    Constant errors
    Duet Web Control
    1.9k
      jay_s_uk
      What OS are you flashing from?
        A Former User
        Windows 10
          jay_s_uk
          Windows can be a bit odd sometimes.
          It's possible to use bossa from a pi if you have one.
            A Former User @jay_s_uk
            @jay_s_uk
            Hell no im not trowing any more money at this thing, like i have stated its discusting that the product quality is so bad.
              jay_s_uk
              I'm not suggesting you spend any more money.
              I was purely stating that windows can be odd with USBs (outside of the control of the Duet team).
              I would also suggest trying connecting through a USB hub (preferably powered) as your PC may not be able to supply enough power.
              If you don't have one of those but you have a laptop, you can power the Duet 3 using 12-32v and connect the laptop via USB and try that way. Just make sure the laptop is ran off battery power only.
                A Former User
                No luck, have none of those.
                  A Former User
                  What option do i have left, was able to aquire a laptop from my niece and even powering the duet with the PSU and trying with the laptop results in the same thing.
                    @Torppa said in Constant errors:
                    Verify failed
                    Page errors:1114
                    Byte errors:563942
                    And now the board is compleatly useless...
                    This is almost exactly what I get when i use Bossa without removing the Erase jumper first. I am flashing version 3.1.1 so I get slightly different results:
                    After removing the Erase jumper, pressing Write again and then Verify, it works:
                    So please double check that you have removed the correct jumper:
                      A Former User
                      I did not have the jumpper on, still did the reset and erase again and no luck
                        Looks like the MCU is not coming out of Erase mode. Try the following:
                        • Put the Erase jumper on
                        • Press the Reset button on the Duet
                        • Remove the jumper
                        • Press Reset again
                        • Reconnect Bossa (you can normally just click on the COM port dropdown and select the same COM port again)
                        • Ensure that Erase All, Lock and Boot to Flash are checked (but not the other boxes)
                        • Press Write
                        • Press Verify
                        The Write operation should display a progress bar and take 15 seconds or longer.
                          A Former User @dc42
                          Does not work
                            Are you using VIN power to the Duet, USB power, or powering it some other way?
                              A Former User
                              BOSSA just wont write.
                              And USB power
                                USB power alone may be insufficient. Please read the notes on avoiding USB ground loop problems at https://duet3d.dozuki.com/Wiki/USB_ground_loops and try again with VIN power. I assume that you have the 5V regulator on the Duet enabled.
                                  A Former User
                                  Running on VIN and a laptop results in the same problem.
                                    Make sure that the PC and the Duet PSU are plugged into the same power distribution block then. Usually it's not a problem if they are not, but occasionally a home has faulty mains wiring.
                                      A Former User
                                      Not gonna risk it, unless duet waranty cowers a 5000€ pc.
                                        A Former User
                                        What i have tried so far.
                                        USB power only: Does not work
                                        USB power only nothing connected exept the USB: Does not work
                                        VIN and USB via a laptop: Does not work
                                        Used the jumppers and reset multiple times.
                                        Nothing works just like i expected.
                                          A Former User
                                          Found the real problem, its a bad solder joint in the sd card slot, multimeter temp probe reads 67C.
                                            A Former User @A Former User
                                            Found the real problem, its a bad soder joint in the sd card slot, multimeter temp probe reads 67C.
                                            What does "soder" mean ?
