    Need help installing ustreamer
    135
    10.7k
    • luckyflyerundefined
      luckyflyer
      Well I guess I need to admit I don't know how to save a file in linux. I googled "how to save a file with raspbian command line" but they talk more about editing files. Can you give me the exact syntax for saving these files.
      Looks like an editor like nano may be the way to save files, trying to figure it out.
        A Former User @gtj0
        @gtj0 said in Need help installing ustreamer:
        /etc/udev/rules.d/80-ustreamer.rules
        so run sudoedit /etc/udev/rules.d/80-ustreamer.rules and paste
        KERNEL=="video0", SUBSYSTEM=="video4linux", TAG+="systemd", ENV{SYSTEMD_WANTS}+="ustreamer@%k.service"
        into it. hit ctr + x to exit the editor (say yes to save on your way out)*.
        similar for /etc/systemd/system/ustreamer@.service
        *) edit: this assumes the default EDITOR enviornment variable is set to nano, but if you've changed it you probably know how to use the editor:)
          luckyflyer
          Thank you sir.
            luckyflyer
            @gtj0 ,
            I have both files entered and saved, rebooted but am unable to log onto http://0.0.0.0:8080 or my printers address http://192.168.0.181:8080. I've double checked that everything is correct, I removed "--encoder=HW and -m JPEG" from /etc/systemd/system/ustreamer@.service: since they don't apply to my camera. But have tried it with and without those two items.
            It starts up ok if I use the start script.
              luckyflyer
              This happens when I try to start the service manually,
              pi@duet3:~ $ sudo systemctl start ustreamer@.service
              Failed to start ustreamer@.service: Unit name ustreamer@.service is missing the instance name.
                A Former User
                @luckyflyer said in Need help installing ustreamer:
                this seems to be a so called template service, so it needs the name in the invocation; sudo systemctl start ustreamer@video0.service
                which probably means Description=UStreamer for video0 should be changed to Description=UStreamer for %I but doesn't affect the issue at hand I believe.
                • gtj0undefined
                  gtj0
                  @luckyflyer Yeah sorry about that. I should have given more compete instructions. @bearer is correct about being a template service and has the correct command line to manually start and stop the service.
                  I don't see (or don't remember) whether the camera you're using is a USB cam or a MIPI cam directly attached to the Pi's camera connector. If it's a USB camera, then here are updated service and rules files that will automatically stop the service when the device disconnects..
                  /etc/udev/rules.d/80-ustreamer.rules:
                  ACTION=="add", KERNEL=="video0", SUBSYSTEM=="video4linux", TAG+="systemd", ENV{SYSTEMD_WANTS}+="ustreamer@%k.service"
                  ACTION=="remove", KERNEL=="video0", SUBSYSTEM=="video4linux", RUN+="/bin/systemctl --no-block stop ustreamer@%k.service"
                  [Unit]
                  [Service]
                  Type=simple
                  ExecStart=/usr/local/bin/ustreamer --exit-on-parent-death -r 640x480 --static /tmp/ -d /dev/%i --host=0.0.0.0 --port=8080
                  [Install]
                  WantedBy=multi-user.target
                  As a reminder... "0.0.0.0" is a special IP address that tells server software to listen for connections on all ip addresses on the system. It can never be used to actually connect to anything.
                    luckyflyer
                    @gtj0,
                    Yes usb cam, I will try this in about an hour. Thanks to you and @bearer .
                      A Former User @gtj0
                      @gtj0 thanks for sharing this, gonna have to try with with my auto--bossac-recovery plan.
                      re: 0.0.0.0 that had me questioning a few things (in the sense OP said he could connect to it)
                        luckyflyer
                        What mipi camera do you guys recommend for print monitoring? I've been looking at the arducam v2 https://www.amazon.com/Arducam-Raspberry-Official-Megapixel-Acrylic/dp/B083FNFPF2/ref=sr_1_3?dchild=1&keywords=arducam+v2&qid=1590854384&sr=8-3
                        Or is there something better out there.
                        • Dougal1957undefined
                          Dougal1957 @luckyflyer
                          Have you seen this one High Res PI Camera with interchangeable lens
                          luckyflyerundefined 1 Reply Last reply Reply Quote 0
                            luckyflyer @Dougal1957
                            @Dougal1957
                            Nice looking cam , I would like to buy from a US vendor if possible, is it available here anywhere?
                            gtj0undefined Dougal1957undefined 2 Replies Last reply Reply Quote 0
                            • gtj0undefined
                              gtj0
                              The downside of RPi cameras is the distance limit and the flat ribbon cable. You get a lot more choices if you use a USB camera.
                              I use this one
                              https://www.amazon.com/gp/product/B07HVT2XZL/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
                              because it has LED illumination, is easy to mount, move, and use for other things if needed.
                              • gtj0undefined
                                gtj0 @luckyflyer
                                @luckyflyer You can get RPi cameras with interchangeable lenses on Amazon. Here's one...
                                https://www.amazon.com/Arducam-Camera-Raspberry-Interchangeable-LS-2717CS/dp/B012ETE75I/
                                  @Dougal1957
                                  I would have thought it would be as it is an official Raspberry device https://www.raspberrypi.org/products/raspberry-pi-high-quality-camera/
                                  and 2 meter long cables are available for cheap as well https://shop.pimoroni.com/products/raspberry-pi-camera-cable?variant=10312200583 don't know what effect they would have mind
                                    luckyflyer
                                    @gtj0 But don't the mipi cams offer greater programmability and flexibility than usb cams?
                                    A picture of the back of my printer, a 30 cm cable would be perfect, up to the top and out.!P1030087.JPG
                                      @luckyflyer I don't really know as I don't have one yet but am considering one with possible a wide angle lens on it not a cheap combination mind
                                      • mdevaevundefined
                                        mdevaev
                                        Sup. The ustreamer developer here. I am glad that you use my software, but just in case I want to warn those who want to use RPi CSI cameras: it doesn't work with ustreamer. The reason is that these cameras use their own specific non-v4l2 driver. It is possible to configure them as v4l2, but this requires research and I have not yet addressed this issue. So if you don't want any problems, use regular USB cameras.
                                        Quick answers to old questions:
                                        • 0.0.0.0 is a special address that means "listen all ipv4 interfaces". If you choose this option, you can connect to the streamer via the ip address of your network card or localhost (127.0.0.1).
                                        • You can't listen to port 80 unless you are root or have the CAP_NET_BIND_SERVICE capability (blah-blah-blah the network magic). If you want to run ustreamer via systemd on port 80 under non-root user, you need to add a parameter AmbientCapabilities=CAP_NET_BIND_SERVICE to the Service section
                                        • Use the HW encoder: almost all cameras support it.
                                        • If you're afraid that someone will see your video, use password authorization. It's better than nothing.
                                        PS: I was just passing by, so if you need any help, go to discord, the link is in the ustreamer repository on github.
                                          Dougal1957 @mdevaev
                                          @mdevaev Thank you very much for that info just saved me a ton of cash
                                            luckyflyer
                                            Wow, good to know.
