    Bltouch with new firmware
    1.7k
    • Elliotundefined
      Elliot @Phaedrux
      @Phaedrux I was getting some other errors but playing around fixed them. I am now getting the errors you can see on screen.
      I have noticed another issue.
      My Bltouch deploys but does not retract (lights still flash like its doing it)
      One last thing..... I realized that my hardware HAS changed. I have added a lcd screen (the duet 5 inch) It is only connected via the X1 slot on the back of the LCD.
        dc42 administrators @Elliot
        @Elliot said in Bltouch with new firmware:
        M557 X50:200 Y50:200 S65 P3:3 ; Define mesh grid
        That looks correct.
        ; probe locoation
        M557 P1 X41 Y25
        M557 P2 X120 Y25
        M557 P3 X200 Y25
        M557 P4 X200 Y135
        M557 P5 X120 Y135
        M557 P6 X41 Y135
        M557 P7 X41 Y200
        M557 P8 X120 Y200
        M557 P9 X200 Y200
        That style of M577 command hasn't been supported for many versions. I suggest you remove those M557 commands.
        Elliotundefined 1 Reply Last reply Reply Quote 1
        • Elliotundefined
          Elliot @dc42
          @dc42 I removed them and now I get M280: Invalid servo index 3 in M280 command
          • aidarundefined
            aidar
            How is your bltouch connected? And please post your deployprobe.g and retractprobe.g files
            Elliotundefined 1 Reply Last reply Reply Quote 0
            • Elliotundefined
              Elliot @aidar
              @aidar It is connected the same way it was before (see pics).
              Deploy
              M280 P7 S10 I1
              Retract
              M280 P7 S90 I1
              • aidarundefined
                aidar
                I can not see where is yellow wire connected to. In deplayprobe and retractprobe files you define it to be connected to heater7, however in your config you disabled heater3 and heater4 for it. And servo signal wire (yellow one) is not connected to either of them. I see black wire connected to heater3 pin, if it is yellow servo wire extension, then you should change deployprobe and retractprobe files .So they will be:
                M280 P3 S10 I1
                and
                M280 P3 S90 I1
                Elliotundefined 1 Reply Last reply Reply Quote 2
                • Elliotundefined
                  Elliot @aidar
                  @aidar Thank you. Yes, the black wire is an extension of the yellow. I changed my deployprobe and retractprobe files and it is better.
                  1. Is there anything I should change in my config.g?
                  2. I was able to start a print. It only did one probe (in the front left corner) and then started to try and print. How can I make it do the probe test on all corners and in the middle?
                  • aidarundefined
                    aidar
                    I would remove all M918 commands from config, as you do not have 12864 display connected (its supported on Maestro board, not on Wifi), paneldue is connected, but that is differst thing and do not need that M918 command.
                    About probing - please post your homing files as well as slicer starting script.
                    • Elliotundefined
                      Elliot @aidar
                      @aidar these are the homing files I have:
                      Homeall.g
                      ; homeall.g
                      ; called to home all axes
                      ; generated by RepRapFirmware Configuration Tool on Sat Sep 29 2018 12:21:44 GMT-0700 (Pacific Daylight Time)
                      G1 Z2.5 F6000 S2        ; lift Z relative to current position
                      M98 Pdeployprobe.g      ; deploy mechanical Z probe
                      G1 S1 X-269 Y-261 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 X5 Y5 F6000          ; go back a few mm
                      G1 S1 X-269 Y-261 F360  ; move slowly to X and Y axis endstops once more (second pass)
                      G90                     ; absolute positioning
                      G1 X51 Y20 F6000        ; go to first bed probe point and home Z
                      G30                     ; home Z by probing the bed
                      ;G91                    ; relative positioning
                      ;G1 S2 Z2.5 F100        ; lift Z relative to current position
                      ;G90                    ; absolute positioning
                      M98 Pretractprobe.g     ; retract mechanical Z probe
                      homedelta.g
                      ; Example Homing file for RepRapFirmware on delta printer
                      M117 Use https://configurator.reprapfirmware.org/ to set up your printer config
                      ;G91							; use relative positioning
                      ;******* Change F250 in the following line to F2500 when you are finished commissioning
                      ;******* Change 320 in the following to a higher value if your Kossel has taller towers
                      ;G1 S1 X320 Y320 Z320 F2500	; move all carriages up 320mm, stopping at the endstops
                      ;G1 S2 X-3 Y-3 Z-3			; move all carriages down 3mm
                      ;G1 S1 X6 Y6 Z6 F250			; move carriages slowly up 6mm, stopping at the endstops
                      ;G1 Z-5 F2000				; down a few mm so that we can centre the head
                      ;G90							; back to absolute positioning
                      ;G1 X0 Y0 F2000				; centre the head and set a reasonable feed rate
                      homex.g
                      ; homex.g
                      ; called to home the X axis
                      ; generated by RepRapFirmware Configuration Tool on Sat Sep 29 2018 12:21:45 GMT-0700 (Pacific Daylight Time)
                      G1 S1 X-269 F1800 ; move quickly to X axis endstop and stop there (first pass)
                      G1 X5 F6000       ; go back a few mm
                      G1 S1 X-269 F360  ; move slowly to X axis endstop once more (second pass)
                      G1 Z-2.5 F6000 S2 ; lower Z again
                      homey.g
                      ; homey.g
                      ; called to home the Y axis
                      G1 S1 Y-261 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                      G1 Y5 F6000       ; go back a few mm
                      G1 S1 Y-261 F360  ; move slowly to Y axis endstop once more (second pass)
                      homez.g
                      ; homez.g
                      ; called to home the Z axis
                      G1 X51 Y20 F6000 ; go to first probe point
                      Slicer Script:
                      G28 ; home all axes
                      G29; BLTOUCH mesh generation
                      G92 E0.0
                      G1 Z5;
                      G1 X10 Y10 Z0 F6000;
                      G1 X60.0 E9.0  F1000.0 ; intro line
                      G1 X100.0 E12.5  F1000.0 ; intro line
                      G92 E0.0
                      • aidarundefined
                        aidar
                        I reccomend:
                        in your config M557 X50:200 Y50:200 S65 P3:3 remove either S or P parameter. As they both define probe spacing but in different way, having both of them may confuse all process. So M557 X50:200 Y50:200 P3:3 seems better.
                        In homeall.g remove M98 Pdeployprobe.g and M98 Pretractprobe.g commands. Firmware knows when to call them as you probe type is defined as bltouch(P9).
                        Delete homedelta.g file. Your printer is not delta, so you dont need it.
                        In your slicer script put M561 between G28 and G29 commands to cancel any mesh compensation before new probing.
                        • Elliotundefined
                          Elliot @aidar
                          @aidar Thanks.
                          I tested out the BlTouch and it deploys and retracts perfectly.
                          I then tried to do a mesh probe and it does the first corner but it only pushes the bltouch halfway back into place. It then proceeds to go round the rest of the corners without trying to test with the bltouch. It just pauses for a second in each place without lowering et.
                          The error I get at the end is:
                          Error: Z probe already triggered at start of probing move
                          • mendenmhundefined
                            mendenmh
                            The probe not being pushed all the way on the touch means you may have set your probe offset wrong. The printer will give up probing if it has to go below the programmed low limit on z. If you are zeroed just about where the probe would switch, it might give up too early.
                            Elliotundefined 2 Replies Last reply Reply Quote 0
                            • Elliotundefined
                              Elliot @mendenmh
                              @mendenmh When i home all axis it works perfectly. However, when I try to probe for mesh bed that's when I get an issue
                              • Elliotundefined
                                Elliot
                                Dont know if it is also related, I have seen two different lines for M558 which one is correct and what does the 'H','R', 'A', and 'B' stand for?
                                M558 P9 H9 F120 R0.2 T18000
                                M558 P9 F100 H5 R0.2 T6000 A5 B1
                                • aidarundefined
                                  aidar
                                  Looks like you should start reading here : https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type
                                  • Elliotundefined
                                    Elliot @mendenmh
                                    @mendenmh Thanks. How would I go about changing this?
                                    • aidarundefined
                                      aidar
                                      Some more reading will help: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                                      • Elliotundefined
                                        Elliot @aidar
                                        @aidar thanks. It is always good to refresh myself on that. That helped alot.
                                        The one remaining issue I have is that the probe goes down on the first location on the bed. Then it goes to the next, and deploys the probe it then doesn't retract. It will then just go to the positions and not try to probe. It then gets an error. If I manually lift the probe after it then goes to the next location and the same thing happens.
                                        After this is done, the bed is not leveled at all.
                                          What are you using for your M558 right now?
                                          Do you get any error messages in the console?
                                          • Elliotundefined
                                            Elliot @Phaedrux
                                            @Phaedrux
                                            The M558 I. Am using is:
                                            M558 P9 H5 F120 R0.2 T3000
                                            The error I get is:
