Slice Thermistor - Wavy line in temp chart
My Duet controlled machine
228
    PaulHew
    Just installed a Mosquito with Slice's temp sensor.
    RRF3.1.1
    I am using this line from RRF Config tool
    M308 S1 P"e0temp" Y"thermistor" A"Mosquito" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
    I have seen other posts mention that the temps fluctuate at room temp and stabilize which it gets to higher temps.
    Is there a way to smooth this out?
    TIA Paul.
    undefined 1 Reply Last reply 19 Jun 2020, 16:33 Reply Quote 0
      deckingman @PaulHew
      @PaulHew Obvious question but have you run a heater tune? The oscillations look like that might be what the temperature is really doing, rather than a noisy signal.
      Edit. If you have run a heater tune (or even if you haven't), try increasing the "D" value in M307.
      undefined 1 Reply Last reply 19 Jun 2020, 17:14 Reply Quote 1
        PaulHew @deckingman
        @deckingman Hi Ian, Yes I did a PID tune, forgot to mention it. 🤦
        I will try your suggestion.
        ? 1 Reply Last reply 19 Jun 2020, 17:16 Reply Quote 0
          A Former User @PaulHew
          @PaulHew said in Slice Thermistor - Wavy line in temp chart:
          does it just oscillate when printing or also when idle stationary?
          ? undefined 2 Replies Last reply 19 Jun 2020, 17:16 Reply Quote 0
            A Former User @A Former User
            This post is deleted!
              PaulHew @A Former User
              @bearer Both! Not worried about the room temp, but would like it more stable higher up.
              ? 1 Reply Last reply 19 Jun 2020, 17:24 Reply Quote 0
                @PaulHew was thinking changes in airflow around the printed part, it being cyclic could be layer dependent, but unlikely.
                undefined 1 Reply Last reply 19 Jun 2020, 17:45 Reply Quote 0
                  @bearer even with the fan off it fluctuates.
                  I will adjust the D value and see what happens.
                  P.
                  6 out of 8
