Smart Stepper?
2.2k
    3dmntbighker
    Anybody working on using these with a Duet?
    http://misfittech.net/nema-17-smart-stepper/
    Scratch built CoreXY with Maestro
    Heavily modified Ender 3 with Maestro
    MPCNC work in progress with Duet WiFi
      madude91
      I am interested to know how they work with Duet too.
        I have been unable to find any user manual or specification for this device, so I can't tell whether it is compatible. I have posted a question at https://groups.google.com/forum/#!topic/smart-stepper/a3IRc89yG5E.
          I have had a reply to my question. It looks like you should be able to use the Smart Stepper connected to the expansion connector or to the CONN__LCD connector. Connect the step, direction, enable and ground pins on the Smart Stepper in the obvious way. Connect the VIN pin of the Smart Stepper to +3.3V on the Duet. In the M569 command for that driver, I suggest T1:2:20:0. If you get missed steps, you may need to increase one or more of those values.
            vmario89
            it's an old topic but for all who found this: https://github.com/Misfittech/nano_stepper/issues/40
            i documented some stuff for wiring up the smart steppers with a Duet 2. Until yet i had no problems with missed steps yet. I did not configure the T parameter.
            by the way what are the default values for step pulse width, step pulse interval, direction setup time and direction hold time ?
            vmario89 created this issue 20 Nov 2019, 22:40 in Misfittech/nano_stepper
            closed Duet Board Support #40
            undefined undefined 2 Replies Last reply 7 Jun 2020, 16:55 Reply Quote 0
              zapta @vmario89
              @vmario89, what are the advantages of having that smart controller between the duet and the motor?
                dc42 administrators @vmario89
                @vmario89 said in Smart Stepper?:
                As fast as the Duet can generate them, which is well under 1us. The Trinamic drivers need only about 100ns.
