    Erratic bet temps followed by heater fault
    476
    • Co3getundefined
      Co3get
      Help me think this through. I'm having a hard time heating my bed up. it goes up smoothly to about 65 or so, then gets erratic with small variations, small 'jumps'. it struggles along and eventually faults.
      I've checked my connections a few times. My SSR is a new panasonic. Ideas?
      Photo is trying to heat up to 90 degrees:
        What is the heater and thermistor? How are they configured?
        What is the error message you get?
        What firmware version? What board are you using?
        Have you PID tuned the bed?
        Post your config.g.
        • jens55undefined
          jens55
          I had exactly the same issues - it turns out this is a faulty sensor in the heat bed. I ended up installing a separate (external to the heat pad) sensor and all issues went away. I use the old defective sensor as a secondary sensor that is displayed on my graph but is not used for control purposes.
          Co3getundefined 2 Replies Last reply Reply Quote 1
            deckingman
            I agree with @jens55 . That temperature trace is noise. The real temperature cannot have such rapid excursions. It's either a faulty sensor or a wiring problem such as a bad crimp.
            • Co3getundefined
              Co3get @jens55
              @jens55 I have been thinking along these lines, I have a big red heat pad with a built in sensor. Were this any other printer I'd replace the bed thermistor and be done. What sensor did you use?
              • jens55undefined
                jens55
                Just a standard thermistor like you get on hot ends. Taped to the underside on top of the heater with Kapton tape
                Co3getundefined 1 Reply Last reply Reply Quote 1
                • jens55undefined
                  jens55
                  Don't forget to re-run tuning for the bed when the new sensor is hooked up.
                  • Co3getundefined
                    Co3get @jens55
                    @jens55 said in Erratic bet temps followed by heater fault:
                    That's pretty smart. middle of the bed?
                    • Co3getundefined
                      Co3get @jens55
                      @jens55 Can you explain you you set up the old sensor as a graphed secondary sensor?
                      • jens55undefined
                        jens55
                        @Co3get, here is my heater section of config.g:
                        M308 S0 P"bedtemp" Y"thermistor" T100000 B4200 ; configure sensor 0 as thermistor on pin bedtemp
                        M308 S3 P"e2temp" Y"thermistor" A"bed sense 2" T100000 B4200 ; configure alternate or second bed heat sensor
                        M140 H0 ; set bed heater to heater zero
                        M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
                        M308 S1 P"e0temp" Y"thermistor" T100000 B4200 ; configure sensor 1 as thermistor on pin e0temp
                        M307 H1 B0 S0.6 ; disable bang-bang mode for the nozzle heater and set PWM limit
                        M308 S2 P"e1temp" Y"thermistor" T100000 B4200 ; configure sensor 2 as thermistor on pin e0temp
                        M950 H2 C"e1heat" T2 ; create nozzle heater output on e0heat and map it to sensor 2
                        M143 H2 S280 ; set temperature limit for heater 2 to 280C
                        M307 H2 B0 S0.6 ; disable bang-bang mode for the nozzle heater and set PWM limit
                        It's been a while since I set that up so am not too sure what all was done.
                        I do know that in order to display the second bed temperature on the graph in DWC, you need to go into the 'Extra' bit of the 'tools and extra' pane and flip the 'show in graph' thingy.
                        Hope that helps.
                        Yes, middle of bed for the sensor, offset a bit to not be directly where the bed wires go into the heat pad. I don't think it makes much difference exactly where it is located as long as it is somewhere in the middle-ish.
