    Nozzle crashed into bed while homing - can this be avoided?
    3.4k
    • pandaymundefined
      pandaym @Phaedrux
      @Phaedrux said in Nozzle crashed into bed while homing - can this be avoided?:
      @pandaym said in Nozzle crashed into bed while homing - can this be avoided?:
      Do you mean that I change:
      Yup, you got it. Having Z moves in the start and end can sometimes confuse the DWC parser which messes up the layer count or object height etc. But it ignores moves with extrusion, so adding the ;E is a bit of a work around. Alternatively you can move the slicer start and end stuff into separate macros and and call them from the slicer. I only mentioned it as a precaution.
      Ok, that makes sense and is added. Thank you.
      As for the stall detection homing problem, I think part of the problem is that in the pause.g file it moves the head to x0 y0
      G1 X0 Y0 F6000 ; go to X=0 Y=0
      This places the print head up against the frame, correct? When trying to home after that it's already up against the frame, so it can't accelerate enough to trigger the homing I think.
      So as a test, try changing the pause positioning to be x10 y10.
      Correct, it places it against the frame. So you are right that it should get away from the corner before trying to home, and that will at least limit a potential homing failure. Unfortunately though, you can see on the video that it fails starting from other places too.
      What I am mostly worried about sorting out first though, is the fact that it runs the Z homing move without deploying a probe after and crashes straight into the bed. This concerns me, as I feel like that could occur again, also if I decide to go with switches instead of sensorless homing. Therefore it seems critical that I make sure this cannot happen, and then afterwards look at getting homing working perfectly. Do you have a feeling about where this issue comes from?
      mikep419undefined 1 Reply Last reply Reply Quote 0
        Are you still getting errors in the console when homing? I'm really hoping that if we can get reliable homing for X and Y from the stall detection that the Z homing will behave better.
        Can you try altering your homeall to include all of the commands from homex/y/z and removing the G32 from the homez?
        Can you also test homing each axis individually?
        pandaymundefined 1 Reply Last reply Reply Quote 0
        • mikep419undefined
          mikep419 @pandaym
          @pandaym it appears you are calling G28 to home all. This will cause Z to crash because in RRF 3 it cannot be defined as an endstop and a probe. You need to call G28 XY and then After your move to probing location call G30 to use probe for Z homing.
          Try calling G30 with the bed lowered way down and see if the probe deploys and can be triggered.
            Phaedrux Moderator @mikep419
            @mikep419 I'm not sure what you mean. his homeall calls his other homing files in turn. I'll put them all inline so they're a bit easier to glance.
            ; homeall.g
            ; called to home all axes
            M98 Phomex.g
            M98 Phomey.g
            M98 Phomez.g
            ; homex.g
            ; called to home the X axis
            M400                         ; Finishes all current moves and and thus clears the buffer
            M913 X50 Y50                 ; Set motor currents to 50%
            M201 X500 Y500               ; Set acceleration on X/Y to 500 stop improve reliability of stall detection
            M915 X Y S2 R0 F0            ; Configure motor stall detection on X and Y as they work together on corexy - sensitivity 2, don’t take action, don’t filter, 400steps/sec
            G91                          ; Set to Relative Positioning
            ;G1 Z5 F1200 H2               ;
            G1 H1 X-300 F4000            ; Move 300 mm left, stopping at the endstop - Speed is 4000 which is about twice the Hmin due to two motors working together on Corexy
            G1 X30 F1200                 ; Move 30 mm out from Xmin
            ;G1 Z-5 F1200 H2              ;
            G90                          ; Set to Absolute Positioning
            M913 X100 Y100               ; Set motor currents back to 100%
            M201 X1000 Y1000             ; Set acceleration back to 1000
            ; homey.g
            ; called to home the Y axis
            M913 X50 Y50                 ; Set motor currents to 30%
            ;G1 Z5 F1200 H2               ;
            G1 H1 Y-300 F4000            ; Move 300 mm back, stopping at the endstop - Speed is 4000 which is about twice the Hmin due to two motors working together on Corexy
            G1 Y30 F1200                 ; Move 30 mm out from Xmin
            ;G1 Z-5 F1200 H2              ;
            ; homez.g
            ; called to home the Z axis
            G1 X150 Y117 F12000 ; Move probe to middle of bed
            M558 F500 ; Set the probing speed
            G30 ; Do a single probe to home our Z axis
            M558 F50  ; Set a slower probing speed
            G30
            M558 F200
            G32 ; Run 3-point bed calibration defined in bed.g
            ; bed.g
            ;G28 ; home
            M558 F160 T16000
            G30 P0 X35 Y173 Z-99999 ; probe near a leadscrew
            G30 P1 X265 Y173 Z-99999 ; probe near a leadscrew
            G30 P2 X150 Y290 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
            G1 X20 Y20 F16000
            G29 S1
            ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 14 2020 14:49:36 GMT+0200 (Centraleuropæisk sommertid)
            G90                                                   ; send absolute coordinates...
            M83                                                   ; ...but relative extruder moves
            M550 P"CoreXY"                                        ; set printer name
            M669 K1                                               ; select CoreXY mode
            M540 PBE:62:38:32:53:34                               ; set custom MAC address
            M552 P0.0.0.0 S1                                      ; enable network and acquire dynamic address via DHCP
            M586 P0 S1                                            ; enable HTTP
            M586 P1 S0                                            ; disable FTP
            M586 P2 S0                                            ; disable Telnet
            M569 P0.0 S0                                          ; X motor - physical drive 0.0 goes forwards
            M569 P0.5 S0                                          ; Y motor - physical drive 0.5 goes forwards
            M569 P0.1 S1                                          ; Z motor 1 - physical drive 0.1 goes forwards
            M569 P0.3 S1                                          ; Z motor 2 - physical drive 0.2 goes forwards
            M569 P0.4 S1                                          ; Z motor 3 - physical drive 0.2 goes forwards
            M569 P0.2 S1                                          ; Hemera motor - physical drive 0.2 goes forwards
            M584 X0.0 Y0.5 Z0.4:0.1:0.3 E0.2                      ; set drive mapping - X Y frontLeftZ FrontRightZ RearZ E
            M671 X-35:335:150 Y173:173:335 S15 	                  ; Bed rotational center - front left, front right and rear center
            M350 X16 Y16 Z16 E16 I1                               ; configure microstepping with interpolation
            M92 X160.00 Y160.00 Z800.00 E381.81                   ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00                   ; set maximum instantaneous speed changes (mm/min)
            M203 X16000.00 Y16000.00 Z180.00 E1200.00             ; set maximum speeds (mm/min)
            M201 X2000.00 Y2000.00 Z20.00 E250.00                 ; set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E800 I30                          ; set motor currents (mA) and motor idle factor in per cent
            M84 S30                                               ; Set idle timeout
            M208 X0 Y0 Z0 S1                                      ; set axis minima
            M208 X320 Y320 Z320 S0                                ; set axis maxima
            M574 X1 S3                                            ; configure sensorless endstop for low end on X
            M574 Y1 S3                                            ; configure sensorless endstop for low end on Y
            M574 Z0                                               ;
            M950 S0 C"io7.out"                                    ; create servo pin 0 for BLTouch
            M558 P9 C"^io7.in" H5 F120 T6000                      ; set Z probe type to bltouch and the dive height + speeds
            ;M558 H30                                              ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
            G31 P500 X1 Y24 Z0.80                                  ; set Z probe trigger value, offset and trigger height
            M557 X15:215 Y15:195 S20                              ; define mesh grid
            M308 S0 P"temp0" Y"thermistor" T100000 B3950          ; configure sensor 0 as thermistor on pin temp0
            M950 H0 C"out0" T0                                    ; create bed heater output on out0 and map it to sensor 0
            M307 H0 B0 S1.00                                      ; disable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                               ; map heated bed to heater 0
            M143 H0 S200                                          ; set temperature limit for heater 0 to 200C
            M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
            M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
            M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S300                                          ; set temperature limit for heater 1 to 300C
            M950 F0 C"out7" Q500                                  ; create fan 0 on pin out7 and set its frequency
            M106 P0 S0 H-1                                        ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"out4" Q500                                  ; create fan 1 on pin out4 and set its frequency
            M106 P1 S1 H1 T45                                     ; set fan 1 value. Thermostatic control is turned on
            M563 P0 S"Hemera" D0 H1 F0                            ; define tool 0
            G10 P0 X0 Y0 Z0                                       ; set tool 0 axis offsets
            G10 P0 R0 S0                                          ; set initial tool 0 active and standby temperatures to 0C
            T0                                                    ; select first tool
            M501												  ; load saved data from non volatile memory
            • mikep419undefined
              mikep419 @Phaedrux
              @Phaedrux i apologize for not being clear. In his start g-code he posted above he calls G28. My understanding was when he started the print the crash occurred. I had not seen his homing files. What I should’ve said was make sure he’s using G30 on the homez.g macro.
              • pandaymundefined
                pandaym @mikep419
                @mikep419 said in Nozzle crashed into bed while homing - can this be avoided?:
                Just picking up on your replies now, so I will just reply to this one. It happens apparently when I start a second print, or at random, not sure. I fail to see the exact pattern or logic in what happens, but it just seems to be trying to probe Z without deploying the probe - possibly based on a failed X or Y home?`
                Should be all good with my homez.g macro, as I am using G30 there.
                • pandaymundefined
                  pandaym @Phaedrux
                  I have not seen any other errors than what I posted above which indicate that either X or Y fails to home, and the probe cannot be deployed. I am just worried about the fact that it ignores this and continues to move the bed upwards. I hope I can find the reason for this, so that even when I get the homing of X and Y reliable, I still know it won't crash the bed if something should happen on X/Y.
                  I will try make a homeall that includes all the commands instead of calling the others, remove 3 point true bed levelling from homez and test it. I think it might be best to not try and fix X/Y homing before this other thing is fixed, as I will have a hard time figuring out if it works then. I'll get back with the results.
                    Phaedrux Moderator @pandaym
                    I disagree. I think X and Y homing must be reliable regardless because the Z homing depends on being able to accurately place the probe where you want it.
                    For the probe not deploying the pin it's possible there is a wiring issue. The BLTouch has a lot of wires and the crimps are often a cause of problems, so definitely double check your wiring.
                    G31 P500 X1 Y24 Z0.80 I also note that your trigger height is very low. Typically, when the BLtouch is mounted correctly, the base of the probe body is ~8mm above the nozzle tip, which leads to a trigger height of ~2mm. This is the sweet spot for accurate and reliable results.
                    By the way, what version of BLTouch is it? Is it genuine or a clone?
                    • pandaymundefined
                      pandaym @Phaedrux
                      I understand your point about the X and Y. I just assumed that it did not really matter where on the build plate the probe were for probing Z, as I am only in this phase of the build.
                      There truly are a lot of wires that has to be done right on the BLTouch. I checked my wiring and crimping and it all looks good.
                      I reconfigured a bit like you suggested, and what I noticed was that it seemed like true bed levelling was causing the issues. I therefore went through my configs and currently have them configured like this:
                      homex.g:
                      ; homex.g
                      ;Prepare for homing
                      G1 Z5 F1200 H2               ; Move the bed down slightly
                      ;Prepare for sensorless homing
                      M201 X500 Y500               ; Set acceleration on X/Y to 500 to improve reliability of stall detection
                      ;Sensorless homing X
                      ;End of sensorless homing
                      M201 X2000 Y2000             ; Set acceleration back to 2000
                      ;End of homing
                      homey.g:
                      ; homey.g
                      ;Prepare for homing
                      ;Sensorless homing Y
                      ;End of homing
                      G90                          ; Ensure we are in Absolute Positioning
                      homez.g:
                      ; homez.g
                      ;Prepare for homing
                      ;Probe Z
                      M558 F500 					 ; Set the first probing speed
                      G30 						 ; First Z probe
                      G30							 ; Second Z probe
                      ;End of homing
                      homeall.g:
                      ; homeall.g
                      ;Prepare for homing
                      ;BLTouch home Z
                      G30 						 ; First Z probe
                      ;End of homing
                      bed.g:
                      ; bed.g
                      M561 						; Clear any bed transform
                      M401 						; TEST!!! Deploy probe - deployprobe.g
                      G30 P0 X35 Y173 Z-99999  	; Probe near front-left leadscrew
                      G30 P1 X265 Y173 Z-99999 	; Probe near front-right leadscrew
                      G30 P2 X150 Y290 Z-99999 S3 ; Probe near rear-center leadscrew and adjust bed parallel to corexy kinematics
                      M402 						; TEST!!! Retract Probe - retractprobe.g
                      G1 X20 Y20 F12000			; Move close to home
                      For the bed.g, I tried various things to see if the probe would deploy, and ended up finding this to work. I found this particular way of doing it in the same guide I used to set up my BLTouch. This is the guide I used.
                      So in response to your question about trigger height, I found the value in the same guide. It basically tells you to move the nozzle down all the way to the build plate and run:
                      G92 Z0 ; Tell the machine we are at Z=0
                      G1 Z10 ; Move Z 10 mm  away from nozzle
                      G30 S-1 ; The value you get here is the offset you put in G31.
                      The guide also notes that as low a value as possible is best, which to me makes sense, as that will leave the most clearence under the nozzle when probing. I am not sure I understand why the trigger height in itself affects the accuracy or reliability, could you explain that?
                      I tried to measure the physical delta, and it is actually around 8mm. The Hemera carriage with BLtouch mount is one I downloaded off of thingiverse, so I did not design this delta myself.
                      Last thing, yes it is a genuine BLTouch v3.1. Only clone component on the printer are the linear rails.
                      So where do we go from here? 🙂
                      • pandaymundefined
                        pandaym
                        As you recommended, I also tuned the sensorless homing.
                        I think the main reason was that I had no H value on the M915 commands. I am running 0.9 motors, so I set that to 400 and sensitivity to 1, and now that part at least seems to work good:
                        https://www.youtube.com/watch?v=tnWOXK7N014
                        • pandaymundefined
                          pandaym
                          So while waiting to see what you guys think is going on, I went ahead and did a test print. Seems I have more issues 😉
                            I wonder if part of the issue is binding on the axis...
                            • pandaymundefined
                              pandaym @Phaedrux
                              I don’t think there’s any binding going on. I completely disassembled, flushed, greased and carefully assembled all the linear rails. I spent a lot of time with squares and calipers during the build and would say that the machine is very mechanically sound. That is my strong side, so I am more concerned with electronics/firmware where I am still very challenged.
                              I just saw the other post with @dlc60 having 45 degree layer shifts. Mine are exactly 45 deg and exactly the same direction and distance between them. I wonder if we are seeing the same thing?
                              • pandaymundefined
                                pandaym
                                @Phaedrux
                                I am trying to tune some different things right now, and it just happened again 😞
                                It seems completely random! This time I know for sure that the X/Y homing when fine, but still the probe did not come out, and I just managed to stop it before crashing hard..
                                Console says:
                                19.6.2020 14.55.16
                                Error: Z probe was not triggered during probing move
                                Error: Homing failed
                                  Alright you must check your BLTouch wiring for continuity. The crimps are notorious failure points. This is by far the most likely problem at this point.
                                  • pandaymundefined
                                    pandaym
                                    Alright I ran through it.
                                    I got it wired uip to IO_7
                                    Red wire runs to 5V_EXT - Continuity, measured ~2.2 ohm
                                    Yellow wire runs to io7.out - Continuity, measured ~2.2 ohm
                                    Brown and black wire run to GND - Continuity, measured ~2.2 ohm
                                    White wire runs to io7.in - Continuity, measured ~2.2 ohm
                                    Earlier today I was doing a test print, and I noticed the red LED was flickering while it was printing. Afterwards I noticed that it was blinking after homing. So I looked it up on Google, and found something that I did not comprehend entirely, but it was someone talking about the probe thinking it is too close to the bed to be able to deploy. I rebooted the machine and noticed that BLTouch did not do it's self-test either. So I allowed movement without homing, lowered the bed a lot, rebooted, and when powering it back on, it did self-test again and constant red LED.
                                    Don't know if the LED blinking observation has anything to do with this issue, but just wanted to mention it.
                                    I do not know much about any of this, but I would have assumed that there were a safety measure in place that immediately stopped the Z movement for G30, in case an error is thrown that the BLTouch cannot deploy for whatever reason. Maybe I could code that into my homings to create a safety net for this issue till we hopefully solve it?
                                      Flashing red usually indicates error state if the self test is unable to successfully deploy and retract the probe or if the pin is blocked when trying to deploy. Could also be an intermittent wiring break depending on position.
                                      As a precaution you can add the alarm release and pin retract command to the end of config.g and start of homeall to clear any errors just in case.
                                      You can try and take the pin out of the probe and check it/clean it by removing the set screw on the top.
