    Bug report - Macro name length on PanelDue
    PanelDue
    1.1k
    • kuhnikuehnastundefined
      kuhnikuehnast
      Hi there,
      found a funny bug:
      If the name of a macro is to long, it gets cropped on the PanelDue screen. But if you click on the cropped name on the PanelDue, you get the answer that the Macro isn't found. (It tries to execute a Macro with exactly the same cropped name as on the PanelDue and not the original one).
      Would be great to fix this!
      greetings kuhni
      • brunofportoundefined
        brunofporto
        Have the same issue
          Does the problem occur only on macros on the Control tab, or does it also occur with macros on the Macros popup?
          On the Control tab, macro names are currently limited to 20 characters. You may not see all 20, but 20 will be stored.
          kuhnikuehnastundefined 1 Reply Last reply Reply Quote 0
            kuhnikuehnast @dc42
            @dc42 said in Bug report - Macro name length on PanelDue:
            It occurs only on macros on the Control tab. If they are clicked on the Popup it works. (Even if then also not all characters are displayed...)
            brunofportoundefined 1 Reply Last reply Reply Quote 0
              brunofporto @kuhnikuehnast
              @kuhnikuehnast @dc42 Same here. The macros pop-up works.
                Thanks, both of you. I've added this to the work list for the next release.
                  kuhnikuehnast @dc42
                  Is there a mistake in the Release branch? https://github.com/dc42/PanelDueFirmware/releases As the current release, you can download 1.21.3... But on both of my Panels (5i and 7i) I have the 1.21.4 installed???
                  • Abelliundefined
                    Abelli
                    very helpful document...looking for it for a long time.
                    deckingmanundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                      deckingman @Abelli
                      @Abelli said in Bug report - Macro name length on PanelDue:
                      Yes, two years is a long time.
                        droftarts administrators @Abelli
                        @Abelli please stop resurrecting old threads, unless you have new information. If asking a related question, start a new thread and reference the old thread. Otherwise I’m going to assume you’re a spammer and ban you, as your behaviour and posts are similar to tactics used by spammers.
                          Phaedrux Moderator @droftarts
                          @droftarts At least his last post had actual 3d printing related content. Seems legit.
