    New Large Format IDEX Printer Project
    My Duet controlled machine
    idex bondtech nema23 enclosure
    12
    33
    7.4k
    • sebkritikelundefined
      sebkritikel
      I'm pleased to share a personal project of mine, where the initial design started in late 2018, and purchasing started in March of 2019. By no means is this complete, but I'm at a point where I'm excited to share the progress I have made so far.
      Some background - My first real experience with 3D printing was in 2017 at the office; we had a Stratasys Dimension 1200es BST that wasn’t getting much use. I started printing practically anything I could think of, starting with a small hand tool, and progressing to much larger and more sophisticated designs. In early 2018 I got the go-ahead to propose search for a new 3D printer model that we would buy two of – because more is better, right? At that point I realized both the age of the Stratasys machine, as well as the wealth of hardware and software options for printers available at the time.
      We opted to go with two BCN3D Sigmax printers – dual extrusion was a must, the IDEX technology had some potential uses, and the large bed width was attractive. I spent quite a bit of time learning how to effectively operate those machines (they are surprisingly a lot of work!); later I picked up a used Davinci 1.0 and flashed it with Repetier, built a MPCNC, and eventually the Stratasys went belly-up and made its way home with me.
      My initial design objectives were to have a machine that…
      • Has a rigid frame
      • Has a limited number of 3D printed components
      • Has an enclosed and heated chamber
      • Has a large print area
      • Is capable of printing high temperature thermoplastics
      • Is capable of dual extrusion
      • Is capable of fast travel speeds with reasonable accelerations
      To start the design, I purchased two Rexroth ballscrews and 3x sets of IKO LWL12B 500mm rails with two ML12 each, sizing the frame to these components. Later on I purchased two LWHT15 200mm rails with a single carriage each for use with the ballscrews for the Z-Axis.
      Other design and component decisions:
      I wanted to utilize the Gates GT3 series of belts and compatible pulleys
      • For the Y-axis I selected 3mm belt pitch, 15mm belt width
      • For the X/U-axis, I selected 2mm belt pitch, 9mm belt width
      I wanted to balance speed and resolution
      • 16x microstepping, managing to achieve 100steps/mm in the X/U axis, 96steps/mm in the Y axis
      • Y axis is geared down with a 2.25:1 gear ratio to compensate for the heavier axis
      • X, U, and Y axis run at 300mm/s max speeds and 4000mm/s^2 acceleration
      For the Y-axis and Z-axis, stepper motors are NEMA 23
      • Oriental Motor PKP264D28AA2, .74 N*m, 2.8 A/phase, 1.5mH/phase
      • Set to 2.4A in config.g
      • Run super cool, barely feel warm to the touch
      X and U axis use NEMA 17
      • Oriental Motor PKP244D23A2, .48N*m, 2.3 A/phase, 1.9mH/phase
      • Set to 1.8A in config.g
      • These run quite a bit warmer than the NEMA 23s
      Slice Engineering Mosquito and Mosquito Magnum for hotends
      • Various nozzles (P3D, E3D NozzleX, Slice Vanadium
      • Slice thermistors and heaters
      • 12V Sunon fans
      5/16” ATP 5 plate, 1000W Keenovo heater, SDF DF240S thermal cutoff (200°C holding temperature)
      • TCO holding temperature may be a little high, but Keenovo recommended a maximum operating temperature of 204°C based on the 3M adhesive rating.
      • Three-point bed leveling with probing
      • Initially looked at a kinematic bed solution but opted for a fixed countersunk screw/spring combo, with two slotted countersinks sized and positioned to account for thermal expansion.
      Bondtech BMG-M extruders
      IDEX
      • I do enjoy the IDEX technology on the BCN3D printers but wanted something a bit more structurally sound. Mechanically, lots of inspiration taken from the Stratasys Dimension 1200es.
      Duet controller board(s) - Duet 2 Wifi, Duex5, PanelDue 7i
      Snap action homing switches for X, U, and Y
      • These have moved quite a bit as the design has evolved, I’m not happy with how they are mounted at the moment
      • Had a homing “oopsie” where the U assembly crashed into the X carriage, actually moving the switch mounting block, and messing up my calibration!
      Right now I’m looking at a print volume (single extruder) of 420mm x 450mm (475mm Y travel) x 210mm, losing ~100mm (to ~320mm) on the X and U axis for dual extrusion (lesson learned there!).
      The project so far has been a blast, with many lessons learned along the way. The X-U axis has by far been the most challenging to build and design, I’m on the second major iteration and I’m still not entirely pleased, although I am getting satisfactory print results. As this is my first printer design and build, it was challenging to prioritize assembly design priorities. With this project, despite having a good idea of the components I wanted on each hotend assembly, it was the last item I designed and built up – ends up my build plate was a bit too big, leaving me little room to have nozzle wipe stations, purge buckets, etc. On future projects I for sure have a better idea of what assemblies to prioritize, making further decisions based on the size and function of said assemblies.
      While working on this project, I did not initially intend to share the design files, however because of all that I learned from the fantastic content and individuals on this community and others, I figured I should give back and contribute this project.
      https://drive.google.com/drive/folders/12TOxGG-kKjuYwNuwhYpwor9TGhdfy2mg?usp=sharing
      The Google Drive link contains a Solidworks (19-20) pack-and-go, as well as assembly parasolids (.x_t) and IGS files. A (very!) rough BOM and various images and videos of my progress are also available.
      How have I done so far?
      • Has a rigid frame - definitely nailed this one! Almost entirely end tapped extrusions with fasteners + access hole
      • Has a limited number of 3D printed components - making progress, but not quite done. Y axis bearing holders, most of the hotend carriage assembly is still 3D printed
      • Has an enclosed and heated chamber - making progress on enclosure, have not installed+tested active chamber heating (excluding built plate)
      • Has a large print area - pretty satisfied
      • Is capable of printing high temperature thermoplastics - goes hand in hand with the heated enclosure, no issue with extruding 9085 PEI, but I have not tested an actual PEI print (the volume above the build plate stabilizing at 50°C without being fully enclosed, which is pretty neat, but not enough for PEI)
      • Is capable of dual extrusion - accomplished
      • Is capable of fast travel speeds with reasonable accelerations - accomplished
      Many thanks to Slice Engineering, PrintedSolid, and Filastruder ( @elmoret ) for fast shipping, excellent communication, and great customer service when it was needed, as well as to the Duet team for a fantastic product.
      Large(ish?) IDEX - 6HC, 1HCL
      Stratasys Dimension 1200es to 6HC Conversion
      zaptaundefined 1 Reply Last reply Reply Quote 9
        Thanks for sharing! Let us know how well it works.
        sebkritikelundefined 1 Reply Last reply Reply Quote 0
          sebkritikel @dc42
          @dc42 said in New Large Format IDEX Printer Project:
          While I still have a few issues to work out, I'm quite happy with how it runs. This is my first experience with the Duet line of products, and I was blown away with how easy initial setup was - definitely ruins other firmware and controller boards for me!
          A large PA6-GF30 print I did recently (model on the left, removed support on the right)
            sebkritikel
            Some mechanical updates (and lessons learned)! When this thread was posted, the X-U axis was on its second major revision. The initial design placed the steppers, belts, and idlers on the backside of the axis.
            On the 'low' side of the axis, a third ML12 block was used to join this axis to the Y-axis guide blocks and belt, with the intent to mitigate alignment or expansion issues. The issue with this X-U axis design was that the print area was limited because of the space occupied by the stepper motors and idlers.
            The second iteration placed the steppers, belts, and idlers on top of the axis.
            Previously the idlers were supported on both ends via a rotary shaft and two ball bearings, however the change in belt routing necessitated a change in how the idlers were mounted.
            Misumi configurable shoulder bolt, washers, idler, with flanged bearings. The problem here is that I had selected a 4mm shoulder diameter, and had the option to either select an M3 or M4 thread at the end - I opted to go with M4, and thus sized the through-hole in the plate to that diameter. When tightening the stackup, I compress the bearings, idlers, etc to the plate instead of just the threaded portion of the bolt to the plate (below left, area in red can be tightened).
            Had I gone with an M3 thread with the 4mm shoulder diameter (above right) the shoulder would have been tightened to the plate (via the hex nut or even a tapped hole), with the shoulder length specified to be equivalent to the washer, bearing, and idler stackup. As it is now I have to be mindful when tightening this section.
            Interesting design note, in order to match the bearing size, shoulder diameter, and idler counterbore, I needed to select (I believe) a minimum of a 24 tooth pulley. I designed the stepper mounting plates such that the belt segments the hotend carriages clamp to are parallel to the gantry.
            With the new X-U stepper and idler locations, I was able to center the 550mm length rail, however this required a short linear guide to be installed on the low side of the axis. Of course, with the stepper motor plate on the low side now mounted to a linear guide, I'm now tensioning the belts against a sliding surface... yes ultimately that side is mounted to a fixed surface (Y-axis guide), any misalignment would result in varying belt tension as the gantry travels up/down the Y-axis.
            I recently removed this short guide and have seen no ill effects, however the impact of thermal expansion cannot be discounted and should be investigated further.
            Some other neat stuff, build chamber is nearly completely enclosed, with the localized build envelope temperature stabilizing at 68°C with the print bed at 120°C. Some work is still needed on that front.
            Just yesterday I setup the tool needed for duplication printing - not the prettiest ABS prints (steep overhang, high print temperature, and no print cooling fans 🤠 ) but it worked well! Some goofy movements at the start and end, which I attribute to my tool change files, but overall pretty easy.
            https://www.youtube.com/watch?v=5FNhITS6L6I&feature=youtu.be
            An issue I am having is with the filament tubes and cable assemblies for each hotend bending and pressing down on the X and U belts. Somewhat self inflicted with the limited clearance above the hotend carriages, but still working through this issue.
            tekstyleundefined 1 Reply Last reply Reply Quote 2
            • Yeti.WSTundefined
              Yeti.WST
              @sebkritikel said in New Large Format IDEX Printer Project:
              e pr
              Thank you for sharing your design and lessons learned. Great design - looks very solid to me.
              • zaptaundefined
                zapta @sebkritikel
                @sebkritikel, that's a very impressive design.
                You have two brushes on the sides, are they used to clean the heads? Do they work well? (I may need something like that to occasionally cleaning the head when printing PETG).
                I think I recognize the power supply you are using. Does the fan turns on every minute or two and makes loud noise? I switched to this one which is fan-less https://www.amazon.com/gp/product/B07GPDRV7V
                  sebkritikel @Yeti.WST
                  @Yeti-WST said in New Large Format IDEX Printer Project:
                  e pr
                  Thank you! The list of lessons learned keeps growing the more I work on it 😀
                  @zapta said in New Large Format IDEX Printer Project:
                  Thank you!
                  The two brushes do work quite well - just cheap Harbor Freight brass detail brushes with the handle trimmed off. I typically purge the nozzles behind them, and then have a simple X and U tool cleaning macro that I can call from the PanelDue/web interface. These macros are also called in my tool change files. The key with the brass brushes is having the nozzles run over them in a zig-zag pattern at decent speed, rather than approaching and exiting the brush in a straight line. If I have a bit of crud built up on the nozzle and execute a cleaning macro, I can often hear the plastic flying off the brush as the brass wires whip back into position after the nozzle flies through them haha
                  G1 S2 X-260 Y235 F15000 ; brush home
                  G1 X-253 Y205.5 F15000
                  G1 Y225.5 F15000
                  G1 X-260 Y205.5 F15000
                  https://www.youtube.com/watch?v=YsUtwHki46w
                  Ideally it would also be good to have a silicone wiper in addition to the brush, similar to the Stratasys tip wipe solution.
                  Re: power supply - yup, have a MEAN WELL RSP-500-24, fan comes on periodically (and is definitely loud), although I'm not bothered by it. I was looking at the fan-less model, but oped for the RSP as it had a few more features I was thinking about using (remote sense and on-off control).
                  • zaptaundefined
                    zapta
                    @sebkritikel, the brushing in the video looks cool. Do you do it also during prints (e.g. every X layers)?
                    since you mentioned Stratesys I searched and found this patent https://patentimages.storage.googleapis.com/08/47/1b/42d482f76e4ad3/US7744364.pdf . Do you know if those stratasys brushes are available somewhere? Might be easier just to buy a few.
                    Edit: found this https://www.ebay.com/p/17007045322?iid=223634555307&thm=1000
                    • tekstyleundefined
                      tekstyle @sebkritikel
                      I was concern about too clearance as well for my idex I am building. Do you feed your filament from within the machine or from outside? If outside, do u have the filament above or below the printer?
                        sebkritikel @tekstyle
                        Glad you found that listing on ebay, some of the other places I looked (Stratasys resellers, etc) are selling them around $45 each!
                        @tekstyle said in New Large Format IDEX Printer Project:
                        I'm feeding the filament from outside the machine - I have extremely long guide tubes from the exterior of the machine to the direct drive extruders on each hotend. As it is now I have to hand feed filament from the spools through the tubes until it reaches the drive gears. I should build a cart/stand for the printer, could put filament storage underneath... more additions haha
                        zaptaundefined 1 Reply Last reply Reply Quote 0
                        • zaptaundefined
                          zapta @sebkritikel
                          I need to figure out where to install the brush on by HEVO printer. Your printer is IDEX and thus designed that the heads can move out of the bed area. On my single head printer, the frame is 'optimized' such that the nozzle can access the entire bed area but not beyond.
                          I think it will make a difference when with long PETG prints since there are little 'crumbs' that accumulate on the nozzle.
                            sebkritikel @zapta
                            Not sure if you have an unused driver on your duet (or an unused stepper laying around) but I've seen examples where the cleaning brush is attached to a motor and moved out of the way after cleaning the nozzle (rotating/retracting arm, etc).
                            Regarding how often I clean the nozzles - typically only after a purge/prime, so start of prints, after pauses, or between tool selections. If I'm running a multi material print (support, or a the second nozzle printing the infill, etc) it will clean the active nozzle every time there would be a tool switch, so typically every layer.
                            • laelundefined
                              lael
                              Beautiful work! What is your timeframe for insulation and an active heater? Are you going to try to run a retracting heat barrier at the top of the machine?
                                sebkritikel @lael
                                @lael said in New Large Format IDEX Printer Project:
                                Thank you!
                                I've been internally struggling with the active heater - as is the DC side is powered by a 500W power supply, with the bed heater sitting at 1000W on the AC. I'm worried that when adding in the fin strip heater I have that I'll be pushing the limits of an electrical outlet/breaker, but it would be nice to have the flexibility for additional/faster) heating. Right now with the bed at 120°C I see the build volume temperature stabilizing at about 68°C, and of course at higher bed temperatures the chamber temperature increases. Even at those temperatures the printer isn't fully enclosed yet! I'm missing insulation altogether on the top edge of the printer by the Y-axis stepper, and for the most part anything that is insulated on that side is thinly insulated at this time (when compared to the thick sides or top). On the sides and top the insulation is two .5inch layers of PIR foam (so one inch), and then one inch of open-cell polyethylene (at least I think its polyethylene and not polyurethane) foam. Some parts of the back are insulated with just a half inch layer of PIR foam.
                                I wanted to implement a thermal barrier like bellows, but because I've been developing and learning as I go (this is my first printer design and build) I might not have space for it with how much clearance I have between the Z-axis, frame, and print heads.
                                Once I finish enclosing the printer AND without a thermal barrier, I definitely think I'll need to investigate a venting solution to keep the temperature around 72-75°C to keep things safe for the stepper motors (assuming that the bed at 120°C will yield an enclosed chamber temperature of 72-75°C)
                                  dc42 administrators @sebkritikel
                                  What's the limit for an outlet in your country? Here in UK it's a little over 3kW, which would leave plenty for a chamber heater.
                                    sebkritikel @dc42
                                    I'm based in the US, so typically rated for 15 or 20amps, and looking at my breaker box that room is on a 15amp breaker - 1800W. Sitting at 12.5 amps now. I'm not using all 500W on the DC side (some back of the napkin math puts me at 350W) so I could run the heater in a limited capacity off that, but I would certainly need to investigate it further.
                                    While you're here, I'm curious if you could provide some insight into goofy "Tool 2" (duplication) start of print movement.
                                    https://www.youtube.com/watch?v=9kUz8KFMRlY&feature=youtu.be
                                    Relative files:
                                    ; tfree2.g
                                    ; called when tool 2 is freed
                                    M83 ; relative extruder movement
                                    G91 ; relative axis movement
                                    G1 Z3 F1200 ; up 3mm
                                    G90 ; absolute axis movement
                                    G1 S2 X-210 F18000 ; park the X carriage at -210mm
                                    G1 S2 U217 F18000 ; park the U carriage at 217mm
                                    G1 S2 X-260 F6000 ; park the X carriage at -260mm
                                    G1 S2 U267 F6000 ; park the U carriage at 267mm
                                    ; tpost2.g
                                    ; called after tool 2 has been selected
                                    M116 P2 ; wait for tool 2 heaters to reach operating temperature
                                    G1 E4 F900 ; extrude 4mm
                                    M98 P"/macros/X_Tool_Clean1.g"
                                    M98 P"/macros/U_Tool_Clean1.g"
                                    ; X_Tool_Clean1.g
                                    G90
                                    G1 Y225.5 F15000
                                    ; U_Tool_Clean1.g
                                    G90
                                    G1 S2 U267 Y235 F15000 ; brush home
                                    G1 U260 Y205.5 F15000
                                    G1 Y225.5 F15000
                                    G1 U267 Y205.5 F15000
                                    Example start of GCODE
                                    ; Generated with Cura_SteamEngine mb-master-20200321
                                    T2 ; Called before "start gcode" lines
                                    M190 S120; Called before "start gcode" lines
                                    M104 S285; Called before "start gcode" lines
                                    M109 S285; Called before "start gcode" lines
                                    M82 ; Called before "start gcode" lines
                                    G28 ;Home, first line of "start gcode"
                                    T2; call T2 again after bed probing (deselects all active tools)
                                    G1 Z15.0 F6000
                                    ;Prime the extruder
                                    G92 E0
                                    G1 F200 E10
                                    G92 E0
                                    The first X and U moves are not normally seen (including the extraordinarily slow movement back to the X homing switch). After homing (G28) and T2 is called again, I can see the X_Tool_Clean1.g macro executing, but during the first move the U axis moves to its offset position via G10. X_Tool_Clean1.g completes, but U_Tool_Clean1.g doesn't execute, or at least not correctly (both print heads bounce around). Z-axis moves down per start of print file, and then both extruders prime, although not over the last positions in the macros.
                                      sebkritikel
                                      Some exciting updates! I've done a good chunk of work on the assembly recently, which can be seen in the Google Drive here. Included with that is a much more detailed bill of materials which features sourcing information.
                                      Updates of note:
                                      • Added ~590mm length of angled aluminum to run on top of the X and U belt runs. I was having issues with the PTFE tube and wiring harnesses resting on the belts as the carriages moved around. This is really more of a patch, as the root cause is the fact my enclosure is too short, forcing the tubing and wiring downwards.
                                      • Finally fully enclosed the printer - I was only missing a few section in the rear previously, but those are now filled in. During the first print where I was monitoring the chamber temperature the chamber easily rose to 70°C within the first 30 minutes. At that point I got spooked, and dropped the bed temperature down to 100°C, trying to keep it at or below 70°C. I found that I could keep it between 69-70°C with the bed at 96°C. For reference, I typically keep the bed at 120°C, and with those back sections open, max out at 66-68°C
                                      In some other, not so exciting updates, I experienced my first heater fault (x-axis) and jam (u-axis) in the same print, roughly around the same time. Prior to this print, I reworked the X and U PTFE and wiring routes, fitting them both in the nylon webbing (previously I cable tied the filament tubes to the wiring harnesses). Before the modifications I had a thermistor attached to (and the hanging some) the X wiring harness, and used this to measure the chamber temperature. Worked well, as it was always a little above the actual X carriage, but mostly centered on the build plate. Started the roughly five hour, dual extrusion print (sans chamber thermistor), and halfway through I fitted the last few pieces of insulation in the back. Probably not the smartest idea I've had...
                                      I came back to the printer some time later, thinking the print was done. Saw that the support filament had stopped extruding a few layers prior to the print being suspended due to a heater fault on the other extruder. Opened up the web interface, but the fault in question had occurred outside of the 10minute window available for the temperature plots. Fault was similar to "Temperature excursion exceeded 15.0C". I'm confident in thinking that the jam was related to the chamber temperature - build plate was at 120°C, and I wasn't monitoring the chamber temperature, but I can't safely assume the temperature fault was due to the unknown increased chamber temperature - I don't have the greatest strain relief setup on the hotend carriages, and on inspection it appeared that there was quite a bit of tension on the thermistor connector at the hotend.
                                      Part of the jam in question - the length between the hotend and the BMG drive gears.
                                      I was able to easily upload a modified DWC version where I increased the plot range to 1 hour, should help in case I miss some other fault in the future.
                                      • mwolterundefined
                                        mwolter
                                        @sebkritikel Amazing printer and thank you for sharing and taking us along through the design and commissioning.
                                        Saw the image of the filament in your last post and wanted to share something that I’ve run into with using a mosquito in an enclosure. Not sure if it directly applies but it might.
                                        I’ve found that the stock mosquito fan doesn’t provide enough airflow to properly cool the cold side of the heat break when the environment temperature increases. This Increases the cold side temp of the hotend and causes the filament to soften, buckle and jams the hotend. Ultimately I went to a 40mm fan and reversed the airflow to draw air across the heat break. This has dramatically reduced the hotend jams. Might be something to look into.
                                          If that's still an issue with the latest 3.01-RC11 firmware, please start a separate thread about it.
                                            sebkritikel @mwolter
                                            @mwolter said in New Large Format IDEX Printer Project:
                                            Thank you! With the chamber fully enclosed now, I will definitely be monitoring the extruder performance much more closely. I feel that ABS, HIPS, nylon, and other similar filaments are much more tolerant of a smaller temperature gradient in the heat break, especially when compared to PLA. If I continue having issues I'll definitely look into different cooling solutions. What made you decide on reversing the direction of the airflow across the heatbreak?
                                            Not related to 3.01-RC11 at this time (still on 2.05.1). I think it is somewhat user error, created my T2 macros and toolchange files without really thinking about it. If/when I update, and if I have issues, I will create a separate thread.
