    Offset for Dual Y Endstop?
    CNC
    • jan19undefined
      jan19
      I have just been converting a CNC router to a duet 2 ethernet board.
      Everything seems to work fine.
      I am running two seperate steppers on Y with an endstop each.
      Using marlin I used to be able to square off the axis perfectly by setting up an offset for the endstops using the M666 command.
      Is there a way to do something similar on the duet 2?
      Firmware is 3.11
        You can do this in the homey.g file. After homing both motors together, use M584 to temporarily reassign Y to just one of the motors; then you can use a G1 Y move to move just that one a little. Then use M584 to assign Y to both motors again.
        If your homeall.g file homes Y without calling homey.g, then you will need to do the same in the Y homing sequence within homeall.g.
        FelixHundefined 1 Reply Last reply Reply Quote 0
        • jan19undefined
          jan19
          Great, thank you!
          • FelixHundefined FelixH referenced this topic
          • FelixHundefined
            FelixH @dc42
            @dc42 would the G31 command not work on that situation?
