    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    23.0k
    • arhiundefined
      arhi @Danal
      @Danal said in DuetLapse available for Alpha testing:
      and I haven't been able to look at that mkv quite yet
      not much to see really, usb camera looking at the print, rpi camera looking at ceeling, you play the video and if your player support only one track you will see either part being printed or ceeling of my workshop, if player support multitrack you can switch between one or second video... so far did not find a way to see both tracks in the same time, exploring if that's possible, if not I'll try to make different videos then. What I do is make IMGA*.jpg and IMGB*.jpg, I make two mp4 videos (one from IMGA* other from IMGB*) and then I make a third video .mkv that combines first and second video
      • Danalundefined
        Danal @arhi
        @arhi said in DuetLapse available for Alpha testing:
        I do system service programming 10 hours a day in c/c++
        Then I have a really off the wall question for you:
        Do you know how to FORCE "Visual Studio Code" (Note: not Visual Studio) with PlatformIO installed running the Espressif32/ESPIDF platform, force it to compile a mixed source module project with C compiler for .c and .h files and C++ compiler for .cpp and .hpp files? I can handle the 'extern' and such for the cross-calling, so the linker is happy, no problem. I just need it to use the right #$% compiler.
        I thought the whole "use the right compiler by file extension" thing was automatic, and it seemed like it has worked before in VSC. However, at the moment, I have a project that throws tons of errors in the .cpp files, because it is treating them as .c.
        Like I said, off the wall, because it is a VERY narrow question: VSC (not VS), PlatformIO and Espressif32/ESPIDF...
        • zaptaundefined
          zapta @arhi
          I do system service programming 10 hours a day in c/c++ ...
          Then I have a trick question for you 😉 Give an example where the insertion of a space char between two tokens changes the semantic of the program.
          (inserting a space in a string literal doesn't count since it's not between two tokens).
          • arhiundefined
            arhi @Danal
            @Danal no idea, I'm mostly the "ssh to a dev machine and work in console", gui is not my thing. I use "visual studio code" only barely (learning go and rust) and that's it. For ESP32 I use basic arduino IDE, did not use it so far for anything serious, ESP8266 I did some "bigger" projects back in the day and with their whole SDK I used xtensa from them and made Makefiles manually, so easy to call gcc or g++ depending on the c/cpp extension. I had platformio setup on previous computer that went out in flames half a year ago and never redid the setup on the new one as I didn't find it very nice. Something about VSC is not sitting with me properly and PlatformIO was taking it too far. I'm the old style Makefile / autoconf and VIM 🙂 ... recently we moved to cmake but I still did not use cmake for any of my own projects and the cmake structure of mysql is maintained by someone else 🙂
            • arhiundefined
              arhi @zapta
              @zapta said in DuetLapse available for Alpha testing:
              u talking about +++ situation?
              • Danalundefined
                Danal @arhi
                Yeah, I have a lot of resonance with that. Nonetheless, breakpoints on the embedded board and hover the mouse over a variable (when paused) to see its value... that makes me put up with a lot from the IDE.
                You'll both appreciate this: I'm all over that very lower right magic dot...
                arhiundefined 1 Reply Last reply Reply Quote 1
                • arhiundefined
                  arhi @Danal
                  @Danal hahahahahhaha
                  I have to say, I learned to "take a walk" 🙂 .. it is the most effective one, 3d printers help big time here as I stop go fiddle with printer, return fresh :), kids arrived few years ago, they help even more 😄 ..
                  print("here") is my favorite debugging tool in "embedded" systems that I do as a hobby, on my day job it's rather useless 😞 so I never do it. On the other hand my daily job debugging in 90% cases the best I can do is crash a server and then go trough core, or follow the JAM log and go trough core. In the rare 10% of cases gdb connect to live server helps (my daily job is a verification and fixing of bugs in mysql server, I don't work on new features). TBH I'd love to use some good IDE for this but it's not that simple, I for e.g. need to debug a problem on 20+ cpu machine with a terabyte of RAM, big O will supply that machine in our lab in Norway for the duration of the work, or our lab in murica or ... but no way I will have that box at home :(. It might be possible that VS these days knows how to go through 2 layers of VPN and connect to a remote box trough access box and do this, but I have to say I have no clue how to set that up and since gdb works, even over shady network from screen I bite the bullet and do it that way. It's not too bad when you get used to it, not as easy as gui but works.
                  • zaptaundefined
                    zapta @arhi
                    Not related to +++. It's a trick question. Here is a hint: how the semantic of ' x(y) ' can be different than the semantic of ' x (y) ' ?
                    (the single quotes are not part of the code).
                    • arhiundefined
                      arhi @zapta
                      @zapta does sound vaguely familiar but no clue really. I assume it is most likely something obvious but my brain don't do tricks today 😞 and I don't think it's fair I go duckgogo-ing now to find a solution 😄
                      • luckyflyerundefined
                        luckyflyer
                        @Danal I've got the numpy required error on my Duet pi, you said in a previous post that "I've updated the script to show the required commands, if numpy is not found." I'm on your Duetlapse github wiki, usage section. I don't see any commands for if numpy not found. Where do I find them?
                        Also I've loaded everything onto a standalone pi and everything works except there is no video. I'm using a microsoft usb camera that works with motion eyes, I have the script set for usb camera. I read where someone else had this problem but was unable to follow what they did to correct, cuz I'm a noob with linux, would you please walk me through what I need to do to get video?
                        I'm not going to use the stand alone pi if I can get the Duet pi working but ask because I figure if its not working on the stand alone pi then it won't work on the Duet pi.
                        Tia
                        arhiundefined Danalundefined 2 Replies Last reply Reply Quote 0
                        • arhiundefined
                          arhi @luckyflyer
                          @luckyflyer this worked for me
                          apt-get install ffmpeg fswebcam wget
                          apt-get install libatlas-base-dev
                          apt-get install python3-numpy python-numpy
                          • Danalundefined
                            Danal @luckyflyer
                            @luckyflyer said in DuetLapse available for Alpha testing:
                            Tia
                            ahri's commands should work.
                            I was referring to having the script tell you that, instead of half a page of stack trace and a "numpy not found". I'll check and see if I did that or not...
                            • zaptaundefined
                              zapta @arhi
                              @arhi,
                              #define x(y)    y
                              #define x (y)   y
                              One is a macro with an argument and the other is a macro with zero arguments. It's a trick question. 😉
                                luckyflyer
                                Sorry for taking so long, duty called.
                                So what I'm getting now is this on all 3 of arhi's commands.
                                I cd to DuetLapse and tried again but got the same error.
                                E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
                                E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
                                  luckyflyer
                                  I think I fixed it by putting sudo in front of all 3 commands, testing now.
                                    luckyflyer
                                    I ran a small 30 layer print, played the file with vlc player and its just a blank screen. Of the three files only "sudo apt-get install libatlas-base-dev" was not present on the pi but I still get a blank screen. Are any of the 4 usb ports ok to use or just a specific one?
                                    • Danalundefined
                                      Danal
                                      Any port. If you haven't run DuetLapse again, and have not rebooted, all the stills are in the /tmp directory. You can look at them individually, and/or re-assemble them into a video.
                                        luckyflyer
                                        All of the stills are in the temp directory and look good on my standalone pi. How does one reassemble the stills into a video?
                                        Also on my Duet pi I'm still getting this,
                                        Python Library Module 'numpy' is required.
                                        Obtain via 'sudo python3 -m pip install numpy'
                                        Obtain pip via 'sudo apt install python-pip'
                                        When I run #2 I get,
                                        /usr/bin/python3: No module named pip
                                        When I run #3 I get
                                        python-pip is already the newest version (18.1-5+rpt1).
                                        Seems like I'm very close to it working but not there yet.
                                        • arhiundefined
                                          arhi @luckyflyer
                                          use ffmpeg
                                          ffmpeg -r 12 -i /tmp/DuetLapse/IMG%08d.jpeg -vcodec libx264 -y -v 8 finalvideo.mp4
                                            luckyflyer
                                            Thanks, just enter as you posted on the command line?
