    Constant errors
    Duet Web Control
    1.9k
      A Former User
      Problem in DWC seems to be when running M997
      It seems to install and in console tab i get an error of Connection interrupted, attempting to reconnect...
        A Former User
        On the first time setup the largest anoyance is connecting to the duet with the DWC it wont establish an IP and my friend that works as an IT engineer did not find the problem that causes it.
          @Torppa said in Constant errors:
          Wont that result basicly in a situation that i need to run first time setup again?
          No, because all the configuration data is held in files on the SD card.
            jay_s_uk
            IIRC, 3.0-beta12 had an issue that prevented updating from the SD card for some users.
            The only way to upgrade is to bossa the board.
              A Former User
              Super fun time, this thing is true POS...
              Not even this BOSSA can do it, geting errors here and there.
              Verify failed
              Page errors:1114
              Byte errors:563942
              And now the board is compleatly useless...
                Before you clicked Write in Bossa, did you (a) check Erase All, Lock, and Boot from Flash in Bossa; and (b) remove the Erase jumper from the Duet?
                  A Former User @dc42
                  Yes
                    A Former User
                    Stuck on Writing page 0 (0%) for the past 10min
                      jay_s_uk
                      What OS are you flashing from?
                        A Former User
                        Windows 10
                          jay_s_uk
                          Windows can be a bit odd sometimes.
                          It's possible to use bossa from a pi if you have one.
                            A Former User @jay_s_uk
                            @jay_s_uk
                            Hell no im not trowing any more money at this thing, like i have stated its discusting that the product quality is so bad.
                              jay_s_uk
                              I'm not suggesting you spend any more money.
                              I was purely stating that windows can be odd with USBs (outside of the control of the Duet team).
                              I would also suggest trying connecting through a USB hub (preferably powered) as your PC may not be able to supply enough power.
                              If you don't have one of those but you have a laptop, you can power the Duet 3 using 12-32v and connect the laptop via USB and try that way. Just make sure the laptop is ran off battery power only.
                                A Former User
                                No luck, have none of those.
                                  A Former User
                                  What option do i have left, was able to aquire a laptop from my niece and even powering the duet with the PSU and trying with the laptop results in the same thing.
                                    Verify failed
                                    Page errors:1114
                                    Byte errors:563942
                                    This is almost exactly what I get when i use Bossa without removing the Erase jumper first. I am flashing version 3.1.1 so I get slightly different results:
                                    After removing the Erase jumper, pressing Write again and then Verify, it works:
                                    So please double check that you have removed the correct jumper:
                                      A Former User
                                      I did not have the jumpper on, still did the reset and erase again and no luck
                                        Looks like the MCU is not coming out of Erase mode. Try the following:
                                        • Put the Erase jumper on
                                        • Press the Reset button on the Duet
                                        • Remove the jumper
                                        • Press Reset again
                                        • Reconnect Bossa (you can normally just click on the COM port dropdown and select the same COM port again)
                                        • Ensure that Erase All, Lock and Boot to Flash are checked (but not the other boxes)
                                        • Press Write
                                        • Press Verify
                                        The Write operation should display a progress bar and take 15 seconds or longer.
                                          A Former User @dc42
                                          Does not work
                                            Are you using VIN power to the Duet, USB power, or powering it some other way?
