    Help needed with Duet 3 6hc TMC5160 StealthChop config
    86
    13.0k
    • danym21undefined
      danym21
      has some bring StealthChop running on a Duet 3?
      when I search here in the forum it looks like only problems with a maestro was fixed the issues with the duet 3 looks all
      still open.
      has someone the maestro running with RR 3?
      @dc42 do you have some tips that I can try or what is wrong with my configuration?
        I am not aware of any bugs in this area, but have added this to my list of things to test prior to the 3.01 release of RRF.
        danym21undefined 1 Reply Last reply Reply Quote 0
        • danym21undefined
          danym21 @dc42
          @dc42 this means I have nothing wrong in my config? 😧
          I was hoping that I have done something wrong.
            I don't see anything wrong with your config, and M569 P0 says the threshold speed for changing to spreadCycle should be around 110mm/sec. That speed won't be exactly right because it depends on the accuracy of the 12MHz clock in the TMC5160.
            • danym21undefined
              danym21 @dc42
              @dc42 ok then I have to wait for your tests and hope we can find a solution.
              let me know when I can help here with testing etc.
                From my reading of the datasheet, you should always have THIGH < TPWMTHRS. Have you tried setting THIGH to values below 34?
                • danym21undefined
                  danym21 @dc42
                  @dc42 said in Help needed with Duet 3 6hc TMC5160 StealthChop config:
                  THIGH
                  I think I had done is the H parameter right?
                  I will try again.
                    dc42 administrators @danym21
                    @danym21 said in Help needed with Duet 3 6hc TMC5160 StealthChop config:
                    THIGH
                    I will try again.
                    Yes. Use M569 with just a P parameter to check that you have set it.
                    danym21undefined 2 Replies Last reply Reply Quote 0
                    • danym21undefined
                      danym21 @dc42
                      @dc42 I have tried with H10 for X and Y achses (P0.0 and P0.1) nothing changed, StealthChop only works below F119 all above only Spreadcycle from the noise.
                      M569 P0.0
                      Drive 0 runs in reverse, active low enable, step timing fast, mode stealthChop, ccr 0x08053, toff 3, tblank 1, hstart/hend/hdec 5/0/0, pos 548, tpwmthrs 34 (110.3 mm/sec), thigh 10 (375.0 mm/sec)
                      M569 P0.1
                      Drive 1 runs in reverse, active low enable, step timing fast, mode stealthChop, ccr 0x08053, toff 3, tblank 1, hstart/hend/hdec 5/0/0, pos 884, tpwmthrs 34 (110.3 mm/sec), thigh 10 (375.0 mm/sec)
                      to be sure also tested :
                      M569 P0.0 S0 D3 V34 H50                            ; physical drive 0 goes forwards D2=Spread cycle (x-achses)
                      M569 P0.1 S0 D3 V34 H50                            ; physical drive 1 goes forwards D2=Spread cycle (y-achses)
                      13.5.2020, 22:17:07 	M569 P0.1
                      Drive 1 runs in reverse, active low enable, step timing fast, mode stealthChop, ccr 0x08053, toff 3, tblank 1, hstart/hend/hdec 5/0/0, pos 972, tpwmthrs 34 (110.3 mm/sec), thigh 50 (75.0 mm/sec)
                      13.5.2020, 22:17:01 	M569 P0.0
                      Drive 0 runs in reverse, active low enable, step timing fast, mode stealthChop, ccr 0x08053, toff 3, tblank 1, hstart/hend/hdec 5/0/0, pos 540, tpwmthrs 34 (110.3 mm/sec), thigh 50 (75.0 mm/sec)
                      13.5.2020, 22:16:07 	G0 X130 Y130 F90
                      13.5.2020, 22:15:51 	G0 X135 Y135 F90
                      now also G0 X130 Y130 F90 runs only in SpreadCycle
                      • danym21undefined
                        danym21 @dc42
                        @dc42 was you able to test?
                        I have also tried to change the D settings on a test print to hear some changes, but nearly nothing has changed only on D0 (constant off-time)
                        he goes a little bit louder but not much. D1 (random off-time) is not supported by TMC5160.
                        can it be that my board is faulty or that the Firmware has a Bug and only shows the corect mode but not send to the stepper drivers?
                        • danym21undefined
                          danym21
                          I have seen the source code "/src/Movement/StepperDrivers/TMC51xx.cpp"
                          constexpr float SenseResistor = 0.050;
                          when I right on other firmware´s I use 0.075, can this create a difference?
                          Is it possible to play with over the M569 command or is it needed to compile new, have not found in the Duet documentation.
                          • cjackson234undefined
                            cjackson234
                            I'm experiencing the same thing @danym21.
                              cjackson234
                              Are there any updates on this?
                              • danym21undefined
                                danym21 @cjackson234
                                @cjackson234
                                still not 😞
                                  I'm sorry for the delay. This is still on my list to continue investigating. As it's a noise issue not a functionality issue, it has lower priotity then some others on my list.
                                  • Alex_Zundefined
                                    Alex_Z
                                    Hello! The same thing on my CoreXY using Duet3. Does anyone have found a solution?
                                    • danym21undefined
                                      danym21
                                      no sorry 😞
                                        My suspicion is that the issue is not following the tuning sequence specified by Trinamic. In particular, you are supposed to energise the motors, keep them still for a short while (but less than 130ms), then execute a medium speed move such as a homing move. Here is an extract from the datasheet:
                                        Typically, homeall.g does something like this:
                                        G91
                                        G1 H2 Z5 Fxxx
                                        G1 H1 X-400 Fxxx
                                        The initial pause at standstill is after powering up the motors is not present. So perhaps this would be better:
                                        G91
                                        G1 H2 Z0.02 Fxxx
                                        G4 P50
                                        G1 H2 Z5
                                        G1 H2 X0.02 Fxxx
                                        G4 P50
                                        G2 H1 X-400
                                        Similarly for Y. The 0.02mm figure should be adjusted so that it is at least one microstep, but preferably not much more than that.
                                        • danym21undefined
                                          danym21 @dc42
                                          it looks like it does not help, I have created the following test macro file, but I can´t hear any difference only on still stand after moves I can hear the motors a little bit when Spread cycle (D2) is enabled.
                                          maybe I have done something wrong?
                                          ; first test with stealh enabled
                                          M18						   ; disable all motors to reset the stepper drivers
                                          M569 P0.0 S0 D3 V34                                ; physical drive 0 goes forwards D2=Spread cycle (x-achses)
                                          M569 P0.1 S0 D3 V34                                ; physical drive 1 goes forwards D2=Spread cycle (y-achses)
                                          M569 P0.2 S0 D3 V34                                ; physical drive 2 goes backwards D2=Spread cycle (Z1)
                                          M569 P0.3 S0 D3 V34                                ; physical drive 3 goes backwards D2=Spread cycle (Z2)
                                          M569 P0.4 S1 D3 V34                                ; physical drive 4 goes backwards D2=Spread cycle (extruder)
                                          M569 P0.5 R-1                                      ; physical drive 4 goes backwards D2=Spread cycle (empty)
                                          M584 X0.0 Y0.1 Z0.2:0.3 E0.4                       ; Driver 0 For X, 1 for Y, Z=2:3 U=4, Extruder 4
                                          M350 X32 Y32 Z16 E16 I1                            ; configure microstepping with interpolation - working
                                          M92 X400.00 Y400.00 Z400 E412.00                   ; set steps per mm
                                          M566 X300.00 Y300.00 Z24.00 E300.00                ; set maximum instantaneous speed changes (mm/min) from config file thingiverse
                                          M203 X14000 Y14000 Z4520 E7000                     ; set maximum speeds (mm/min) new test Z800 old
                                          M201 X1000 Y1000 Z1400.00 E5000                    ; set accelerations (mm/s^2) own
                                          M906 X1150 Y1150 Z850 E600 I50                     ; set motor currents (mA) and motor idle factor in per cent
                                          G1 H2 Z0.02 F3000		; enable the Motor move at least one mircostep  -- Problem Stealthchop?
                                          G4 P50					; make a 50ms pause for the drivers  -- Problem Stealthchop?
                                          G1 H2 Z15 F6000         ; lift Z relative to current position
                                          G1 H2 X0.02				; enable the Motor move at least one mircostep -- Problem Stealthchop?
                                          G1 H2 Y0.02				; enable the Motor move at least one mircostep -- Problem Stealthchop?
                                          G1 H1 X-355 Y355 F9000  ; move quickly to X or Y endstop and stop there (first pass)
                                          G1 H1 X-355             ; home X axis
                                          G1 H1 Y355              ; home Y axis
                                          G1 X5 Y-5 F9000         ; go back a few mm
                                          G1 H1 X-355 F360        ; move slowly to X axis endstop once more (second pass)
                                          G1 H1 Y355              ; then move slowly to Y axis endstop
                                          G90                     ; absolute positioning
                                          G1 X177.713 Y144.526 F9000 ; go to first bed probe point and home Z --> own direct system
                                          G30                     ; home Z by probing the bed
                                          G1 Z15 F6000           ; lift Z relative to current position
                                          ;smal test moves
                                          G0 X0 Y0 F3000
                                          G0 X0 Y310 F3000
                                          G0 X310 Y310 F3000
                                          G0 Y0 Y0 F3000
                                          ; now again with Spread cycle
                                          M569 P0.0 S0 D2                                    ; physical drive 0 goes forwards D2=Spread cycle (x-achses)
                                          M569 P0.1 S0 D2                                    ; physical drive 1 goes forwards D2=Spread cycle (y-achses)
                                          M569 P0.2 S0 D2                                    ; physical drive 2 goes backwards D2=Spread cycle (Z1)
                                          M569 P0.3 S0 D2                                    ; physical drive 3 goes backwards D2=Spread cycle (Z2)
                                          M569 P0.4 S1 D2                                    ; physical drive 4 goes backwards D2=Spread cycle (extruder)
                                          ;smal test moves
                                          G0 X0 Y0 F3000
                                          G0 X0 Y310 F3000
                                          G0 X310 Y310 F3000
                                          G0 Y0 Y0 F3000
                                          empi00undefined 1 Reply Last reply Reply Quote 0
                                          • empi00undefined
                                            empi00
                                            I have also to reply here.
                                            I have Moon Motors.
                                            I think even the same as you. Need to check in detail, but i think so.
                                            I starte with a Duet Wifi clone and they were really noise in some higher speed (>70mm/s)
                                            So i decided to go for the Duet3 and the advanced TMC5160, as noise is key for my MGN cube. (CoreXY)
                                            In fact now, if i switch to stealthchop, it is even "noisier" than in spreadcycle.
                                            No such a "high" noise, but louder....
                                            I am lost now...
