    Extrusion Option greyed out
    968
    • aidarundefined
      aidar
      Hi. First of all :
      M667: Select CoreXY or related mode
      This command is deprecated in RRF 2.03 and later. Use M669 instead.
      Secondly, what DWC version are you using?
      • hiro_onoundefined
        hiro_ono
        I'm not sure what you mean by DWC version?
          deckingman @hiro_ono
          @hiro_ono How are you setting the temperature and what temperature are you setting to? You need to have the tool active (send T0) pr click on it. Then set he active temperature, Also, extrusion is disabled until the temperature reaches a default value. I think that is 160 deg C but I think it's configurable in DWC.
          Edit - DWC = Duet Web Control
          • hiro_onoundefined
            hiro_ono
            Duet Web Control 2.1.0
            Setting the temp in DWC, to 200.
            When i click on the tool it just says changing tool for ages, when thats done i still can't control the extruder.
            If I type T0 i get a green tick to say its worked but still cant extrude
            G1 E20 Works
              @hiro_ono When you click on the buttons in the web interface, what drive do you select and what feedrate?
              • hiro_onoundefined
                hiro_ono
                I just telect tool 0 i'm not selecting any specific drive i dont think? feed rate can be anything but doesn't make a difference, its on 5mm/s at the moment
                  jay_s_uk
                  IIRC, there was an issue with a DWC build of around your number.
                  I suggest updating to DWC 3.1.1 and RRF 3.1.1
                    deckingman
                    Something else too.
                    This line at the top of your config.g.............
                    ; Configuration file for Duet Maestro (firmware version 3)
                    But the configuration file is for firmware V2
                    What firmware are you actually on? (run M122 to find out).
                    • hiro_onoundefined
                      hiro_ono
                      @deckingman said in Extrusion Option greyed out:
                      M122
                      M122
                      RepRapFirmware for Duet 2 Maestro version 3.01-RC6 running on Duet Maestro 1.0
                      Board ID: 08D8M-9T8A2-MQNS0-7J9FL-3SJ6K-KNSQX
                      Used output buffers: 1 of 24 (21 max)
                      Static ram: 22012
                      Dynamic ram: 88620 of which 60 recycled
                      Exception stack ram used: 408
                      Never used ram: 19972
                      Tasks: NETWORK(ready,312) HEAT(blocked,1328) MAIN(running,1876) IDLE(ready,80)
                      Owned mutexes:
                      Last reset 01:40:48 ago, cause: software
                      Last software reset at 2020-06-18 12:56, reason: User, spinning module GCodes, available RAM 19972 bytes (slot 1)
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                      Error status: 0
                      Free file entries: 10
                      SD card 0 detected, interface speed: 15.0MBytes/sec
                      SD card longest block write time: 2.3ms, max retries 0
                      MCU temperature: min 35.0, current 39.7, max 43.9
                      Supply voltage: min 0.0, current 12.1, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: standstill, read errors 0, write errors 1, ifcount 93, reads 45221, timeouts 0
                      Driver 1: standstill, read errors 0, write errors 1, ifcount 93, reads 45220, timeouts 1
                      Driver 2: standstill, read errors 0, write errors 1, ifcount 96, reads 45221, timeouts 0
                      Driver 3: standstill, read errors 0, write errors 1, ifcount 80, reads 45218, timeouts 5
                      Driver 4: standstill, read errors 0, write errors 1, ifcount 69, reads 45232, timeouts 0
                      Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 45238
                      Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 45238
                      Slowest loop: 35.21ms; fastest: 0.13ms
                      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 121, MaxWait: 799239ms
                      === MainDDARing ===
                      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                      === AuxDDARing ===
                      Bed heaters = 0 -1, chamberHeaters = -1 -1
                      Heater 0 is on, I-accum = 0.4
                      Heater 1 is on, I-accum = 0.6
                      Segments left: 0
                      Movement lock held by null
                      HTTP is ready with "M122 " in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 140.79ms; fastest: 0.02ms
                      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                      HTTP sessions: 1 of 8
                      Interface state active, link 100Mbps full duplex
                      • hiro_onoundefined
                        hiro_ono
                        Just updated everything to 3.1.1 and its working fine now 🙂
