    Unsure with Duet (RRF3) & Simplify3D
    811
    • arhiundefined
      arhi
      s3d uses
      M140 S100
      M190 S100
      to set bed temperature
      T0/1/2/3... irrelevant
      only thing important is to have M140 H0
      • botundefined
        bot
        What version of simplify3d are you using?
        Once you indicate that the heater controller is a heated bed, it shouldn't prevent you from choosing T0 for bed.
        It seems like a starting script or something is selecting T1 for your print. Are you trying to print with a second extruder? It should choose T0 for the print if not.
        *not actually a robot
        • zaptaundefined
          zapta @en_passant
          @en_passant, as a side note, S3D is a stale product. 😉
          Once you will have this working, you may want to consider one of the free slicers such as PrusaSlicer or Cura which are actively maintained.
          en_passantundefined 1 Reply Last reply Reply Quote 1
          • en_passantundefined
            en_passant @zapta
            @zapta said in Unsure with Duet (RRF3) & Simplify3D:
            Yeah... I was on simplify3d's forums trying to find an answer for this and seen a lot of very unhappy customers! I got an email about a year ago saying there was version 5 being introduced at the end of 2019, that then moved to the beginning of 2020... 🙄
            But, it's what I've got and would rather get the printer set up using something at least somewhat familiar before venturing off the beaten track... 🙂
            @bot said in Unsure with Duet (RRF3) & Simplify3D:
            I'm on 4.1.2. I quit and restarted it and I can now select primary extruder = T0 AND heated bed = T0.
            My config now has:
            M563 P0 D0 H1 S"Nozzle"			   			; tool 0 [hot end] define
            G10 P0 S0 R0		        				; tool 0 [hot end] operating & standby temps
            T0								; select t1 (hot-end)
            my starting script is:
            M104 S0				; cancel s3d set temp
            G21				; work in mm
            G92 E0				; reset extruder count
            M220 S100			; reset speed multiplier
            M104 T0 S140			; set hot-end to 140C
            M190 R50			; set bed temp to 50C & wait
            M104 T0 S175			; set hot-end to 175C
            M116 H1 S1			; wait: hot-end = 175 +/- 1C
            G1 E-20 F2500			; e -20mm (retract) @ 2500mm/min
            M116 H1 S2			; wait: hot-end = 140 +/- 2C
            G91				; relative co-ords (from last position not origin)
            G1 Z5 F1000 H1			; z 5mm @ 500mm/min (ensure it's below probe trigger height)
            G1 X-500 Y-500 F3000 H1		; x & y -500mm [relative] (> max) @3000mm/min - until limit sw. detects
            G1 X-500 H1			; x -500mm [relative] (> max) @ 3000mm/min - until limit sw. detects
            G1 Y-500 H1			; y -500mm [relative] (> max) @ 3000mm/min - until limit sw. detects
            G1 X5 Y5 F500			; x & y 5mm @ 500mm/min
            G1 X-10 H1			; x -10mm @ 500mm/min - until limit sw. detects
            G1 Y-10 H1			; y -10mm @ 500mm/min - until limit sw. detects
            G90				; absolute co-ords (relative to origin)
            G1 X172.5 Y172.5 F15000		; x & y 172.5mm [absolute] @ 15000mm/min
            G1 X177.5 Y177.5 F1000		; x & y 177.5mm [absolute] (bed-centre) @ 1000mm/min
            G30				; raise bed until probe triggered & set z to trigger height
            G1 Z5 F500			; z 5mm [absolute] @ 500mm/min (max speed)
            G1 X-172.5 Y-172.5 F15000 H1	; x & y -172.5mm [relative] @ 15000mm/min
            G1 X-50 Y-50 F1000 H1		; x & y -50mm [relative] (> max) @1000mm/min - until limit sw. detects
            G1 X-50 H1			; x -50mm (> max) @ 1000mm/min - until limit sw. detects
            G1 Y-50 H1			; y -50mm (> max) @ 1000mm/min - until limit sw. detects
            G1 E20 F2500			; e 20mm (extrude) @ 2500mm/min (cancel previous retract)
            T0				; select tool 0 (hot-end)
            M190 S[bed0_temperature]	; set bed temperature
            M109 S[extruder0_temperature]	; set hot-end temp
            G1 E10 F500			; extrude 10mm @ 500mm/min (prime)
            G1 X5 F10000			; x 5mm y 0mm [absolute] @ 10000mm/min (wipe start position: x 5 y 0)
            G1 Z0.10 F1000			; z 0.10mm [absolute] @ 1000mm/min (bed up to begin wipe)
            G1 X177.5 E5 F15000		; x 177.5mm [absolute] & extrude 5mm @ 15000mm/min (max) whilst z = 0.10mm [absolute] (nozzle wipe: extruding while moving)
            G92 E0				; set extruder position to 0
            but when I ran a test cube generated with those I get:
            24/05/2020, 21:52:59	Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
            The heated bed changed over from 50 to 55 just like I want but the hot-end is saying it's not hot enough.
            I now think this may be because (as I noticed when I heat the hot-end manually) I cannot extrude until 160. The reason I have 140 is because I have precision piezo and it's advised (and I did notice when I tested) it gets a bit spurious above that when doing G30.
            I did also have:
            M116 H1 S2			; wait: hot-end = [extruder0_temperature] +/- 2C
            but it seems to ignore the wait command?
            @arhi said in Unsure with Duet (RRF3) & Simplify3D:
            s3d uses
            M140 S100
            M190 S100
            Thanks @arhi. And the hot-end? It doesn't seem to pick up my M109 S[extruder0_temperature]...?
            e_p
            • botundefined
              bot
              For M116 try putting just the tool number with P0 instead of the heater number.
              Maybe also try setting temps with G10 and then waiting with M116 instead of both M109 and waiting.
              Other than that, I can't spot anything that seems amiss.
              en_passantundefined 1 Reply Last reply Reply Quote 0
                en_passant @bot
                Thanks @bot. I appreciate you taking the time to read my config & scripts.
                I just tried:
                M116 P0 S2			; wait: hot-end = [extruder0_temperature] +/- 2C
                to no avail. It doesn't even change the active temperature on DWC (though my bed is changing to 55 as I set it to in s3d).
                I suspect M109 S[extruder0_temperature] isn't correlating with s3d.
                Not sure how to implement G10 - as it mentions that (and appears so) that s3d uses M109?
                *e_p
                • botundefined
                  bot @en_passant
                  Since you can configure the start script with whatever you want, and when you include a temperature variable in the script, S3D suppresses its own M109 command, you can use G10 in the start script with no issues.
                  • arhiundefined
                    arhi @en_passant
                    @en_passant said in Unsure with Duet (RRF3) & Simplify3D:
                    s3d generates for me
                    M140 S100
                    M190 S100
                    M104 S255 T0
                    M109 S255 T0
                    bed 100C, hotend 255C
                    works as expected
                    • arhiundefined
                      arhi
                      my suggestion - forget about S3D
                      execute M-code manually trough DWC and see if it works
                      if everything works ok (M140, M190, M104 and M109) only then move forward to s3d
                      for me, I don't have much of code in s3d at all.
                      start code:
                      end code:
                      s3d relevant configuration:
                      print_start.g on the RRF:
                      ; no volumetric extrusion
                      M200 D0
                      ; relative extruder distance
                      M83
                      ; do not home if already homed
                      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                        G28
                      ; do the wipe
                      M98 P"wipe.g"
                      ; use MESH compensation
                      G29S1
                      ; all currents to 100%
                      M913 X100 Y100 Z100
                      ; load default jerk, speed and acceleration values
                      M98 P"cfg_jerkspeedaccel.g"
                      ; reset baby steps
                      M290 R0 S0
                      ; reset speed overrides
                      M221 S100
                      M220 S100
                      ; Dynamic Acceleration Adjustment
                      ; M593 Fxxx
                      ; Pressure Advance
                       M572 D0 S0.042
                      and print_stop.g
                      M104 S0 ; turn off extruder
                      M140 S0 ; turn off bed
                      M106 S0 ; turn off fan
                      M913 X20 Y20 Z25
                      G91
                      G0Z10
                      G90
                      M913 X100 Y100 Z100
                      M98 P"wipe.g"
                      • arhiundefined
                        arhi
                        head of the generated file that works
                        ; G-Code generated by Simplify3D(R) Version 4.1.2
                        ; configuration dump
                        G90
                        M83
                        M106 S0
                        M140 S85
                        M190 S85
                        M104 S240 T0
                        M109 S240 T0
                        M98 P"print_start.g"
                        ; process Process1
                        ; layer 1, Z = 0.500
                        ;M118P0S"MESSAGE: TOOL CHANGE"
                        T0
                        G1 E-0.1000 F3000
                        ;M118P0S"MESSAGE: LAYER CHANGE"
                        ; feature skirt
                        ; tool H0.500 W0.648
                        G1 Z0.500 F600
                        G1 X-4.272 Y11.571 F12000
                        G1 E0.1000 F3000
                        G1 X-4.278 Y-31.610 E5.1186 F360
