    Duet 3 6hc and raspberry pi 3 B+ DCS not started
    Duet Web Control
    2.3k
    • Macgyver1307undefined
      Macgyver1307
        Macgyver1307
          A Former User
          Huh, interesting. Was it working with any previous version? You might want @chrishamm to take a look at this one.
            Macgyver1307
            never worked first set up and I'm new to Duet. but learning lots!
              Macgyver1307
              any other thought on fixes? I ordered a pi 4 and it will be here Tuesday. Should I try stand-alone mode? thanks
                Macgyver1307
                could I have a kernel issue on the PI?
                  Macgyver1307
                  I tried making up Dupont jumpers and replaced the ribbon cable and still the same results as above. I'm thinking a duet 3 bord issue? 802ea531-0774-41cb-a62f-c2fa94706f2c-image.png
                  • chrishammundefined
                    chrishamm administrators
                    The no header error message indicates that the transfer ready pin works OK but the SPI data transfer did not. If you are not using DuetPi, please make sure that the SPI buffer size is 8KiB:
                    pi@duet3:/home/pi# sudo cat /sys/module/spidev/parameters/bufsiz
                    8192
                    If it is still set to 4KiB (4096), create a file in /etc/modprobe.d as explained here.
                    Duet software engineer
                      Macgyver1307
                      @chrishamm said in Duet 3 6hc and raspberry pi 3 B+ DCS not started:
                      sudo cat /sys/module/spidev/parameters/bufsiz 8192
                      i checked and it is set to 8192
                      ![0_1590156191075_f7572f46-d5a7-4ae0-b56c-bc339ca49cc2-image.png](Uploading 100%)
                        Macgyver1307
                          I suggest you follow this post and check what happens: https://forum.duet3d.com/topic/15551/duet3-pi-flashing-diag-led-after-wiring-24v-dcs-is-unavailable/119?_=1590153541635
                            A Former User @Macgyver1307
                            @Macgyver1307 you can probably copy/paste the text from the terminal and save some bandwidth.
                            Presumably you're using the DuetPi image?
                            Lacking another Pi to test, as you already have the du-pont style wires ready you could try to use the SPI1 bus and edit /opt/dsf/conf/config.json. The SPI loopback testing doesn't test the clock signal from the Pi so its possible it could be bust I guess, but its hard to definitively point at one or the other without tools or replacements.
                            ref pinout.xyz's nice pinout:
                            (Or wait for the Pi4 come Tuesday)
                              Macgyver1307
                              yes sir! I started with that and did all of the testings from that post before I started this one. I can try the pin process again?
                                @Macgyver1307 said in Duet 3 6hc and raspberry pi 3 B+ DCS not started:
                                If you do, copy paste the output so we can catch anything amiss along the way. If using putty just use the mouse to drag and select text, which will automatically be copied to the clipboard ready to paste in the forum. Then highlight the text (in the forum post editor) and use the Code formatting button (5th button from the left after bold, italics etc).
                                  Macgyver1307
                                  ok sounds good ill start the process again and display the outputs. thanks for the help!
                                    Macgyver1307
                                    pi@duet3:~/spidev-test $ RDY=22 CS=24 ; {
                                    gpio -1 mode $CS out
                                    > gpio -1 mode $RDY in
                                    > gpio -1 write $CS 1 && echo "(Pin RDY/$RDY) `gpio -1 read $RDY` should equal `gpio -1 read $CS` (Pin CS/$CS)"
                                    > gpio -1 write $CS 0 && echo "(Pin RDY/$RDY) `gpio -1 read $RDY` should equal `gpio -1 read $CS` (Pin CS/$CS)"
                                    > { ~/spidev-test/spidev_test -v -s 8000000 -D /dev/spidev0.0 && echo RX should equal TX. ;} | tail -n3 | cut -b-100 ;}
                                    (Pin RDY/22) 1 should equal 1 (Pin CS/24)
                                    (Pin RDY/22) 0 should equal 0 (Pin CS/24)
                                    TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D
                                    RX | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                                    RX should equal TX.
                                    * list item
                                      Macgyver1307
                                      well I tried 22 to 28 ad 24 to 28 with the same output. I would post it but the form says its spam.
                                        Phaedrux Moderator @Macgyver1307
                                        3 posts in a row to the same thread in a short amount of time probably flagged you. Please try again.
                                          Macgyver1307
                                          I'm going to wait till Tuesday and loaded up a fresh pi -4 and see if I still have issues. thanks, Phaedrux!
                                            The first bit looks to confirm your Chip Select, and Ready pins are working but the next bit would suggest a problem with the jumper between MISO and MOSI or a problem with the Pi. Did you place a jumper over (physical) pins 19 & 21 as well as 22-24?
                                            This is also in line with the error from DSF.
