    GCode to view start print height?
    401
    • joehsmashundefined
      joehsmash @dc42
      @dc42 ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 11 2020 00:13:11 GMT-0600 (Mountain Daylight Time)
      G91 ; relative positioning
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; go to first probe point
      ;G91 ; relative positioning
      ;G90 ; absolute positioning
        joehsmash @dc42
        @dc42 i take that back, it seems the mesh isnt even doing anything.. while its printing i cant see the either of the z axis adjusting
          joehsmash
          absolute rubbish first layer.....
          im starting to think this swap was a mistake lol
            joehsmash
            Realized i didnt load the height map in the config.g
            added
            ;Bed
            G29 S1 P"heightmap.csv" ;Load manual probed heightmap
            config.g
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 11 2020 00:13:10 GMT-0600 (Mountain Daylight Time)
            M550 P"JoehBo3D" ; set printer name
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P3 S0 ; physical drive 3 goes forwards
            M569 P4 S1 ; physical drive 4 goes forwards
            M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
            M671 X-160:160 Y0:0 S1 F1 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
            M208 X-110:110 Y-122:122 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
            M350 X16 Y16 Z16 E16 I1 ; configure microstepping without interpolation
            M92 X80 Y80 Z800 E790 ; set steps per mm
            M566 X1020 Y1020 Z24 E3000 ; set maximum instantaneous speed changes (mm / min)
            M203 X6000 Y6000 Z180 E8000 ; set maximum speeds (mm / min)
            M201 X6000 Y6000 Z100 E3000 ; set accelerations (mm / s ^ 2)
            M906 X935 Y935 Z935 E935 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X-110 Y-122 Z0 S0 ; set axis minima
            M208 X110 Y122 Z203 S1 ; set axis maxima
            M558 P1 H3 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
            G31 P600 x-2 Y-24 Z-0.135 ; set Z probe trigger value, offset and trigger height
            M557 X-108:108 Y-110:98 S100 ; define mesh grid
            M305 P1 T100000 B4388 R4700 ; set thermistor + ADC parameters for heater 1
            M143 H1 S300 ; set temperature limit for heater 1 to 300C
            M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M106 P1 S1 I0 F500 H1:1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            ; Bed
            G29 S1 P"heightmap.csv" ; Loads manual probed height map
            M501 ;
              joehsmash
              also just realized i could just
              g29 s1
              and it will auto load the heightmap.csv...
              durrr
              • fcwiltundefined
                fcwilt
                I think you are better off setting the Z=0 datum with G30 and then loading the height map with G29 S1 at the start of each print.
                This should take into account any changes in Z=0 as the bed heats.
                joehsmashundefined 1 Reply Last reply Reply Quote 1
                  joehsmash
                  getting there, still incredibly inconsistant though
                    joehsmash @fcwilt
                    @fcwilt im trying that right now, adjusted my g30 and added g29 s1 to the starting script on slicer
                    • taconiteundefined
                      taconite
                      Hey,
                      so when you set the Z=0 Datum, it makes sence, that you can't move the printhead down by -9 mm because of the axis limits.
                      You may want to allow movement below 0 to accomplish that (But with Caution!!)
                      M208 Z-3 S1 ; set minimum Z
                      Best Regards
                      Adrian
                      Custom ANET A8
                      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
                      All I do here is under this license: CC BY-NC-SA
                      • fcwiltundefined
                        fcwilt @joehsmash
                        @joehsmash said in GCode to view start print height?:
                        If I wasn't clear let me try again. The G30 should also be part of the starting script.
                        I don't like having GCode in the slicer. I use M98 to execute GCode that I maintain on the Duet.
                        I have M98 P"printbegin.g" and M98 P"printend.g" entered into the appropriate places in the slicer setup.
                        printbegin.g has the G30 and the G29 S1 commands. It also has commands to wait for the hotend and bed to reach working temp, to prime the hotend with filament and others.
                          joehsmash
                          Ive decided to scrap all of this and i tore off my crappy ir probe and went back to my z switches. i cant get any repeatability out of it, one small nudge and everything is gone.
