    Updated to RRF3, paneldue 7i stuck at "connecting"
    • likevviiundefined
      likevvii
      My paneldue can not connect to my duet wifi 2 anymore. It shows "connecting" on the top right.
      I updated my duet wifi 2 to RRF 3.1.1
      My panel due worked without failure before this.
      My old version was RRF 2.04
      I then proceeded to update my panel due firmware successfully and ended up with the same problem; stuck at "connecting" on the top right.
      My config file is stock and produced from the reprapconfigurator for V3+ with no extra additions.
      • sebkritikelundefined
        sebkritikel
        Add M575 P1 S1 B57600 to your config.g
        Had to do that myself with the upgrade to 3.1.0 from one of the RC versions I was on.
        Listed in the upgrade notes here for 3.1.0 :https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md
        Large(ish?) IDEX - 6HC, 1HCL
        Stratasys Dimension 1200es to 6HC Conversion
        • likevviiundefined
          likevvii
          Worked right away!
          How do I mark this post as solved?
