    Constant errors
    Duet Web Control
    1.9k
      PS - the procedure for using Bossa is the same as the procedure for Duet 2 described at https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3, except that the file to select is Duet3Firmware_MB6HC.bin.
        A Former User @dc42
        Wont that result basicly in a situation that i need to run first time setup again?
        If so im not mad enough to go thru the seven circles of hell, last time it was so fun there is no way im doing it again.
          A Former User
          Problem in DWC seems to be when running M997
          It seems to install and in console tab i get an error of Connection interrupted, attempting to reconnect...
            A Former User
            On the first time setup the largest anoyance is connecting to the duet with the DWC it wont establish an IP and my friend that works as an IT engineer did not find the problem that causes it.
              @Torppa said in Constant errors:
              No, because all the configuration data is held in files on the SD card.
                jay_s_uk
                IIRC, 3.0-beta12 had an issue that prevented updating from the SD card for some users.
                The only way to upgrade is to bossa the board.
                  A Former User
                  Super fun time, this thing is true POS...
                  Not even this BOSSA can do it, geting errors here and there.
                  Verify failed
                  Page errors:1114
                  Byte errors:563942
                  And now the board is compleatly useless...
                    Before you clicked Write in Bossa, did you (a) check Erase All, Lock, and Boot from Flash in Bossa; and (b) remove the Erase jumper from the Duet?
                      A Former User @dc42
                      Yes
                        A Former User
                        Stuck on Writing page 0 (0%) for the past 10min
                          jay_s_uk
                          What OS are you flashing from?
                            A Former User
                            Windows 10
                              jay_s_uk
                              Windows can be a bit odd sometimes.
                              It's possible to use bossa from a pi if you have one.
                                A Former User @jay_s_uk
                                @jay_s_uk
                                Hell no im not trowing any more money at this thing, like i have stated its discusting that the product quality is so bad.
                                  jay_s_uk
                                  I'm not suggesting you spend any more money.
                                  I was purely stating that windows can be odd with USBs (outside of the control of the Duet team).
                                  I would also suggest trying connecting through a USB hub (preferably powered) as your PC may not be able to supply enough power.
                                  If you don't have one of those but you have a laptop, you can power the Duet 3 using 12-32v and connect the laptop via USB and try that way. Just make sure the laptop is ran off battery power only.
                                    A Former User
                                    No luck, have none of those.
                                      A Former User
                                      What option do i have left, was able to aquire a laptop from my niece and even powering the duet with the PSU and trying with the laptop results in the same thing.
                                        Verify failed
                                        Page errors:1114
                                        Byte errors:563942
                                        This is almost exactly what I get when i use Bossa without removing the Erase jumper first. I am flashing version 3.1.1 so I get slightly different results:
                                        After removing the Erase jumper, pressing Write again and then Verify, it works:
                                        So please double check that you have removed the correct jumper:
                                          A Former User
                                          I did not have the jumpper on, still did the reset and erase again and no luck
                                            Looks like the MCU is not coming out of Erase mode. Try the following:
                                            • Put the Erase jumper on
                                            • Press the Reset button on the Duet
                                            • Remove the jumper
                                            • Press Reset again
                                            • Reconnect Bossa (you can normally just click on the COM port dropdown and select the same COM port again)
                                            • Ensure that Erase All, Lock and Boot to Flash are checked (but not the other boxes)
                                            • Press Write
                                            • Press Verify
                                            The Write operation should display a progress bar and take 15 seconds or longer.
