    Duet3D Mainboard+Daughter board+PT100
    1.5k
    • Reaperrhsundefined
      Reaperrhs @Reaperrhs
      @Reaperrhs ; Heaters
      M308 S0 P"spi.cs0" Y"rtd-max31865" ; configure sensor 0 as thermocouple via CS pin spi.cs0
      M950 H0 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 1
      M143 H0 S450 ; set temperature limit for heater 1 to 450C
      M307 H0 A512.3 C269.6 D3.6 S1.00 V24.0 B0 ; disable bang-bang mode for heater and set PWM limit
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out0" T1 ; create bed heater output on out0 and map it to sensor 1
      M307 H1 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H1
      Reaperrhsundefined 1 Reply Last reply Reply Quote 0
        @Reaperrhs the one on the top is for my hotend, is the one with the PT100
        Carloundefined 1 Reply Last reply Reply Quote 0
        • Carloundefined
          Carlo @Reaperrhs
          @Reaperrhs
          Just copy and paste mine in comment your lines out ; line by line so you dont need to delete it
          M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
          M307 H0 A122.0 C513.7 D0.5 S1.00 V24.0 B0 ; disable bang-bang mode for the bed heater and set PWM limit
          M308 S1 P"spi.cs0" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs0
          M143 H1 S450 ; set temperature limit for heater 1 to 450C
          M307 H1 A512.3 C269.6 D3.6 S1.00 V24.0 B0 ; disable bang-bang mode for heater and set PWM limit
            Reaperrhs @Carlo
            @Carlo HOTEND Working Thanks!!!
            • Carloundefined
              Carlo @Reaperrhs
              @Reaperrhs
              Ok change the position of your bed thermistor on the board to 0 and you should be done.
                Reaperrhs
                thank you guys, i will never get it done on my own, one more thing my heated bed has a ntc 100k, I need to configure that to, can you guys help me?
                • Carloundefined
                  Carlo @Reaperrhs
                  @Reaperrhs
                  So is mine
                    Reaperrhs
                    the sensor on my bed is reading -273, I change the pin on my board to 0 and i left config as it is
                    • Carloundefined
                      Carlo @Reaperrhs
                      @Reaperrhs
                      Add that
                      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                      In place of
                        Reaperrhs
                        i comment out the one i have and copy
                        Still reading -273
                        • Carloundefined
                          Carlo @Reaperrhs
                          @Reaperrhs
                          What printer is it ? or bed heater ?
                            Reaperrhs
                            to be exact is a silicone pad that I using on my heated bed
                            • Carloundefined
                              Carlo @Reaperrhs
                              @Reaperrhs
                              Change to B3950
                                Reaperrhs
                                i think is the thermistor, i plug a didn't one and is reading, so..i really want to thanks for the help, you guys get this thing working, big thumbs up to you guys
