    Z-Axis not homing
    My Duet controlled machine
    1.1k
      For the Z axis steps per mm you'll either need to find the previously used value or calculate it based on the lead screw specs using this formula:
      Z_steps_per_mm = (motor_steps_per_rev * driver_microstep) / screw_lead
      For the Z motor current, use 60-85% of the rated max of the motor. If it's too low, you may not get any movement at all. When you command movement do you hear anything from the motor itself? Change in pitch?
      If you connect a different motor to the Z axis, does it work?
      If you connect the current z motor to another driver, does it work?
      • aidarundefined
        aidar
        also check that second z motor connection have jumpers installed, as you have only one motor and those connectors are wired in series.
        • rickypilnikundefined
          rickypilnik
          For the calculation what is screw lead?
          Okay, I'll try the current adjustment and no upon attempted movement nothing is heard or changed. (I think this value is massively off as I j checked the motors and it says 2.5A on them)
          Before changing any settings I switched the Y and Z motors, and both worked, except a tiny increment in the z movement moved the Y a lot and a lot in the y-direction only moved the z a little. This makes me think it's all related to the steps per mm.
            Screw lead refers to the amount of movement produced per rotation. A very common lead screw type is TR8*8 which has a diameter of 8mm and one full rotation produces 8mm of lift. Other common sizes would be 1mm, 2mm, 4mm.
            rickypilnikundefined 1 Reply Last reply Reply Quote 0
              rickypilnik @Phaedrux
              @Phaedrux One more thing, I have steps set to *16 with interpolation to 256. Which value do I use?
                Phaedrux Moderator @rickypilnik
                x16 microstepping with interpolation to 256 means the firmware uses x16 microstepping for it's calculations and step pulse generation and then the drive chips take those pulses and cho them up into x256 stepping for the motors so they are quieter and smoother.
                So for your purposes, use x16.
                  rickypilnik
                  So I've adjusted all the values, X and Y axes home fine but the Z axis still won't home and I'm now getting this error.
                  "Error: short-to-ground reported by driver(s) 2"
                    Alright, now we're getting somewhere.
                    For the sake of completeness can you post your current config.g with your changes and describe how you're trying to move the axis?
                    Also, can you post a photo of the Z driver chip?
                      rickypilnik
                      config (2).g
                      I press the home Z button on DWC and nothing moves and I hear no noises.
                      (changed all motor currents to 1875mA (max is 2.5A) and Z steps per mm to 400. (200*16)/8 )
                        Swap the plug to the ZA port and put the jumpers on the ZB port and try again.
                          rickypilnik
                          Same as before. Z - Axis still not moving.
                            And just to eliminate the homing files, If you send M564 S0 H0 to allow unhomed axis movement are you able to get the z motor to move by using the jogging buttons?
                            And does it still produce the short to ground error message?
                              Can you also send M122 in the console and post the response?
                                rickypilnik
                                No I can't move the Z-axis, but x and y are fine even with the message of short to drivers from before.
                                m122
                                RepRapFirmware for Duet 2 Maestro version 3.1.1 running on Duet Maestro 1.0
                                Board ID: 08DJM-9X66L-LG3SN-6JKDL-3S06Q-K8X6P
                                Used output buffers: 3 of 24 (10 max)
                                Static ram: 21924
                                Dynamic ram: 92804 of which 52 recycled
                                Exception stack ram used: 392
                                Never used ram: 15900
                                Tasks: NETWORK(ready,472) HEAT(blocked,1324) MAIN(running,1996) IDLE(ready,84)
                                Owned mutexes:
                                Last reset 00:01:06 ago, cause: power up
                                Last software reset at 2020-05-20 19:20, reason: User, spinning module GCodes, available RAM 16096 bytes (slot 3)
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                                Error status: 0
                                MCU temperature: min 32.7, current 35.3, max 35.5
                                Supply voltage: min 0.0, current 15.4, max 15.7, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: standstill, read errors 0, write errors 0, ifcount 9, reads 2644, timeouts 0
                                Driver 1: standstill, read errors 0, write errors 0, ifcount 9, reads 2644, timeouts 0
                                Driver 2: short-to-ground, read errors 0, write errors 0, ifcount 9, reads 2644, timeouts 0
                                Driver 3: standstill, read errors 0, write errors 0, ifcount 7, reads 2646, timeouts 0
                                Driver 4: standstill, read errors 0, write errors 0, ifcount 6, reads 2647, timeouts 0
                                Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 2653
                                Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 2652
                                Date/time: 2020-05-20 19:32:27
                                Slowest loop: 10.29ms; fastest: 0.12ms
                                === Storage ===
                                Free file entries: 9
                                SD card 0 detected, interface speed: 15.0MBytes/sec
                                SD card longest read time 2.6ms, write time 0.0ms, max retries 0
                                Hiccups: 0(0), FreeDm: 168, MinFreeDm: 168, MaxWait: 26403ms
                                === MainDDARing ===
                                Scheduled moves: 14, completed moves: 13, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
                                === AuxDDARing ===
                                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                Bed heaters = 0 -1, chamberHeaters = -1 -1
                                Segments left: 0
                                Movement lock held by HTTP
                                HTTP is idle in state(s) 1 8, running macro
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 129.03ms; fastest: 0.02ms
                                HTTP sessions: 1 of 8
                                Interface state active, link 100Mbps full duplex
                                  @rickypilnik said in Z-Axis not homing:
                                  Does 15v sound correct for your power supply?
                                  The short to ground message was only for driver 2, correct?
                                    rickypilnik
                                    Yes 15V sounds correct and the message is
                                    " Error: short-to-ground reported by driver(s) 2 "
                                      Alright, I think we've established that the Z driver has failed unfortunately. Please hang on while I confer with DC42 in case he has any further ideas.
                                      When and where did you purchase your Duet 3?
                                        rickypilnik
                                        On the 5th May 2020, from E3D Online, and it's a Maestro
                                          Ah yes, sorry, Maestro.
                                            I think the reason I assumed it was a Duet 3 was because of this statement on motor current.
                                            These motors may not be well suited to the Maestro as it's drivers are rated for 1.4a peak. The Duet wifi is 2.4a and the Duet3 6.3.
                                            You'd have to run the drivers at full power to get close to 60% of the rated max for the motors. This will require actively cooling the driver chips.
                                            If you send M906 in the console, what does it report back with?
