    Z-Axis correctly homing but crashes into the endstop on printing
    36
    6.1k
    • timcurtis67undefined
      timcurtis67
      What is the "G1 F9000" for?
      Its in this section of the program
      G92 E0 ;zero the extruded length again
      G1 F9000
      Maybe that is causing the crash?
        deckingman
        My best guess would be as follows but I'd need to know what maximum speed you've set for Z in your config.g.
        Towards the start of your gcode, there is G1 Z15.0 F9000. That is to say, move the Z axis 15mm at a speed of 9,000 mm/min which is pretty dammed high for the Z axis - it's 150mm per second and if you are using some sort of lead screws, I'd doubt that the machine is capable of that speed. So, you'll likely have skipped steps and the machine won't physically move that 15mm. So say for example that it only moves 10mm but the electronics "thinks" the bed is at 15mm away from Z=0. The next Z move is to go to 0.3mm at a speed of 3600 (still high IMO but more sensible). So the machine "thinks" it has to move the bed 14.7 mm to get to Z=0.3 but because the bed is only 10mm away from the nozzle, it'll crash.
        It's easy to check - just edit that Z15.0 F9000 to something like Z15.0 F600.
        AFAIK, the maximum speed you set in config.g should also limit the speed regardless of what the slicer tries to do (DC42 will confirm this or otherwise) so if you have that set high, reduce it to something sensible.
        HTH
        • CoolM8undefined
          CoolM8
          Nope Z15.0 F600 and Z0.3 F600 still give the same result. Because my Machine is an Ultimaker Original and rhe Profile in Cura is for the Ultimaker Original it should be able to do F9000.
            deckingman
            Oh well, it was just a thought (although I'd be amazed if your Z can travel at 150mm/sec). However, you've tried a slower speed so…...
            The only other thing that I can think of is are you sure you've got the steps per mm correct for Z? What do you have them set to and what is the lead (not pitch) of your screws?
            Edit, even if your machine is capable of 9000mm/min in Z , it's way too fast IMO - especially if you are using that sort of speed to home.
              timcurtis67
              I see what you are saying but if you look close in the program you posted you just have a "G1 F9000". No axis is called out on that line. I would remove that line and see if it corrects the crashing issue.
              This is where a single block button would be nice to have. All of the CNC machine I run have that switch to step through the program one line at a time. Its a big help for correcting program issues.
              • CoolM8undefined
                CoolM8
                No this doesn't work neither. Im gettig so frustrated, it all homes fine wen it starts the g-code file, then it moves to the center in X and Y and then it moves the Z-axis (I've even increaten from Z0.3 to Z0.6) but is still can watch how the platform hits the Z-axis enstop but carelessly continues to move upwards.
                  deckingman
                  Just to be clear. If you home Z, then do G1 Z0 does it go to the point where the nozzle is just touching the bed?
                    timcurtis67
                    @CoolM8:
                    Anyway you can post a video of this happening?
                    Is your Z home position down at the print bed where the nozzle touches the build plate or up with the nozzle at it highest point away from the build plate?
                    • CoolM8undefined
                      CoolM8
                      Here is a short video. You can clearly see that i the beginning the Z-axis correctly stops when the endstop triggers, but when it moves to the middle you can hear that the Z-axis turns further even though the endstop triggers.
                      https://youtu.be/93f6WJ-Ht1I
                      This is the test G-Code file:
                      [[language]]
                      ;Generated with Cura_SteamEngine 2.4.0
                      G21 ;metric values
                      G90 ;absolute positioning
                      M82 ;set extruder to absolute mode
                      M107 ;start with the fan off
                      G28 X0 Y0 ;move X/Y to min endstops
                      G28 Z0 ;move Z to min endstops
                      G1 Z15.0 F600 ;move the platform down 15mm
                      G1 F200 E6 ;extrude 6 mm of feed stock
                      ;Put printing message on LCD screen
                      M117 Printing...
                      ;LAYER_COUNT:199
                      ;LAYER:0
                      M107
                      G1 F1500 E-6.5
                      G0 F3600 X86.3 Y86.301
                      G0 F600 Z0.6
                      ;End of Gcode
                        T3P3Tony administrators
                        What is in your homing gcode files?
                        • CoolM8undefined
                          CoolM8
                          [[language]]
                          ; homeall.g
                          ; called to home all axes
                          ; generated by RepRapFirmware Configuration Tool on Thu Nov 17 2016 21:40:07 GMT+0100 (W. Europe Standard Time)
                          ; Relative positioning
                          G91
                          ; Lift Z
                          G1 Z5 F6000
                          ; Move towards X and Y axis endstops (first pass)
                          G1 X-215 Y-215 F1800 S1
                          ; Go back a few mm
                          G1 X5 Y5 F6000
                          ; Move slowly to axis endstops once more (second pass)
                          G1 X-215 Y-215 F360 S1
                          ; Move Z down until the switch triggers
                          G1 Z-210 S1 F1800
                          ; Absolute positioning
                          G90
                          ; Tell the firmware where we are
                          G92 Z2.5
                          ; Uncomment the following line to lift the nozzle after probing
                          ;G1 Z5 F100
                          [[language]]
                          ; homez.g
                          ; called to home the Z axis
                          ; Lift Z relatively to current position
                          G91
                          G1 Z5 F6000
                          G1 Z-210 S1 F1800
                          ; Back to absolute positioning
                          G90
                          G92 Z2.5
                          ;G91
                          ;G1 Z5 F100
                          ;G90
                          • Jackalundefined
                            Jackal
                            Your video is marked private, can't see it.
                            The line G92 Z2.5 after your homing sequence tells Duet your hotend is 2.5mm above the build plate while it is actually hitting the min-z endstop
                            If you go below Z2.5 afterwards the hotend will always move lower than when it hit the endstop (as in G0 F600 Z0.6 in your test)
                            Is that what you intend to do?
                            • Phytone3dundefined
                              Phytone3d
                              I had nearly exactly the same issue, and I started discussing on on reprapforums:
                              http://forums.reprap.org/read.php?416,745331
                              I fixed the issue by downloading a new configuration file (using exactly the same parameters). I've no idea what caused the first problem.
                              • CoolM8undefined
                                CoolM8
                                made the video public.
                                Well then i might try that as well with uploading a new config file with same parameters.
                                • Jackalundefined
                                  Jackal
                                  Before you overwrite everything, it is better to understand how it works so that you will be able to troubleshoot future problems.
                                  Start with removing the G92 Z2.5 line from the files and see what happens
                                  • Dougal1957undefined
                                    Dougal1957
                                    or even make the value for Z in that line to be negative just to give a margin of safety that change should make the nozzle 2.5 above the bed
                                      deckingman
                                      What has been throwing me is the title which starts "Z axis correctly homing…" but now I don't think it is homing correctly.
                                      Here is a quick explanation of how it works. Z=0 is the point where the nozzle is just touching the bed. We have some sort of probe or switch or whatever which will trigger when the bed gets close to it. However, it is very unlikely that the nozzle will be just touching the bed at this exact same position. It is possible but would require some very precise mechanical adjustment. So instead, we accept that the position where the switch/probe triggers is not Z=0 but is offset by some amount. Lets say the switch triggers 1.0 mm before the nozzle touches the bed. We then put this value into our configuration file which "tells" the machine that to get to Z =0 from the point where the switch triggers, we have to move a further 1.0mm.
                                      It seems to me that the trigger height is set to 2.5mm in the config.g file but the true distance between the switch triggering and the nozzle touching the bed is somewhat less. So the machine tries to move 2.5mm from the point where the switch triggers because that is what it has been "told" is the distance from this point to Z =0.
                                      • Jackalundefined
                                        Jackal
                                        Ian, I totally agree with you.
                                        I think some of these config files are generated by the online configuration tool, which may be misused by entry users.
                                        A review/rewrite maybe required to generate suitable config files.
                                        • CoolM8undefined
                                          CoolM8
                                          Yes, it seems that this was the issue. I've used the tool at reprapfirmware.org but I still don't really understand what the difference is between "Trigger height at Z axis" and "Trigger height on bed" which are shown when i chose de Switch Tab in the Z-Probe section. Both their tooltips are the same and it seems to me that their value should be the same too, so why do I have to configure both?
                                          Anyway, I got it almost working by manually adjusting the configuration file, but on the first try to print something, it failed because the hotend temperature sensor failed. i had the turn the printer off and on again in order to get it working again. Sadly after it failed a second time it went into reading 2000 degress since then. I'm using a PT-100 sensor and the daughter board and i even switched to the second RTD Pin but it's still reading 2000degrees. I've even replaced the sensor with no luck. Could it be that the daughter board is broken now or might it be the Duet itself?
