PanelDue firmware 1.16 released
Thanks
rock on!
where should we post request for new features for the PanelDue? this thread?
Thank you David! will update shortly!!
~Russ
oh also, we still can not update this through the duet correct?
~Russ
ok, i got it updated using Win 10.
using Command line bossac found here: https://github.com/dc42/RepRapFirmware/tree/dev/Tools/Windows
win 10… oh boy...
any how, i havent updated sence V 1.13 i think it was, and the colors i have on my screen from 1.13 to the last 1.16...
well the colors are total wack IMO. they look " puke'e"
is this normal?
here is the one from your site, it looks SO much better?
Thanks!~Russ
Looks like you've loaded 5" firmware when you have a 7" screen, or vice versa.
the file i uploaded was labeled : "PanelDue-7.0-1.16.bin"
Ill try it again Monday. this is a 7"
any other ideas let me know…
Thanks David
~Russ -
Awesome! Will flash this just because the Emergency button
ok, all is fine now that i put the 5" LCD firmware on the 5" LCD…
haha i must have lost my marbles...
all is well,
~Russ
So far so good
I only wish the emergency button would be visible on the "Move head" screen as well.
While i was doing a bed level i tried to hit the STOP on the Panel Due.
it did not respond.
can some one else check this?
it should stop correct?
Thanks!
~Russ
Which firmware are you running on the Duet? You need version 1.18 to get a fast response from the emergency stop button on PaneDue.
A true emergency stop button is an electrical switch that disconnects the power to the printer.
1.18.1 duet WIFI
I hit it over and over to try to get it to respond but it never did. ( press and held it)
just wanted to point this out.
it responded right away on the web interface..
I decided to run some G code and try it. (octagon-test-delta.gcode)
it responded right away also.
but when doing a mesh grid ruteine it works fine. everything stops.
its only when I'm running a bed level ruteine.??
ok, now I'm confused… now after Manny restarts its working fine now.
wonder if anyone else has come across this??
~Russ
100% agreed!
I have not updated to 116 Yet but I am on 115C
I do not know if this feature is already in the PanelDue.
But I would like for the PanelDue to read the Default Heater Temperatures and Default Bed and Chamber Temperatures setting.
That I configed through the Duet Wifi web site,Do I can choose them for the Bed and hot-end temp
Thanks
Do you mean the settings that you have set the heaters to? Or do you mean the selections available on the drop down list?
I use macros to set the bed and hot end temperatures for the filaments that I commonly use.
