    Extruder hit the model after print job is done
    463
    • OwenDundefined
      OwenD
      It won't do anything not commanded.
      It's not normal to home after a print.
      You need to post the files listed above and perhaps the gcode you are printing.
      yolkgk1undefined 2 Replies Last reply Reply Quote 0
      • yolkgk1undefined
        yolkgk1 @OwenD
        @OwenD said in Extruder hit the model after print job is done:
        ok! I''ll show you the end of file!
        yolkgk1undefined 1 Reply Last reply Reply Quote 0
        • yolkgk1undefined
          yolkgk1 @yolkgk1
          This post is deleted!
          • yolkgk1undefined
            yolkgk1 @OwenD
            @OwenD M121
            M107
            M104 S0 ;extruder heater off
            M140 S0 ;heated bed heater off (if you have it)
            G91 ;relative positioning
            G1 E-1 F300 ;retract the filament a bit before lifting the nozzle to release some of the pressure
            G1 Z+0.5 E-5 F{travel_speed} ;move Z up a bit and retract filament even more
            G28 X0 Y0 ;move X/Y to min endstops so the head is out of the way
            M84 ;steppers offngontan
            G90
            this end G code work fine with Arduino mega 2560 and ramp 1.6! but with duet it not working! it only hit the model!
            • OwenDundefined
              OwenD
              Remove G28 X0 Y0
              Replace with G1 X0 Y0
              • yolkgk1undefined
                yolkgk1 @OwenD
                @OwenD thank you! I'll try and tell you the result!
                  G90 ; absolute positioning
                  G1 X0 Y0 ; move to x0 y0
                  Include G90 to be sure you are in absolute movement first.
                  • yolkgk1undefined
                    yolkgk1 @Phaedrux
                    @Phaedrux So I need to change "G90 ; absolute positioning G1 X0 Y0 ; move to x0 y0" in my end G code?
                      What type of printer is it: Cartesian, delta, or something else?
                      • yolkgk1undefined
                        yolkgk1 @dc42
                        @dc42 it is Cartesian type!
                          OK, I asked because on some deltas the M84 command on your slicer end Gcode will cause the hot end to drop into the print.
                          Your end Gcode looks ok to me, assuming that your homing files are correctly set up so that G28 X0 Y0 homes just X and Y.
                            Phaedrux Moderator @yolkgk1
                            @yolkgk1 said in Extruder hit the model after print job is done:
                            Well you need to be in absolute positioning mode to move to x0 y0. If you'r ein relative positioning mode (G91) X0 Y0 is a movement of nothing.
