzzling. My printer is a bit different because I have two completely separate gantries (actually 3 because it's now CoreXYUVAB) but what I have to do is map the motors to individual axes for homing, then combine them for "normal" movement. So maybe what you need to do is, after homing Y combine the Y and V motors. So send M584 Y1:4. if that works, then change your config.g to be M584 X0 Y1:4 U3 V4 Z2 E5:6 (not sure about the "P" - maybe leave it as 4). That might work (no guarantees) ☺
                                undefined 1 Reply Last reply 15 May 2020, 15:05 Reply Quote 0
                                  @deckingman - can't hurt to try ! - thank you for taking the time 👍
                                    curlypaul
                                    Well, that made for some strange movements
                                    So, I can home X, Y and then U - all fine then if I try to move Y it doesn't move correctly and the belts/motors make angry noises (Sorry - I spent ages thinking of a better description)
                                    Yet X and U still move correctly
                                    From a fresh power on situation, if I send M564 H0,same as homing, again x moves okay, y moves okay, u moves okay. Go back to y - angry noises again
                                    If I move x, then u - all okay but then if I move Y - it doesn't like it
                                    undefined 1 Reply Last reply 15 May 2020, 16:00 Reply Quote 0
                                      @curlypaul "Angry noises" is nicely descriptive. 🙂 It seems that the motors are fighting against each other - or maybe one or more is stationary.
                                      I'm looking at your home Y file and trying to figure out what's different between a G1 Y move there and a G1 Y move outside of home Y. 2 things leap out at me (but I'm not sure how it helps).
                                      Firstly, you seem to have a scattering of "G1 S1" moves in amongst the "G1 H2s". So you ought to correct them (edit - change them from S1 to H1).
                                      Secondly H1 and H2 moves select individual motor mode. So I'm guessing that if you send G1 H2 Ynn it will work, but if you send G1 Ynn (without the "H") you'll get "angry noises". Can you check if that's the case?
                                      undefined 1 Reply Last reply 15 May 2020, 16:36 Reply Quote 0
                                        @deckingman - I didn't spot the S1 in HomeY, That's gone now - still the same
                                        In the meantime, I thought I'd try swapping the carriages - so U is now RH / X LH still the same issue
                                        It's really baffling me, all axis move the correct way and amount on their own, just whenever need to 'mix' axes (if that makes sense) Y goes wrong.
                                        I unhid V and sent a M564 H0. U and V move correct ways and I can then move X try and move Y .... angry noises
                                        I reset... I move X,U and Y, and X,Y and U try and move V - angry noises 😞
                                          curlypaul
                                          Endeavoured to make a video of whats going on..
                                          https://youtu.be/z0dNBMlm_lQ
                                          This is with carriages swapped from original - as mentioned in previous post
                                          undefined 3 Replies Last reply 15 May 2020, 17:25 Reply Quote 0
                                          9 out of 41
