    Layer Count Error
    Duet Web Control
    950
    • CCS86undefined
      CCS86
      Running RRF / DWC 3.1.1, I'm seeing a bad layer count. It is off by quite a bit.
      gcode sliced with Cura 4.6.1. 0.2mm first layer, 0.15mm layers after that. There should be 236.
      Large Claw.gcode
      • Lanovarundefined
        Lanovar
        Same with PrusaSlicer for me. Looks like its counting retractions instead of layers.
          Do you have Z hop configured in the slicer retraction settings?
          CCS86undefined 1 Reply Last reply Reply Quote 0
          • CCS86undefined
            CCS86 @dc42
            @dc42 said in Layer Count Error:
            No Z hop in this program.
            Since it shows in the Job information that the total height is 5mm, and the total layer count of 34 nearly matches that height with 0.15mm layers, it seems to be getting tripped up there. But, looking through the gcode, I can't see anything unique about Z5
            • Lanovarundefined
              Lanovar
              Yes i have @dc42
              • CCS86undefined
                CCS86
                Completely different model, sliced with similar settings also registers as 5.00mm tall and 34 total layers. In reality it is 24mm tall and 159 layers.
                  @CCS86 said in Layer Count Error:
                  Large Claw.gcode
                  Based on your start gcode it seems like it's picking up the G1 Z5 in your start gcode. Try changing that to be G1 Z5 ;E
                  • CCS86undefined
                    CCS86 @Phaedrux
                    @Phaedrux said in Layer Count Error:
                    Large Claw.gcode
                    Good call, I'll give that a try.
                    • CCS86undefined
                      CCS86
                      That did it, thanks!
                      • Lanovarundefined
                        Lanovar
                        My layer count is way off. Its supposed to be 75 layers.
                        Maybe someone can tell me, what Im doing wrong.
                        35x35_0.4mm_nozzle_flowrate_calibration_0.2mm_PLA_RatRig V-Core Pro_23m.gcode
                        • Lanovarundefined
                          Lanovar
                          Ahh ok, now I understand.
                          Is ;E excluding that line from layer count?
                          • Lanovarundefined
                            Lanovar
                            So now Im down to 76 of the original 75 layers.
                            I think the last wrong layer is the ";before layerchange" G1 Z0.200?!
                            My before layerchange section is empty in PrusaSlicer. Any tipps on how to fix that?
                            Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              Phaedrux Moderator @Lanovar
                              @Lanovar Add the ; E to this line in your start gcode: G0 Z5; Raise nozzle before move and add ; E to this line in your end gcode: G1 Z45.2 ; Move print head up
                              Lanovarundefined 1 Reply Last reply Reply Quote 0
                              • Lanovarundefined
                                Lanovar @Phaedrux
                                @Phaedrux I already did that, but one false layer is still left.
                                Maybe you could take a look at my second post?!
                                  @Lanovar said in Layer Count Error:
                                  I think that G1 Z0.200 is the layer change.
                                  ;BEFORE_LAYER_CHANGE
                                  G1 Z0.200 F12000.000
                                  ;AFTER_LAYER_CHANGE
                                  That's before layer change, layer change, and after layer change. with before and after being blank.
                                  But it also looks like you have Z hop on.
                                  G1 Z0.400 F12000.000
                                  G1 X150.000 Y167.279
                                  G1 Z0.200
                                  Z hop, travel, back to layer height.
                                  And in your end gcode you have a z move, but you should make sure you're in G91 relative positioning mode before doing the Z move. That way you can move the extruder up above the print rather than to a fixed position (which may be inside the print).
                                  ;END_G_CODE
                                  M400 ; wait for current moves to finish
                                  M104 S0 ; turn off temperature
                                  M140 S0 ; turn off heatbed
                                  M107 ; turn off fan
                                  G1 F1000.0 ;E set feed rate
                                  G1 E-3 ;E - retract 3mm
                                  G1 Z45.2 ;E - move extruder up
                                  G1 X20 Y200 F3000 ;E - move extruder to X side
                                  M84 X Y E0 ; disable motors
                                  • Lanovarundefined
                                    Lanovar
                                    Ahh ok. I understand.
                                    Yes I have, but does it count as a layerchange in DWI?
                                    Actually Im using conditional G-Code in PrusaSlicer for that:
                                    {if layer_z < max_print_height}G1 Z{z_offset+min(layer_z+30, max_print_height)}{endif} ;E - move extruder up
                                    Isnt that kind of like switching to G91? Or am I misunderstanding what youre saying?
                                      @Lanovar We've hijacked another persons resolved thread. I think it would be best if you created a new thread with your issue. Include your firmware and DWC version, the example gcode file, your homing file.
                                      Yes that makes sense.
