    GCode to view start print height?
    401
    • joehsmashundefined
      joehsmash
      perhaps im misunderstanding how this all goes together.
      i have now manually leveled my bed with a .20mm feeler gauge,
      the mesh seems to be working fine. only i cant get my first layer height dialed in.
      i have my g31 set to -0.20 and the micro stepping only seems to work so far. last couple of first layer test prints seem to only curl the PLA on the bottom of the nozzle, baby stepping it down doesn't seem to do anything. to the point i had it down to -9 and it still wasn't laying plastic down.
      with me doing the manual bed probing it was suggested to me to disable my ir probe in my bed.g, than manual probe, and re-enable.
      how do i set my first layer height with this board?
      ideally when i click print my nozzle should already be at my first layer height.
      is there a GCODE to view what the current zheight offset is?
        dc42 administrators @joehsmash
        How are you homing Z? Please post homeall.g and homez.g.
        joehsmashundefined 2 Replies Last reply Reply Quote 0
          joehsmash
          0:/sys/homeall.g
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 11 2020 00:13:11 GMT-0600 (Mountain Daylight Time)
          G91 ; relative positioning
          G1 H1 X-110 Y-122 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000 ; go back a few mm
          G1 H1 X-110 Y-122 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G90 ; absolute positioning
          G1 X0 Y0 F6000 ; go to first bed probe point and home Z
          ;G91 ; relative positioning
          ;G90 ; absolute positioning
            joehsmash @dc42
            @dc42 ; homez.g
            ; called to home the Z axis
            G1 X0 Y0 F6000 ; go to first probe point
              joehsmash @dc42
              @dc42 i take that back, it seems the mesh isnt even doing anything.. while its printing i cant see the either of the z axis adjusting
                joehsmash
                absolute rubbish first layer.....
                im starting to think this swap was a mistake lol
                  joehsmash
                  Realized i didnt load the height map in the config.g
                  added
                  ;Bed
                  G29 S1 P"heightmap.csv" ;Load manual probed heightmap
                  config.g
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 11 2020 00:13:10 GMT-0600 (Mountain Daylight Time)
                  M550 P"JoehBo3D" ; set printer name
                  M552 S1 ; enable network
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  M569 P3 S0 ; physical drive 3 goes forwards
                  M569 P4 S1 ; physical drive 4 goes forwards
                  M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
                  M671 X-160:160 Y0:0 S1 F1 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                  M208 X-110:110 Y-122:122 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
                  M350 X16 Y16 Z16 E16 I1 ; configure microstepping without interpolation
                  M92 X80 Y80 Z800 E790 ; set steps per mm
                  M566 X1020 Y1020 Z24 E3000 ; set maximum instantaneous speed changes (mm / min)
                  M203 X6000 Y6000 Z180 E8000 ; set maximum speeds (mm / min)
                  M201 X6000 Y6000 Z100 E3000 ; set accelerations (mm / s ^ 2)
                  M906 X935 Y935 Z935 E935 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X-110 Y-122 Z0 S0 ; set axis minima
                  M208 X110 Y122 Z203 S1 ; set axis maxima
                  M558 P1 H3 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                  G31 P600 x-2 Y-24 Z-0.135 ; set Z probe trigger value, offset and trigger height
                  M557 X-108:108 Y-110:98 S100 ; define mesh grid
                  M305 P1 T100000 B4388 R4700 ; set thermistor + ADC parameters for heater 1
                  M143 H1 S300 ; set temperature limit for heater 1 to 300C
                  M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P1 S1 I0 F500 H1:1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  ; Bed
                  G29 S1 P"heightmap.csv" ; Loads manual probed height map
                  M501 ;
                    joehsmash
                    also just realized i could just
                    g29 s1
                    and it will auto load the heightmap.csv...
                    durrr
                    • fcwiltundefined
                      fcwilt
                      I think you are better off setting the Z=0 datum with G30 and then loading the height map with G29 S1 at the start of each print.
                      This should take into account any changes in Z=0 as the bed heats.
                      joehsmashundefined 1 Reply Last reply Reply Quote 1
                        joehsmash
                        getting there, still incredibly inconsistant though
                          joehsmash @fcwilt
                          @fcwilt im trying that right now, adjusted my g30 and added g29 s1 to the starting script on slicer
                          • taconiteundefined
                            taconite
                            Hey,
                            so when you set the Z=0 Datum, it makes sence, that you can't move the printhead down by -9 mm because of the axis limits.
                            You may want to allow movement below 0 to accomplish that (But with Caution!!)
                            M208 Z-3 S1 ; set minimum Z
                            Best Regards
                            Adrian
                            Custom ANET A8
                            Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
                            All I do here is under this license: CC BY-NC-SA
                            • fcwiltundefined
                              fcwilt @joehsmash
                              @joehsmash said in GCode to view start print height?:
                              If I wasn't clear let me try again. The G30 should also be part of the starting script.
                              I don't like having GCode in the slicer. I use M98 to execute GCode that I maintain on the Duet.
                              I have M98 P"printbegin.g" and M98 P"printend.g" entered into the appropriate places in the slicer setup.
                              printbegin.g has the G30 and the G29 S1 commands. It also has commands to wait for the hotend and bed to reach working temp, to prime the hotend with filament and others.
                                joehsmash
                                Ive decided to scrap all of this and i tore off my crappy ir probe and went back to my z switches. i cant get any repeatability out of it, one small nudge and everything is gone.
