    Duet3D Mainboard+Daughter board+PT100
    1.5k
    • Carloundefined
      Carlo @Reaperrhs
      @Reaperrhs
      There is a space before the Y M308 S1 P"spi.cs0" Y"rtd-max31865"
      Reaperrhsundefined 1 Reply Last reply Reply Quote 0
      • Reaperrhsundefined
        Reaperrhs @Carlo
        @Carlo no luck so far, i have to double-check everything, also.. can you tell me whats define by the S1? because that's the only thing we have different
        Carloundefined 1 Reply Last reply Reply Quote 0
        • Carloundefined
          Carlo @Reaperrhs
          @Reaperrhs
          That's the Sensor number 1 so my bed is Sensor 0 ,hot end single hot end on my setup #1
            jay_s_uk
            maybe attach a photo of the daughterboard and wiring as you've installed it?
            • JoergS5undefined
              JoergS5
              and the current heater config please
                Reaperrhs @jay_s_uk
                  Reaperrhs @Reaperrhs
                  @Reaperrhs ; Heaters
                  M308 S0 P"spi.cs0" Y"rtd-max31865" ; configure sensor 0 as thermocouple via CS pin spi.cs0
                  M950 H0 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 1
                  M143 H0 S450 ; set temperature limit for heater 1 to 450C
                  M307 H0 A512.3 C269.6 D3.6 S1.00 V24.0 B0 ; disable bang-bang mode for heater and set PWM limit
                  M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                  M950 H1 C"out0" T1 ; create bed heater output on out0 and map it to sensor 1
                  M307 H1 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                  M140 H1
                    @Reaperrhs the one on the top is for my hotend, is the one with the PT100
                    • Carloundefined
                      Carlo @Reaperrhs
                      @Reaperrhs
                      Just copy and paste mine in comment your lines out ; line by line so you dont need to delete it
                      M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
                      M307 H0 A122.0 C513.7 D0.5 S1.00 V24.0 B0 ; disable bang-bang mode for the bed heater and set PWM limit
                      M308 S1 P"spi.cs0" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs0
                      M143 H1 S450 ; set temperature limit for heater 1 to 450C
                      M307 H1 A512.3 C269.6 D3.6 S1.00 V24.0 B0 ; disable bang-bang mode for heater and set PWM limit
                        Reaperrhs @Carlo
                        @Carlo HOTEND Working Thanks!!!
                        • Carloundefined
                          Carlo @Reaperrhs
                          @Reaperrhs
                          Ok change the position of your bed thermistor on the board to 0 and you should be done.
                            Reaperrhs
                            thank you guys, i will never get it done on my own, one more thing my heated bed has a ntc 100k, I need to configure that to, can you guys help me?
                            • Carloundefined
                              Carlo @Reaperrhs
                              @Reaperrhs
                              So is mine
                                Reaperrhs
                                the sensor on my bed is reading -273, I change the pin on my board to 0 and i left config as it is
                                • Carloundefined
                                  Carlo @Reaperrhs
                                  @Reaperrhs
                                  Add that
                                  M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                                  In place of
                                    Reaperrhs
                                    i comment out the one i have and copy
                                    Still reading -273
                                    • Carloundefined
                                      Carlo @Reaperrhs
                                      @Reaperrhs
                                      What printer is it ? or bed heater ?
                                        Reaperrhs
                                        to be exact is a silicone pad that I using on my heated bed
                                        • Carloundefined
                                          Carlo @Reaperrhs
                                          @Reaperrhs
                                          Change to B3950
                                            Reaperrhs
                                            i think is the thermistor, i plug a didn't one and is reading, so..i really want to thanks for the help, you guys get this thing working, big thumbs up to you guys
