    Logic Level shifter for 12864 display on Duet 2 Wifi
    200
    16.5k
    • Schmartundefined
      Schmart @oliof
      @oliof This is the wiring I used without the inverter.
      So to be clear and safe, this is very specific wiring to connect the Duet 2 Maestro to a Creality ST7565-based MiniPanel display @3.3v logic levels.
      The pinout of displays made vary wildly, and the connectors on display-side may need to be reversed (the plastic shroud rotated 180 degrees). Also, the firmware adaptations I made in my fork are relatively easy to change for the Duet 2 Wifi, but I believe you would need to make changes in the Pins.h specific to the board and maybe also in Display.cpp (for now).
      Edit: Since @oliof is using the exact same Creality MiniPanel display from the CR-20, I have adjusted the diagram to match the exact orientation of the display connectors on that specific display. The tab goes on the side of pin #1.
      Creality CR-20 Pro with a Duet 2 Maestro, 3Dfused X+Z-axis rail kit, HIWIN-based DIY solution for the Y-axis, E3D Hemera, working ST7565 MiniPanel and various other small hardware improvements.
      • oliofundefined
        oliof
        @Schmart said in Logic Level shifter for 12864 display on Duet 2 Wifi:
        I have a Creality minipanel I want to use, so we're in the clear there. I'll check how Pins.h need to be adapted if I get around to it before this lands in 3.2 or beyond.
        Schmartundefined 1 Reply Last reply Reply Quote 0
        • Schmartundefined
          Schmart @oliof
          @oliof That would be so cool if you'd get it working as well. I'm not at my computer anymore, but I believe I'm using ‘M918 P2 E4 F2000000‘ in my config.g.
            Please note, the wiring diagram posted by @Schmart above is not the wiring arrangement that will be supported in RRF 3.2. The wiring arrangement in 3.2 is listed in this post https://forum.duet3d.com/post/157139.
            Schmartundefined antlobundefined 2 Replies Last reply Reply Quote 1
            • Schmartundefined
              Schmart @dc42
              @dc42 I saw the post, it wasn't clear to me if this was for the Duet 2 Wifi/Ethernet only or also for the Maestro?
              oliofundefined dc42undefined 2 Replies Last reply Reply Quote 0
              • oliofundefined
                oliof @Schmart
                @Schmart I'd assume it will be the same for either.
                  dc42 administrators @Schmart
                  It's for Duet WiFi/Ethernet. For the Maestro, I chose pin exp.pa21 to connect A0 to (same as in your diagram). To avoid having to invert the CS signal in hardware, I am considering requiring CS of a 7567-based display to be connected to exp.pa22.
                  • antlobundefined
                    antlob @dc42
                    @dc42 Can you please confirm if that wire arrangement ( https://forum.duet3d.com/post/157139.) will work not only for the MINI LCD 12864 but also for a standart LCD 12864, mine is a BigtreeTech. Many thanks! If that's the case from lines 11 to 17 I must connect them only if I want the LCD 12864 SD Card support, right? If I prefer the one on the panel due I only need to connect the LCD 12864 to ConnLCD on the Duet 2 Wifi, right?
                    antlobundefined A Former User? 2 Replies Last reply Reply Quote 0
                    • antlobundefined
                      antlob @antlob
                      @antlob Hello! Anybody? Please help!
                      • oliofundefined
                        oliof
                        @antlob I can confirm that the BTT TFT2.4 12864 emulation works on the Duet Maestro which indicates it's an ST7920 and will need a logic level shifter (and a custom firmware build) for the Duet2 Wifi. Unless you share more details about the 12864 you have we cannot give you a straight answer.
                        antlobundefined 1 Reply Last reply Reply Quote 0
                        • antlobundefined
                          antlob @oliof
                          @oliof Thanks for the reply. I have the following display . For what I've seen in forums is an ST7920 but don't know how to be certain, the display is soldered to a backplate and don't have access to the chip. So, assuming that I have the correct one, should I follow scheck's diagram? And also seems like I have to compile version RRF 3.02 dev, right? Would it work, in principle? But, if by any chance you already have the *.bin file it would really help me. Many thanks again for your time. My current RRF version is 3.1.1 as suggested by @dc42.
                          • oliofundefined
                            oliof
                            RRF 3.2 only supports the 7565 and 7567 on Duet 2 Wifi by my understanding (I might be wrong there). You need to do Markus Scheck's or @bearer's) diagram.
                            I don't have the firmware file from my experimentation around anymore, but bearer's code excerpts above should get you going.
                            • antlobundefined
                              antlob @oliof
                              @oliof Thanks Oliof, I reread most of the messages and you were rigth @bearer uploaded his *.bin file, I've already updated the Duet with it. Funny thing is that now the DWC shows a Display Menu DWC_bearer_bin_file.png .
                              I'll try and do the hardware today or tomorrow and post my results (I give it a 10% rate of success and a 90% that I'll be asking questions again :-)).
                              • oliofundefined
                                oliof
                                If you have a Display menu item that's a good sign that DWC detected a firmware that does support an 12864. Don't forget that bearer did his own pinout in the interest of simplifying cabling, and that the encoder connections are direct connections. You still need the level shifter!
                                  A Former User
                                  (will re-do to try and match the stuff dc42 did, got some 7408 today, still trying to get some alcohol for cleaning so i can make a board though)
                                    A Former User @antlob
                                    @antlob said in Logic Level shifter for 12864 display on Duet 2 Wifi:
                                    You need pins from both CONN_LCD and CONN_SD to make both the LCD and the encoder and buzzer working. It is shown on the schematic.
                                    the RRF3 binary have had the hang printer support removed to fit the LCD code.
                                    I'm currently waiting to see what the status is when dc42 is done, to possibly redo the schematic and board to match a similar pinout and adjust the patch. However if the ST7920 support is being dropped in favour of the 756x then I'll probably just get a new display instead.
                                    • antlobundefined
                                      antlob @A Former User
                                      @bearer Many thanks! Just to be sure, this is the schematic I should connect, right? (without the swapping). Schematic.png
                                        @antlob think so, but probably easier to reference the stuff we published at https://easyeda.com/oliof/duet2wifi-lcd12864-adapter (it should at least be in sync with the attached patch)
                                        • antlobundefined
                                          @bearer Perfect! I'll give it a try later today.
                                          • antlobundefined
                                            antlob @antlob
                                            @bearer Didn't work, I get a blank screen, it turns on but is blue, nothing else, is the same as to give it 5v and ground.
                                            What I did was to use the Duet2CombinedFirmware-rrf3-lcd.bin file and update the firmware with it.
                                            I saw that attached you had this file lcd12864rrf2.patch. Should I upload it in the Display menu in the DWC? Also, the patch says RRF2 so Will it work on RRF3?
                                            Sorry for having so many questions.
                                            A Former User? Schmartundefined 2 Replies Last reply Reply Quote 0
