    1.18 Z height offset question
    1.9k
    • mhackneyundefined
      mhackney
      It was previously -.15 mm
      My 3D Printing blog: http://www.sublimelayers.com
      Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
        I think that reduction in trigger height was spurious, nothing to do with the firmware upgrade. If anything, the trigger height should be higher using 1.18, not lower.
        • mhackneyundefined
          mhackney
          I've gone through the printer mechanics and configs and it is still behaving as described. Multiple deletes of config-override and resets. It's almost as if G31 Z offset is not being applied.
          • mhackneyundefined
            mhackney
            David, I downgraded to 1.17 and my original Z offset is working perfectly. I'll re-convert to 1.18 when I get time early this week and try again.
              Michael, have you tried printing using 1.18 and your old height offset?
                @mhackney:
                That can happen if you put the G31 command earlier in config.g than the M558 command. This is because RRF stores different G31 parameters for different types of Z probe, to allow you to use more than one probe.
                • mhackneyundefined
                  mhackney
                  @dc42:
                  David, yes that is actually what I was trying to articulate above. With the same height offset I had to baby step down an additional 0.20mm. If I then change my height offset to -.35mm I STILL have to baby step down .20mm. That's what's strange. I see your second post about order so let me verify that, although once committed to config-override.g the correct order is captured, correct?
                  • mhackneyundefined
                    mhackney
                    @dc42:
                    @mhackney:
                    Understood and I do have them in the correct order. I actually take advantage of the ability to support different probes on one of my test machines that has the IR probe, FSRs and an accelerometer probe on it so I can do comparisons. On this machine I have:
                    [[language]]
                    ; Z probe and compensation definition
                    M558 P4 X0 Y0 Z0 F250 H3 I1 T3500
                    ; grid compensation
                    M557 R110 S15
                    G31 T4 X0 Y0 Z-.20			; Set the z probe offset and threshold
                      As long as you had the correct probe type selected when you sent the G31 command, then M500 will save it correctly in config-override.g. The G31 commands in that file use the T parameter to say what probe type they refer to. As far as I know, that parameter works correctly. If you suspect it doesn't, run G31 Tn where n is your probe type (as in M558 P parameter) and it will tell you the trigger height that it is using.
                      • mhackneyundefined
                        mhackney
                        Today I built a new CF card from a backup set of config files I had. I turned off the printer, installed the new card and restarted. Verified that there was no config-override.g, checked my offsets, Z height and other calibration settings. All looked good. Calibrated, looked good (0.01 deviation) then I verified height and it seemed spot on. Started a print and the first layer looks fine. I'm waiting for it (1 layer) to complete so I can verify thickness.
                        But it does seem like I must have displeased the 3D Printing Deities this weekend and now I'm back in good standing.
                        • sLpFhaWKundefined
                          sLpFhaWK
                          hopefully my red head sacrifice takes hold and the gods will be pleased with me. we'll find out tomorrow, I don't wish to pursue any 3d printing tonight.
                          -sLpFhaWK
                          Ultibots K250v
                          Rostock Max v2 Soon to be Full MetalMax
                          Mini Kossel
