    Duet 3 6hc and raspberry pi 3 B+ DCS not started
    Duet Web Control
    2.3k
      A Former User @Macgyver1307
      if you run sudo journalctl -u duetcontrolserver -e from ssh?
      • Macgyver1307undefined
        Macgyver1307
        @bearer said in Duet 3 6hc and raspberry pi 3 B+ DCS not started:
          Macgyver1307
            Macgyver1307
              Macgyver1307
                Macgyver1307
                  Macgyver1307
                    A Former User
                    Huh, interesting. Was it working with any previous version? You might want @chrishamm to take a look at this one.
                      Macgyver1307
                      never worked first set up and I'm new to Duet. but learning lots!
                        Macgyver1307
                        any other thought on fixes? I ordered a pi 4 and it will be here Tuesday. Should I try stand-alone mode? thanks
                          Macgyver1307
                          could I have a kernel issue on the PI?
                            Macgyver1307
                            I tried making up Dupont jumpers and replaced the ribbon cable and still the same results as above. I'm thinking a duet 3 bord issue? 802ea531-0774-41cb-a62f-c2fa94706f2c-image.png
                            • chrishammundefined
                              chrishamm administrators
                              The no header error message indicates that the transfer ready pin works OK but the SPI data transfer did not. If you are not using DuetPi, please make sure that the SPI buffer size is 8KiB:
                              pi@duet3:/home/pi# sudo cat /sys/module/spidev/parameters/bufsiz
                              8192
                              If it is still set to 4KiB (4096), create a file in /etc/modprobe.d as explained here.
                              Duet software engineer
                                Macgyver1307
                                @chrishamm said in Duet 3 6hc and raspberry pi 3 B+ DCS not started:
                                sudo cat /sys/module/spidev/parameters/bufsiz 8192
                                i checked and it is set to 8192
                                ![0_1590156191075_f7572f46-d5a7-4ae0-b56c-bc339ca49cc2-image.png](Uploading 100%)
                                  Macgyver1307
                                    I suggest you follow this post and check what happens: https://forum.duet3d.com/topic/15551/duet3-pi-flashing-diag-led-after-wiring-24v-dcs-is-unavailable/119?_=1590153541635
                                      @Macgyver1307 you can probably copy/paste the text from the terminal and save some bandwidth.
                                      Presumably you're using the DuetPi image?
                                      Lacking another Pi to test, as you already have the du-pont style wires ready you could try to use the SPI1 bus and edit /opt/dsf/conf/config.json. The SPI loopback testing doesn't test the clock signal from the Pi so its possible it could be bust I guess, but its hard to definitively point at one or the other without tools or replacements.
                                      ref pinout.xyz's nice pinout:
                                      (Or wait for the Pi4 come Tuesday)
                                        Macgyver1307
                                        yes sir! I started with that and did all of the testings from that post before I started this one. I can try the pin process again?
                                          @Macgyver1307 said in Duet 3 6hc and raspberry pi 3 B+ DCS not started:
                                          If you do, copy paste the output so we can catch anything amiss along the way. If using putty just use the mouse to drag and select text, which will automatically be copied to the clipboard ready to paste in the forum. Then highlight the text (in the forum post editor) and use the Code formatting button (5th button from the left after bold, italics etc).
                                            Macgyver1307
                                            ok sounds good ill start the process again and display the outputs. thanks for the help!
